Are Medical device Raw material suppliers required to be ISO 13485 certified
mpfizer
We are medical device manufacturers manufacturing equipment and orthopedic implants. In USFDA CE or ISO 13485 is there any clause or requirement that states that raw material suppliers have to be ISO 13485 certified especially for high risk devices . Suppose that the raw material supplier is certified to ISO 9001 and all lots supplied are tested to relevant ISO standards for chemical , physical and mechanical properties is it not ok?
Does ISO 13485 require suppliers to be ISO 13485 certified ?
Please comment
michelle
mpfizer
Please comment
michelle
would request more experts to comment please
michelle
Sidney Vianna
Post Responsibly
If ISO 13485 required suppliers to be certified to any management system standard, a requirement to that effect would exist in the document. As there is no such requirement, what additional comments you expect to the question?
Obviously, from a product conformity and business continuity perspectives, you want to ensure that critical suppliers have robust business and quality systems. Certification to a standard does not assure either one.
RA_QA_Expert
ISO 13485, ISO 9001, 21 CFR 820 or any other QMS standard/regulation worldwide do not require sub-contractors to be ISO13485 certified.
You need to eshablish your own approach to selection, evalution and monitoring of our suppliers. ISO 13485 requires risk-based approach to each step based on the risk the purchased product as on the safety and performance of the medical device.
In your case, besides ISO 9001 and materiál testing, I would recommend also on-site supplier audit (critical supplier).
racglobal
Nothing in ISO 13485 requires the suppliers to be certified to the standard. The decision is up to you as to whether you require your suppliers to be certified. What is the risk of the supplied material with respect to safety? Is it a critical supplier? ISO requires that you control your suppliers; as to how you control your suppliers is a question for you and your top management.
indubioush
michelle
I agree with what all others have said. There is no requirement that your suppliers have any certification.
Would I buy a low risk part from a supplier without a cert? Yes.
Would I select a contract manufacturer that had a 9001 cert but no 13485 cert? No.
P Medical Device Raw Material Traceability Requirements Other Medical Device and Orthopedic Related Topics 6
J Risk Assessment of Raw Materials? Medical Device product ISO 14971 - Medical Device Risk Management 2
H Medical Device Manufacturer: Incoming Raw Material Inspection ISO 13485:2016 - Medical Device Quality Management Systems 5
A Raw Material Specifications - Medical Device Company ISO 13485:2016 - Medical Device Quality Management Systems 8
J Endotoxin testing - Raw materials and components of a Class III medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
L Medical Device Registration in Macau Other US Medical Device Regulations 1
A Medical Device Registration in the Dominican Republic Other Medical Device Regulations World-Wide 4
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
T B2C Medical Device Shipping across the US Other Medical Device Related Standards 0
M Medical Device Registration In Malaysia Other Medical Device Regulations World-Wide 2
