Are Overload Test Results expected to be maintained through out Life of Product?
N
Nancy Allen
Hoping someone can help...
Here are the facts:
We make mechanical (non electrical) Class ! devices. These attach to surgical tables and are used to position patients in the operating room.
When we design our products, we do overload testing to a 2.2 factor of safety. We base this testing on a test found in:
IEC 60601-2-46Medical electrical equipment –Part 2-46:particular requirements for the safety of operating tables, though we do not reference the standard in our CE self certification
Life testing is performed based on 5 years of use within the range of the specification (1X) rather than the 2.2 overload weight.
Here are the questions:
From a regulatory standpoint, is there a requirement (or if not a requirement, the expectation) that the 2.2 safety factor must be maintained through out the life of the product, or only that the product remain within specification.?
The 60601 standard does not provide any time period for 2.2 load testing.
Assuming we don't use the 2.2 factor of safety after initial load testing, would the expectation be that the 2,2 should be maintained at least when FAI tested out of box by a customer, or should the testing be done to the spec?
Thanks much for any thoughts on this!
Peter Selvey
Moderator
The mechanical test with a safety factor is normally time limited (e.g. 1min). This time together with the safety factor is intended to be representative of the lifetime stress on the device (e.g. 2.2 x rated load for 1 min shows the equipment can handle rated load for 10 years).
IEC 60601-1:2005, Clause 9.8.2 (which has the similar test as in IEC 60601-2-46) clearly indicates the safety factor test (1 minute) is intended to show the suitability for the service life. Also if you consider some of the higher safety factors in that clause (safety factors 2.5 - 12), it is clear that using these values for lifetime calculations would result in huge over design. Consider a normal load of 100kg rating x safety factor of 8, and then try to design the equipment for 10 years with 800kg rather than 100kg. These tests are really intended for just for 1 minute.
E Transformer Overload Test - Need help IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Windings Temperature exceeds the Limit - Overload Test of Switching Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S How to overload a linear transformer with multiple protective devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
Marc Information Overload World News 3
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Bench test report translation to English for 510(k) submission Other US Medical Device Regulations 2
J Production Line Test Brasil - High Voltage Dielectric Strenght Test Other Medical Device Regulations World-Wide 5
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
J 510(k) for a control kit for an external IVD test kit 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Cord anchorage pull test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Medical Device Airworthiness, DO-160 Test Planner IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Audit Finding For Not Retaining Test Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 10
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
N Heavy tare to simulate high load in a routine sensitivity test of a floor scale? General Measurement Device and Calibration Topics 3
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
A Information about Medical Device Test Laboratories Other Medical Device and Orthopedic Related Topics 4
B Standard for Dielectric Strength Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
J EN61010 Electrical Withstand Test IEC 62304 - Medical Device Software Life Cycle Processes 0
Z MDD ER 7.5, "phthalate test"? Aspiration tips EU Medical Device Regulations 3
G ISO 17025:2017 Uninterrupted chain of traceability for test laboratories ISO 17025 related Discussions 6
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C CQA Test Questions Bank General Auditing Discussions 1
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Watchcat Identification of Test Sample in Test Reports? Design and Development of Products and Processes 22
S Safety Class A with no test? IEC 62304 - Medical Device Software Life Cycle Processes 1
A IEC 60601-2-2 - Defib-proof test amendment to base standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
B EU: Alcohol test kits for breast milk IVDD EU Medical Device Regulations 2
D IEC EN 61326 Dated Standards - Dated standards for test protocols CE Marking (Conformité Européene) / CB Scheme 3
K Electromagnetic Compatibility Test IEC 60601-1-2: 2014 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A IEC 60601-1 Impact test on glass touch controller IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
D Medical device development - Custom test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 1
