D.Salman
Dear experts,
Is process behavior charts the only way to analyze deviations from targets?
Many thanks in advance
Dear experts,
Dear experts,
An unstable process from which I can make little prediction as to if I will hit the target in the future.
I am a little wary of your use of the phrase "deviations from targets". Generally, when using SPC to try to understand deviations from targets we figure out the variability of the data itself - the deviations (standard deviation) away from the average of the data. That lets us know what the process has been capable of, and if stable, allows a prediction of future performance. Then we can look at the center line and the control limits, and compare that against any targets to see if the past performance has been hitting the target or not.
So I may have the following combinations occurring:
An unstable process with a trend towards the target (improving)
An unstable process with a trend away from the target (getting worse)
A stable process not capable of hitting the target
A stable process capable of (and predictably) hitting the target
You would need to categorize your results into one of these categories in order to understand "deviation from the target", and yes, you could use SPC to do this.
Hello D. Salman,
Just to make sure; what is your definition of "Process Behavior Charts?"
Are you referring to regular SPC control charts for variables?
Stijloor.
Dear Mr. Steve,
Thanks for the information, but I couldn’t understand what you mean of an unstable process from which I can make little prediction as to if I will hit the target in the future.
Can I have an example from the service industry?
