Are 'Error Proofing Methods' required to be mentioned in Control Plans?
minrah
Hello all,
Got a question regarding Control Plans -
Are 'Error Proofing Methods' required to be mentioned in Control Plans (is it required by the standard)?
Thanks in advance !
Minrah
Hello all,
Thanks in advance !
Minrah
There are requirements to consider error-proofing in the design phase and to use error-proofing in corrective actions when possible. If you have implemented error-proofing in production, then it's a control method and must be in the control plan. If you have no error-proofing mechanisms, then of course they wouldn't be in the control plan.
minrah
Should Error Proofing methods be mentioned as a separate Column in Control Plan Format. The Format of Control Plan as in APQP and Control Plan Manual does not mention any such separate requirement of 'Error Proofing Method' Column.
If there are any error-proofing methods in the process, they will be mentioned in 'Evaluation/Measurement Technique' Columm. :confused:
Thanks,
Minrah
Thanks,
Minrah
They are Current Process Controls (Prevention). The "Evaluation/Measurement Technique" field should be used to describe the error-proofing method(s).
Q
q8792271
"Error proofing" is a tool, standard require us to ues this tool when we solve the problem.
outdoorsNW
Jim,
Why did you state that error proofing belongs in the Evaluation/Measurement Technique column?
Looking at the AIAG book, page 53, I see no mention of error proofing in the description for that column. The Evaluation/Measurement Technique description talks about measuring tools and MSA.
However, in the Control Method column description, in about the middle of the first paragraph, I see “Operations may be controlled by…mistake proofing…”
Tom
Jim,
However, in the Control Method column description, in about the middle of the first paragraph, I see ?Operations may be controlled by?mistake proofing??
Tom
I guess it depends on the type of error-proofing involved. There could be dedicated gage of some sort, use of which is an evaluation/measurement technique. On the other hand, if error-proofing is something built into a tool or machine and just prevents a bad thing from happening, it wouldn't be considered that way.
N Error-proofing tools/methods to suggest? TS16949 Clause 8.5.2.2 IATF 16949 - Automotive Quality Systems Standard 2
C What is Error-Proofing Methods? TS 16949 Clause 7.3.2.2 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R Error Proofing Label process Manufacturing and Related Processes 4
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
K Documented problem solving and documented error-proofing - IATF 16949 10.2.3 & 10.2.4 Internal Auditing 7
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 33
optomist1 Error Mistake Proofing Color Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
S Manufacturing Error-proofing Packers mixing up which 4 Mats go together in a Kit Manufacturing and Related Processes 3
M Machine Feature: Is it possible to consider it Error Proofing? FMEA and Control Plans 6
D Error Proofing Workstation FOD (Foreign Objects and Debris) Problem Solving, Root Cause Fault and Failure Analysis 7
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
M Error Proofing Packing Process Problem Solving, Root Cause Fault and Failure Analysis 11
AnaMariaVR2 Healthcare Focused Error Proofing Hospitals, Clinics & other Health Care Providers 3
M Label Error Proofing - Mislabeled parts in a small automotive company Manufacturing and Related Processes 25
C Need help error proofing valve. All ideas welcome. Human Factors and Ergonomics in Engineering 31
Q Error Proofing Verification - Layered Audit Question Process Audits and Layered Process Audits 17
S Definition Error Proofing vs. Mistake Proofing - Differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
C Are Error Proofing Statistics Correct Nonconformance and Corrective Action 20
D Definition Error-Proofing vs. Mistake-Proofing - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
M Metal forming - Brake presses - Need error-proofing advice Manufacturing and Related Processes 8
B Definition Error Proofing vs. Programmable Logic Controls (PLCs) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
L Seeking examples - Error-Proofing Methodology - Used with regard to corrective action IATF 16949 - Automotive Quality Systems Standard 10
Marc Error Proofing - Brief Powerpoint .ppt files General Information Resources 0
K Compliance of Control Plans to Annex A - Addressing Error Proofing FMEA and Control Plans 13
S TS 16949:2002 - Error Proofing Column Required in Control Plan II FMEA and Control Plans 22
A Error Proofing In Every Corrective Action? QS-9000 - American Automotive Manufacturers Standard 2
D Seeking Information on Poka Yoke - Error Proofing Nonconformance and Corrective Action 3
D Use Error Risk Controls and Control Verification ISO 14971 - Medical Device Risk Management 6
H California Instrument AC Load - 222 Error Message Manufacturing and Related Processes 0
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
bobdoering Informational Ndc Calculation Error Caution Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I IMDS Error Message Question RoHS, REACH, ELV, IMDS and Restricted Substances 1
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M Trouble with Europa website - Internal Server Error (March 2019) EU Medical Device Regulations 5
Marc Definition MPEE - Maximum Permissible Error for Length Measurement Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S Need help wrapping my head around confidence vs beta error Statistical Analysis Tools, Techniques and SPC 2
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
R Rank Deficiency Error Minitab Using Minitab Software 7
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
