Are inputs to the nonconformance process required to be identified?
I have a question on ISO 9001:2015, section 8.7.1, where it describes that "The organization shall ensure that the outputs that do not conform to their requirements are identified and controlled to prevent their unintended use or delivery"
I am in an audit and noticed that the supplier has a procedure that describes what actions to be taken when nonconformance is identified; but the procedure does not describe which type of inputs could lead to a nonconformance.
Per the ISO 9001:2015, is it required to identify the inputs to the nonconformance process?
AMIT BALLAL
Hi!
As per my understanding, the intent of the requirement is that the status of nonconformity should be known (by identification) and should be prevented from unintended use and delivery.
What we do is do red tagging of nonconforming products and these parts are kept in a defined area and the area is locked to prevent unintended use and delivery.
I don't think there is a requirement in ISO 9001 of identifying inputs to non-conformance process.
Marc
Fully vaccinated are you?
<snip> Per the ISO 9001:2015, is it required to identify the inputs to the nonconformance process?
I have updated the discussion title to be more specific.
I think this will be an interesting discussion, especially if folks give some examples of potential nonconformance system inputs.
If the supplier's procedure is addressing the controls on the detected NC product, he does not have to mention about the inputs.
His another procedure about the Nonconformity and corrective action (10.2) must be addressing the causes of NC (inputs)
Marc
<snip> the supplier has a procedure that describes what actions to be taken when nonconformance is identified <snip>
Is the specific question only with regard to product nonconformances?
When I see "nonconformance system" I think of many potential inputs. E.g.:
  • Process audit nonconformances?
  • System audit nonconformnces?
  • Compliance (to a standard - E.g.: ISO 9001) failure?
  • Compliance (to a national or international regulation) failure?
  • Product defect(s)?
  • Process failure(s)?
I guess I'm questioning what the definition of "nonconformance system" is in the starting discussion post. I'm probably over thinking this.
jmech
No, because there is no requirement in ISO 9001:2015 to identify the inputs to the non-conformance process.
Note that 8.7.2 and 10.2.2 already require the organization to retain documented information that describes the (nature of the) nonconformity and any actions taken. Would it add any value to require the organization to identify the inputs to the nonconformity process?
Mark Meer
Strictly by the standard, no this is not required to be explicitly stated.
However, the inputs are presumably implied, be it in a process-interaction description/flowchart, or simply in enumerating different types of non-conformities (see, for example, Marc's post above). Also, people involved with the process should know what the inputs are.
There may be a suggestion for improvement, but not a finding.
Thanks for all the responses.
From my FDA regulated background, I also felt that it would be good if the inputs types are identified but seems like the ISO 9001 has no requirements. Yes, not a finding but something for them to consider.
If you are auditing the area "Control of NC outputs" and looking for /asking about inputs types here, then its not the approach. These is no scope for any improvement or any consideration.
ISO 9001 certainly addresses the input types contributing to a NC output in the "NC and corrective action"...
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
K Are Nonconformance inputs to the product also NC product? Nonconformance and Corrective Action 11
M Management Review Inputs ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G How to record Regulations and Standards as Design Inputs? Design and Development of Products and Processes 15
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 14
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
M Inputs on definition of very similar processes for multi site audit sample - IAF MD1 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Sequence of performing risk assessment: User_FMEA (User Errors) vs Design Inputs FMEA and Control Plans 1
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
K IATF16949 inputs/outputs & KPIs Internal Auditing 3
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
I Trying to explain some of the Management Review Inputs (AS9100D) Management Review Meetings and related Processes 10
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
armani Difference between requirement for 4.4.1a (inputs) and 4.4.1d (resources needed)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
armani ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 15
A SIPOC (Suppliers Inputs Process Outputs Customers) examples wanted Quality Manager and Management Related Issues 1
L Identification of Inputs vs. Outputs in Design and Development (Section 7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Design Inputs - Final Medical Device Specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
J Design Inputs and Verification Activities CE Marking (Conformité Européene) / CB Scheme 5
C Required Management Review Inputs List Management Review Meetings and related Processes 10
Crusader What are the CB's inputs and deliverables at Stage 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S Cost Targets as Design Inputs in your DHF (Design History File) US Food and Drug Administration (FDA) 7
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Sampling Inspection at QA - Inputs on the following sampling plan Statistical Analysis Tools, Techniques and SPC 3
J Names of Inputs and Outputs in Octopus Diagrams IATF 16949 - Automotive Quality Systems Standard 3
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
S AS9110B ? Product Safety Inputs to Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Management Review Inputs - Production Site under a Corporate Certification Scheme Management Review Meetings and related Processes 9
Q How to read and interpret an SIPOC (Suppliers Inputs Process Outputs Customers) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Risk Assessment Matrix Question - Inputs from the DFMEA, etc. FMEA and Control Plans 9
R Software System Inputs and Outputs - IEC 62304 5.2.2 - Software Requirements Content IEC 62304 - Medical Device Software Life Cycle Processes 6
Q Design Inputs Document Content Design and Development of Products and Processes 20
F Failure Modes for Public Transport Vehicle Door Assembly - Your inputs please! FMEA and Control Plans 27
C ISO 17025 Testing Laboratory Management Review Inputs ISO 17025 related Discussions 2
E SIPOC (Suppliers Inputs Process Outputs Customers) Feedback & Example to share Process Audits and Layered Process Audits 12
Chennaiite DFMEA (Design FMEA) at Vehicle Level - Some inputs needed. FMEA and Control Plans 4
S Definition Inputs vs. Resources in the context of a Process - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
M SIPOC (Suppliers Inputs Process Outputs Customers) Process Mapping Tool example Process Maps, Process Mapping and Turtle Diagrams 11
Z SIPOC (Suppliers Inputs Process Outputs Customers) Chart Training Material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Management Review Inputs (Process Performance) Management Review Meetings and related Processes 16
O Management Review Inputs and Outputs - AS9100 Registration Audit Requirements Management Review Meetings and related Processes 16
S Design Trace Matrix Ensuring that Design Outputs meet Design Inputs wanted 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Quality Planning process map - Struggling to define all the inputs and outputs Process Maps, Process Mapping and Turtle Diagrams 17
