Are Machine and Equipment Manuals Controlled Documents?
Howard Atkins
Forum Administrator
I received this question by E-Mail from frank napoli
"We are starting the process for TS and are evaluating documents to identify under document control. Since preventative maintaince is required, do companies consider identifying machine maintenance manuals as controlled?"
Do you mean your internal maintenance manual or that supplied by the manufacturer.
Your manual yes, IMO it is the equivalent of a work instruction
The manufacturers manual, yes also, you need to update the maintenance information that you use.
What do others do?
Marc
I typically see them as locally controlled documents by maintenance or whoever is responsible for maintaining the equipment.
CarolX
I see it as this, like Marc said, controlled locally. In other words, the document should be identified and accesable (sp), but updating to "current revision" isn't required unless issued and delivered by the manufacture. You would not be required to actively search for updates.
JMHO
Wes Bucey
JMHO
I dealt with a lot of machines in a high tech machining environment. Most of them were so complex, I wouldn't have been able to turn one on, let alone use it to make something, without a short (sometimes a LONG) session with the operating manual, which we kept in a heavy duty plastic pouch chained to the machine.
For the most part, manufacturers do not update or revise the manuals except when bringing out a new model. (You only need the update if you have the new model or upgrade the machine itself.) Occasionally, there will be bulletins about new attachments or accessories available, which we added to the plastic pouch. Operators would often refer to these manuals for tips in working out a new setup.
In the last five years, manufacturers of complex CNC machines have made their machines internet accessible and the entire manual applicable to the machine is downloaded into the machine memory and routinely updated via internet. Some manufacturers even allow for remote programming of the machine from the manufacturer's engineering department.
We extracted information from these machine manuals to create our own maintenance Work Instruction to cover all machines in a department, which we "normalized" to allow setting up a routine for maintenance to mesh with our work load (so no machine was scheduled for a long run if routine maintenance would have interrupted the run - a business decision might be made to complete the maintenance early BEFORE the work run.)
TIP: When you spend $250,000 on a machine, it's OK to put the arm on the manufacturer to supply a couple of backup copies of the manual to keep in storage for replacement if the one at the machine is damaged beyond legibility.
Bottom line: We considered the manufacturer's manual a REFERENCE DOCUMENT - our employees might highlight passages or add margin notes - we did not CONTROL any of the copies. We considered our Work Instruction a CONTROLLED DOCUMENT. We sealed (laminated) it in plastic to prevent notes and highlighting and to prevent deterioration from dirt, grime, and oil.
Marc
Let's not neglect manuals for areas such as metrology. Different departments typically have documents which are specific to them that are (or should be) controlled locally. The degree of 'formal' control is relative to the importance of the document. For example, I know calibration laboratories that calibrate in accordance with the manufacturers manual and do not go through the motions of deriving a specific work instruction.
As always (sigh), it's sitution specific.
KIDDO
What about information printed from a CD-ROM?
Our maintenance manager has recently printed Lock Out procedures from the manufacturer. He's laminated them and put them out on each machine on the plant floor... nothing approved, dated, revision level..... ugh!!:mad:
IMHO I believe he needs to control these documents.. but now they're laminated and I know he'll hum and haw about destroying these and reprinting them, re-laminate etc. etc.
Before I go and "set him straight", do you agree that these need to be controlled?
thanks:bigwave:
KIDDO
CarolX
IMHO, no they do not. These are safety procedures and instructions issued by the manufacture. Do you require any other type of safety or warning signs to be approved?
Look at it this way....does the operator need to know how to do this to make good parts?
Helmut Jilling
Auditor / Consultant
Wes Bucey said:
We extracted information from these machine manuals to create our own maintenance Work Instruction to cover all machines in a department...
These two ideas are the most comon approach I see. The auditors I know have not required owners manuals to be officially controlled. They generally do not change.
In most instances, confusion results from not understanding what actually needs to be controlled. Processes need to be controlled, and one of the elements of process control is the control of related documentation. If a document is necessary (or potentially necessary) to the efficacious operation of a process, the document should be controlled to the extent that the document will be changed when a process change renders the document obsolete.
Equipment manuals (issued by the equipment manufacturers) may or may not be necessary to the operation of a process. (Note that operation of a machine and maintenance of it are two different processes.) If they are, they should be controlled in a manner that ensures they remain current and relevant.
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
S Measuring OEE (Overall Equipment Effectiveness) for each Job, not for Machine Lean in Manufacturing and Service Industries 2
C Measuring Equipment on Injection Machine should be Calibrated by 3rd party? General Measurement Device and Calibration Topics 21
K Machine or Equipment Purchase Checklist and Content Manufacturing and Related Processes 1
A Control of Production Equipment,Tools and Numerical Control (N.C.) Machine Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Machine Set-Up Sheets for More Than One Kind of Equipment FMEA and Control Plans 15
E Class 1K & 10K cleanroom specification - Machine/equipment design for IC packaging Design and Development of Products and Processes 2
Y Product Stability (Machine Capability) vs. Equipment Repeatability (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Machine/Equipment Maintenance List ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D What is the best gage equipment to measure an ID bore? Coordinate Measuring Machine? General Measurement Device and Calibration Topics 11
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
R Machine directory (2006/42/EEC) is applicable or not Other Medical Device Related Standards 0
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Marc The German Enigma Machine of World War II After Work and Weekend Discussion Topics 0
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
C Machine Verification Plan Manufacturing and Related Processes 2
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
GoSpeedRacer Veterinary anesthesia machine CE Marking (Conformité Européene) / CB Scheme 1
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
J Extent of Validation - New machine installed in manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
K IEC 60601-1-9 Compliance mendatory or Not - CT Scan machine CE Marking (Conformité Européene) / CB Scheme 8
