AQL Sampling Tables Question
baioce
I have been reading extensively about how acceptance sampling and do understand perfectly the AQL concept. What I dont understand and I cannot find an explanation for is the following.
Lets suppose that I have a lot of 100,000 and I want a maximum of 1% defects. Based on the table below I would be sampling 500 products and accepting <=10. My question is: How do they come up with 10? If this is based of a 1-sided binomial distribution, if I plug in those numbers at a 95% confidence I get that the maximum that I can accept is 1 defective product in the sample. So, how come they are saying 10? How do they come up with that number? What am I missing?
Thanks so much for the help
Well, the formula you used is not the formula the AQL tables are based on.
The AQL tables were based on grouping of lot sizes and a lot size adjustment that isn't necessary and was the result of negotiations.
Remember that the AQL is the defect rate that will be accepted 95% of the time. (if your confidence level is 95%)
The manner in which you used the Binomial had your 1% defect rate as the RQL or Rejectable quality level (aka LTPD); the defect rate that you would detect and therefore reject 95% of the time. These are very different plans. This plan would give you an AQL of .07%
You may want to check out this AQL RQL Spreadsheet developed by some of us at the cove rather than the AQL tables. The formulas are listed in the spreadsheet so you can understand how calculations are being done.
baioce
Thanks so much. I will take a look and will let you know if there is anything I cannot figure out.
Thanks again for your help!
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
P Which Sampling Tables for AQL? Statistical Analysis Tools, Techniques and SPC 6
A AQL Tables or Binomial/Poisson Method? Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
alonFAI AQL and Sampling Size for Components Solderability Test Statistical Analysis Tools, Techniques and SPC 3
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
K Verification Sampling vs. AQL - Sampl Sizes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F AQL - ISO 3951-4:2011 Sampling Plan Requirements AQL - Acceptable Quality Level 2
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A What is the purpose of using AQL (Acceptable Quality Level) for Sampling? AQL - Acceptable Quality Level 3
J Sampling Plans - AQL Table Application AQL - Acceptable Quality Level 2
C C=0 vs. AQL MIL Standard 105 E - Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Why sample size for c=0 sampling plan reduces across the increases of AQL AQL - Acceptable Quality Level 2
J Incoming Inspection AQL Sampling of Bulk Textiles AQL - Acceptable Quality Level 3
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
0 AQL Sampling Plan based upon ISO 2859 AQL - Acceptable Quality Level 1
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
A What is a good lot size? We use the C=0 Sampling plans at AQL %1.0 AQL - Acceptable Quality Level 9
B Sampling Plan - AQL effect on Sample Size AQL - Acceptable Quality Level 9
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
M Sampling AQL - Am I understanding it correctly? AQL - Acceptable Quality Level 2
P AQL and Sampling Plan as they relate to Functional In-Process Inspections AQL - Acceptable Quality Level 4
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
S Using AQL to get true random sampling using General Inspection Level II AQL - Acceptable Quality Level 4
M Sampling a continuous process - How to use AQL with a continuous process AQL - Acceptable Quality Level 6
W AQL and RQL Calculation for Variables Sampling Plan AQL - Acceptable Quality Level 8
S Setting AQL Levels with Multiple Suppliers Supplier Quality Assurance and other Supplier Issues 3
Q Anything higher than AQL 6.5 (ACCEPT/REJECT)? Misc. Quality Assurance and Business Systems Related Topics 8
S Question regarding AQL - ISO 3951 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
S AQL tables: how to read them Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C What is the Appropriate AQL for Purchased Implantable Devices? Supplier Quality Assurance and other Supplier Issues 5
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
S ARMY AQL - Requirements which don't have an AQL associated with them Manufacturing and Related Processes 2
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
