Are Quality Objectives applicable on HSE Department?
K
khetiajatin
Are quality objectives applicable on HSE Department? and if it is, could anyone tell me the examples?
t.PoN
There is three scopes here:
1. Quality, 2. Health and Safety and 3. Environments.
Each should have objectives to improve the system. one "MAY" or "MAY NOT" be applicable to the other.
For example:
Objective: Improve the quality of the product to be more safe during the handling process will be applicable to the Quality and Health & safety.
Two birds, one stone.
Another Example:
Objective: Increase the number of retained customer.
That is a quality objective but I can't see how you can apply it to Health or Environment.
So, I guess it depends on the objectives.
but as a management system. all should have objectives.
Important Note:
What is required by the ISO or the OHSAS is to have objectives established at "RELEVANT FUNCTIONS" of the organisation.
so if the HSE does't affect the quality of product, then it is not relevant and you can exclude this department from the quality objectives
John Broomfield
khetiajatin,
Yes, to the extent that HSE management results in a work environment that is conducive to quality (see 6.4).
But, unless unsafe work environment is a particular problem - which could be addressed by corrective action, fulfill all the objectives implied by clause 8.4 first.
John
K
kgott
Quality is about customer satisfaction, its about the entire impression or picture the customer gets about us. Safety cannot be excluded.
ISO 9001, ASOHS 18001 are risk control standards. Do what these standard require and you will be controlling risk to yourselves and the customer and so come acrosos to the customer as a well oiled, professional, efficient, effective, reliable and dependable organisation.
So how does safety come into this? Well, how can you be percieved in the above ways (a good quality organisation) if your safety performance is not very good?
Your safety objectives will nee to in some way contribute to your quality objectives.
W
Wilderness Woody
Maintaining a SAFE working environment means you are doing what you can to keep your necessary work force in working condition. If environment is not safe, then injuries or stress can lead to worker shortage which can delay shipments... impacting quality requirements for delivery.
Environmental controls can play a significant role in producing quality products. The printing industry relies on temperature and humidity to be within ranges in order to provide print registration as paper changes dimensionally with moisture content and inks need to cure properly.
HSE may direct purchasing of safety equipment for staff and facilities, so they integrate into the QMS structure as well.
K
khetiajatin
Thanks for all the valuable inputs.
In our organization we have separate departments Quality and HSE, and we are having our own HSE objectives which indirectly contributes to Quality, so do we need to make separate quality objectives?
JaneB
If you want to achieve certification to ISO 9001, you will need to meet the requirements for quality objectives. I don't know whether a department needs them (internal decision) but the company certainly does.
t.PoN
ISO 9001:2008 clause 5.4.1
Are your Objectives consistent with the quality policy?
If yes, then it is acceptable. It doesn't matter if it was issued by HSE department or QA
If the answer is No, then you need another objective
drgnrider
Objectives are generally stated at the company level, that does not mean that departments cannot create objectives that are in-line with the company ones and even task them to individual levels as well:
Company objective - Meet on time delivery of 98% or better
HSE objective - Ensure a healthy & safe working environment for all employees
Safety Manager objective - Perform at least two safety walk-throughs in the production area daily.
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
M Root cause for lack of quality objectives for HSE Dept. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
I Quality Policy and Objectives examples Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5
M Specific Values of Quality Objectives Benchmarking 7
Q Quality Objectives Not Met - Resources promised by investors ISO 13485:2016 - Medical Device Quality Management Systems 4
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Objectives in Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Farley.0 QMS Sales Goals & Quality Objectives Manufacturing and Related Processes 22
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
V Discussion of ISO 9001:2015 - "Quality Objectives" term ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Quality Department Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Corrective Action for Quality Objectives which are not Measureable Nonconformance and Corrective Action 7
T Best place in QMS to manage Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Quality Objectives for Quality Control and Quality Assurance functions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Will these Quality Objectives cover the Product Requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Presentation for tracking Quality Objectives across sites Preventive Action and Continuous Improvement 3
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
H ISO 9001 Quality Objectives Scorecard or Matrix template to share ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
L Changing Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Where to document Quality Objectives ISO 13485:2016 - Medical Device Quality Management Systems 6
J Quality Objectives for Engineering Department and R&D Quality Manager and Management Related Issues 5
A Quality Objectives 5.4.1 - KPI SOP - ISO 13485 Audit Observations EU Medical Device Regulations 6
A Are Explicit Quality Objectives Required? Quality Management System (QMS) Manuals 8
G Defining Quality Objectives for Product Realization and Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Quality Objectives - Telephone Calls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Quality Objectives for Aerospace Chemical Conversion & other Surface Treatment Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Determining Quality Objectives for the Finance Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
