Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies?
sushant_kulkarni
Initial process capability values Cp & Cpk are use to predic long term process capability.
Pp & Ppk are used to process measures.
My question is in Pp sigma value we are taking is what population is.
where as Cp we are using sample sigma value.
As all of u know large population give ucorrect reading.
And each and every time u notice the things initial process capability allways
not appropriate.
so insteed of Cp & Cpk why not Pp & Ppk as a beach mark for further studies?
Bcoz they are appropriate.
David DeLong
Pp and Ppk values come from short term studies and one uses all the values. It reflects the process potential and, it high enough, determines whether long term statistical control is required. It determines whether your process can meet the specification and with a Pp and Ppk minimum value of 1.67 or 5 estimated standard deviation.
Cp and Cpk values come from your control charts with out of control situations that have been addressed not included in your data with the estimate of the standard deviation coming from the average range. This give one the true picture of the process over time. I guess you could state it is the score card of your process over time.
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
R When Pp>2, and Ppk<1.33, can we approve a new process? IATF 16949 - Automotive Quality Systems Standard 3
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Advise on R Chart with Ppk of 17.85 for Ford Capability, Accuracy and Stability - Processes, Machines, etc. 37
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
M How to Do Ppk on Non-Normal Data Capability, Accuracy and Stability - Processes, Machines, etc. 10
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
J Using Ppk to set up Control Plans - Injection molding Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
