Are Capability Requirement(s) Valid for All Characteristics?
Jkuba
Dear all,
beside of special characteristic (SC, CC, ...) there are always many other characteristics in the drawing (let's say "normal"). The process capability indices are usually evaluated and controlled for special characteristics only (+ some additionally defined char.)
My question:
Is there any minimum requirement for Cpk/Ppk of "normal" characteristics? If so, where is it stated?
Thank you
Jkuba
Hello howste,
I searched an answer in customer requirements of EOMs (VW, BMW, GM..) and so far did not find anything specific. BUT does it mean it's acceptable to have characteristics with Cpk below 1,00? (or 1,33?, ...)
howste
Thaumaturge
There may or may not be requirements from your customers or from a QMS standard that apply. It looks like you're in the automotive industry, so maybe IATF 16949 or VDA apply to your company?
Let's look at the situation from a risk-based perspective. If the Cp and Cpk values are determined correctly (normal distribution and in control) then you would expect roughly 2700 PPM nonconforming with a Cpk of 1.0, and it would be double that if the process is centered and still has Cpk =1.0. If we cared enough about the characteristic to do a study on its capability, then we probably wouldn't want to be shipping that much bad product to the customer. Depending on the criticality of the characteristic for product function or safety (or other risks) we would want to determine if we should work to reduce the variation or center the process better.
If we find that the Cpk=1.33 it's closer to 64 PPM nonconforming. Still not perfect, and you would want to make a decision about the risks to you and the customer and decide if it's an acceptable level or some work needs to be done. Cpk=1.67 is less than 1 PPM, and Cpk=2.0 would be roughly 2 parts per billion NC. Use the data to make decisions on the risks.
in general (and your customer's requirements may differ), for characteristics that are not identified as critical the supplier must still ship parts that meet the specification. Some Customers have stated acceptable defect rates and others hew to the zero shipped defect standard. So its not about capability indices. These are notoriously unreliable at predicting defect rates beyond + 2 SD even when the distribution is roughly bell shaped. They also give no indication or protection against any defect rate up to and including 100% during an out-of-control period. :mg:
It's really about how you control the actual shipped defect rate
Golfman25
Dear all,
My question:
Thank you
So here's the thing. Basically a new customer quality guru will state "min. cpk 1.33 required" and that will be applicable to every dimension on the print. Then when he realizes what a nightmare he created, you'll negotiate down to critical and/or significant characteristics. If those aren't identified, I would look at the tightest tolerance items. Good luck.
bobdoering
Stop X-bar/R Madness!!
Section 2.2.11.1 spells out the requirement: the customer spells out the requirement. The down side? They typically have NO IDEA how capability indices relate to your process. None. They just rubber stamp 1.33 all over their prints - even on unilateral tolerances (concentricity, etc.), which clearly does not apply! Remember this - because I ASSURE you your customer will NOT - Ppk and Cpk are ONLY valid for normally distributed and two-sided specifications with the target in the center. See AIAG PPAP 4th edition section 2.2.11.5 NOTE. Unfortunately, it tells you to go to the SPC book for guidance, and the guidance there is poor at best.
N Customer Requirement exceeded my BMC (Best Measurement Capability) Measurement Uncertainty (MU) 3
Howard Atkins Calculation of capability of a minimum requirement with no found maximum Statistical Analysis Tools, Techniques and SPC 1
C Is the QS-9000 requirement to maintain PPAP capability gone from TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
bobdoering Unilateral Tolerance Capability Calculations Capability, Accuracy and Stability - Processes, Machines, etc. 1
