Are Medical Device Servicing Instructions Part of Labeling?
Aphel
Hello!
Can you give some advice regarding the following topic:
Does a servicing instruction of a medical device belong to labeling?
Our auditor says yes...
I just want to know where in the US law is this defined?
I really would like to this special section...
Thank you very much for your support.
Best regards,
Aphel
Marc
Hunkered Down for the Duration
My bet is no. Sorry, I'm not a medical device person but I'll try to help.
What clause, and in what standard, did the auditor cite?
yodon
Look in the labeling guidance: http://www.fda.gov/downloads/Medica...onandGuidance/GuidanceDocuments/UCM095308.pdf
On p. 18 ('physical' p. 26), there's the statement: "Labeling includes ... maintenance manuals, etc." Might be splitting hairs between "service" and "maintenance" but that may be where they're coming from.
Irrespective of the "label" you give the service instructions, maybe the root of the issue raised is control? How do you control the service instructions (versus how would you control them if you considered them labeling)?
And clearly there are requirements for capturing service records so if the service instructions themselves are uncontrolled, the service records may be incomplete, inconsistent, etc. But maybe I'm overreaching.
Ronen E
Problem Solver
Moderator
I'd say definitely yes.
Service instructions would be an integral part of the intended use basis. They'd establish part of the "normal use" of the device, i.e. under what terms the device is intended to perform as labeled.
Cheers,
Ronen.
somashekar
Put a symbol on the label which will mean to refer to user manual and within the user manual, have the servicing instructions clearly said in the contents...
Chris Ford
<snip> Does a servicing instruction of a medical device belong to labeling?
Our auditor says yes... <snip>
Did you read the definitions and regulatory requirements for labeling?
I'm going to have to assume that since your auditor claimed the service instruction is labeling, that the service instruction accompanies the device and this servicing is performed by the customer.
If the service instruction is an internal document (ie an internal work instruction), then your auditor is obviously incorrect. If this instruction does accompany the device then it is labeling.
Section 201(m) defines 'labeling' as:
'all labels and other written, printed, or graphic matter
(1) upon any article or any of its containers or wrappers, or
(2) accompanying such article' at any time while a device is held for sale after shipment or delivery for shipment in interstate commerce.
FDA has also explained what it means by "accompanying" just to be sure there's no confusion...
The term 'accompanying' is interpreted liberally to mean more than physical association with the product. It extends to posters, tags, pamphlets, circulars, booklets, brochures, instruction books, direction sheets, fillers, etc. 'Accompanying' also includes labeling that is brought together with the device after shipment or delivery for shipment in interstate commerce. Yes... this even extends to the internet. If you post a service instruction on a website, it's labeling. In fact, the entire website (relative to the medical device) is labeling, whether it's about servicing, performance claims, clinical claims, etc.
So, you see there is no wiggle room in the interpretation. If it's provided to the customer, it's Labeling.
The need for such labeling is determined by the device intended use and the safety and effectiveness of the device. If service instructions are necessary for the ongoing performance of the device (which means assuring that the device remains safe and effective), then these instructions must be included in the device labeling.
In determining the safety and effectiveness of a device for its intended use, the following factors are to be considered and addressed in the device's labeling by the inclusion of appropriate information:
  • The persons for whose use the device is represented or intended
  • The conditions of use for the device, including conditions of use prescribed, recommended or suggested in the labeling or advertising of the device, and other intended conditions of use;
  • The probable benefit to health from the use of the device weighed against any probable injury or illness from such use;
  • The reliability of the device; and,
  • Other relevant factors.
One of the easiest, quickest routes to a 483 and Warning Letter is a labeling error. A very simple error on your part can become a very costly mess, if FDA finds your device is misbranded or adulterated. A labeling field correction could cost the company tens of thousands of dollars, so if you don't have an experienced regulatory professional at the company, I'd highly recommend that you speak with a consultant about your device labeling. There are several nuances to consider with regard to the required labeling for specific devices and device types, and it's really not a topic to be taken lightly.
Ronen E
Problem Solver
Moderator
@Chris Ford:
Just so that people don't get confused:
One of the easiest, quickest routes to a 483 and Warning Letter...
A warning letter is indeed a result of an apparent failure on behalf of the regulated party; however, a completed 483 form (inspection findings) being issued could be just a routine outcome of normal FDA operation. Of course, if there are findings worth noting then it means the inspected party has a <100% compliant conduct (at least by the investigator), but this is very common and doesn't necessarily mean gross misconduct. Typically, USA-based entities get inspected on a regular basis, regardless of them being suspected by FDA for anything, and except in the uncommon case, there will be some findings. The 483 is just a wrap-up of such findings, which may in fact be quite minor (though non-negligible). Of course, if the recipient of a 483 doesn't handle it properly, it can lead to a warning letter. But that's a separate issue.
Other than that I mostly agree with your analysis.
Cheers,
Ronen.
Chris Ford
@Chris Ford:
Other than the original post having nothing to do with the definition and use of Form 483, or how it can manifest in a Warning Letter, I can't disagree with your description. Still, labeling violations are highly cited on Form 483 and in Warning Letters. There is no debating that, or the fact that labeling violations can and often do result in very costly field corrections.
