Are IEC 60601-1:2012 and BS EN 60601-1:2006+A11:2011 still identical?
ISO 13485 - Medical
can anybody help?
our device is compliant with en60601-1: 2006 (3rd Edition)
when reviewing the standard it says identitical to IEC 60601-1;2005 and BS EN 60601-1:2006
there have has been several new amendments been issued what is the differnce between them are the standards still identical?
IEC 60601-1:2012
The Amendment 1 to IEC 60601-1, Edition 3
Ronen E
Problem Solver
Moderator
can anybody help?
IEC 60601-1:2012
Here's my take (not a 60601 expert):
BS EN [something] has to be identical in its normative part to EN [same something]. The ":[year]" bit may differ because typically there's a time lag between issue of the EN version and the member state implementations (BS etc.).
You say that EN 60601-1:2006 claims that it's identical to IEC 60601-1:2005 (3rd edition). I won't argue with that.
As far as I understand, IEC 60601-1:2012 is simply a consolidated version of IEC 60601-1:2005 and its amendment 1 (A1:2012). It's obviously not identical to either IEC 60601-1:2005 (alone), EN 60601-1:2006 or BS EN 60601-1:2006. I think it's also not identical to BS EN 60601-1:2006+A11:2011 -- I don't know this "A11" in particular, but just based on the year of issue.
Bottom line, if you've already addressed amendment 1 (2012) to the 3rd edition, IEC 60601-1:2012 shouldn't matter too much to you. Otherwise, probably best contact your test house to discuss maintaining your compliance.
Cheers,
Ronen.
IEC 60601-1:2005 and BS EN 60601-1:2006 are identical.
Since their publication there has been a couple of corrigenda (corrections to details of the standard) and an Interpretation Sheet.
Then earlier this year IEC published Amendment 1 (a significant document of over 100 pages). There is a consolidated version available from IEC which you may see refered to as IEC 60601-1:2012 or as 60601-1 Ed. 3.1
IEC 60601-1:2005+A1:2012(E) contains requirements concerning basic safety and essential performance that are generally applicable to medical electrical equipment. ..... The contents of the corrigenda of December 2006, of July 2007, the interpretation sheet 1 of April 2008 and the interpretation sheet 2 of January 2009 have been included in this copy.
The latest version of the EU Official Journal (30th August 2012) that is the formal recognition of technical standards does not list the 2012 version or amendment 1. So there is not, yet, an EN version of 60601-1:2012.
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
K IEC 60601-1 Ed. 3.1 b:2012: Replaced IEC 60601-1 Ed. 3.1 en:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Why was Drip-Rate Infusion Pump removed from IEC 60601-2-24:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Salisburysteve Transfer of IEC 60601-2-10:2012 into BS and EN IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K IEC 60601-1:2012 - Impact Assessment for changes from IEC 60601-1:2005 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M IEC 60601-1: 2012 - Subclause 11.3 - Constructional Requirements for Fire Enclosures IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Inquiry about IEC 60601-2-10:2012 & IEC 60601-1-11:2010 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
N IEC 60601-1-8 ed2.1 Consol. with am1 (2012) IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
M Final draft of IEC 60601-1 Amendment 1 available - May 2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
I Acceptability of Existing Devices complying to IEC 60601-1 2nd Edition after Jun'2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