Regardless, my point is accurate and I certainly see no point in splitting hairs or mincing words about the definitions and use of the 483.
No determination can be made regarding the original question, without further understanding the device and the document that the original question refers to. The original post does not explain the auditor's rationale for determining that the service instruction is labeling, nor does the original post explain why it is not labeling.
So to be perfectly accurate in answering the original question, and based on the information provided, there is no answer. Service instructions may or may not be labeling. However, I thought it would be more useful to point to the labeling regulation and the definition of labeling rather than give the OP a canned yes or no. Always err on the side of caution, until all of the information can be considered.
Ronen E
Problem Solver
Moderator
It's all good, I feel we're not actually saying much different.
Now, I didn't bring the 483s into this thread - you did. And relating to that, I didn't argue that you were not acurate. In fact, I don't feel I negated your post; I only added upon it. You may be very knowledgeable in that regard, but please remenber that many of this forum's visitors do not possess the relevant expertise, or may not master all the relevant nuances. So as a regular here, I feel that it's appropriate - every once in a while - to try and simplify / disambiguate things wherever there's a fair chance that a newbie or the occasional visitor might misinterpret. There's no obligation on anyone to do that - I do it because I like helping people, and the feedback I got so far from Cove users is that this is welcome and appreciated. I'm not preaching to anyone, though. I also trust that if that was disruptive to discussions, I would have heard about it from the moderators by now (and I haven't).
I guess what I was trying to state in the previous post was - in short - that most USA-based, FDA regulated entities will get a 483 sooner or later, either with or without having major labelling (or other) compliance issues. It's mostly a natural, normal outcome of the system, and doesn't say that all these entities are in severe misconduct. To clarify: I don't claim you wrote or intended to say otherwise. Once again, I mostly agree with the views you expressed.
Peace,
Ronen.
S Medical Device Servicing - Forms and Signature ISO 13485:2016 - Medical Device Quality Management Systems 1
F Mexico Medical Device Importing and Servicing Other Medical Device Regulations World-Wide 2
S Manufacturers Obligations for Medical Device Servicing and/or Repair EU Medical Device Regulations 10
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
SteveK Medical Device Servicing ? What Terminology? ISO 13485:2016 - Medical Device Quality Management Systems 3
J Medical Device Engineering, Manufacture, and Servicing Document Storage US Food and Drug Administration (FDA) 1
T Definition Servicing Activities - Definition - Medical device accessory manufacturer Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
A Interpretation of GMP Requirements for class 1 medical device manufacturer (device GMP exempt, only General controls applicable) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Legal Manufacturer of a medical device Vs Legal Manufacturer of MDSW EU Medical Device Regulations 7
T Loaded spring device - Active medical device? EU Medical Device Regulations 1
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 2
J Does Pakistan Medical Device Import License allows parallel import? Other Medical Device Regulations World-Wide 0
K China Medical Device Labeling requirements - Language China Medical Device Regulations 3
F Software as a Medical Device (SaMD) Technical File Requirements Manufacturing and Related Processes 1
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
dgrainger Informational EU medical device website change from 'Growth' to 'Health and Food Safety' (6/2020) Medical Device and FDA Regulations and Standards News 0
B How to classify a medical device based on MDR? EU Medical Device Regulations 3
J Need for a cleanroom in the manufacture of a medical device for a clinical trial EU Medical Device Regulations 4
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
F Labelling requirements for a medical device containing fragrance allergens EU Medical Device Regulations 3
A Medical device Reporting : Good Faith Effort for Additional information Other US Medical Device Regulations 2
A Medical Device Vigilance decision tree for Japan for class 2 devices. Japan Medical Device Regulations 1
I How to classify a medical device based on FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S The US FDA requirements on Disposal of a medical device US Food and Drug Administration (FDA) 1
Edward Reesor EU Authorized Representative for a Class I Medical Device CE Marking (Conformité Européene) / CB Scheme 10
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
S FDA Requirements for Medical Device Label Reconciliation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Medical Device Registration in the UAE MoH Other Medical Device Regulations World-Wide 2
JoCam Medical Device Distribution in the UK EU Medical Device Regulations 6
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Regulatory job in pharma vs. medical device US Food and Drug Administration (FDA) 16
S Regulatory job in pharma vs. medical device CE Marking (Conformité Européene) / CB Scheme 0
C New Class III medical device application for Health Canada Canada Medical Device Regulations 6
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 1
M Mexico Medical Device Registration Requirements Other Medical Device Regulations World-Wide 1
Q 21 CFR 821 Medical Device Tracking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Discontinuation of the Predicate Medical Device Medical Device and FDA Regulations and Standards News 1
H Online courses/program for medical device regulation EU Medical Device Regulations 4
T EQMS for small medical device company ISO 13485:2016 - Medical Device Quality Management Systems 11
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
dinaroxentool Question about qualification as a medical device or accessory in Europe EU Medical Device Regulations 2
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
