Are there ISO9001:2015 Requirements for Preventive Maintenance?
indubioush
#11
Maintenance, one word, is required, if applicable. I don't really see much of a distinction between "maintenance" and "preventive maintenance."
John Broomfield
#12
Preventive maintenance tends to be more analytical (of equipment performance data) than ordinary maintenance at prescribed intervals.
Where it doesn’t really matter (to customers or to the effectiveness of the system) if equipment occasionally breaks down then simple maintenance would probably suffice.
outdoorsNW
#14
Suppose demand for products made on a particular machine type declined. A company now has several more machines than needed to meet current demand. A failure of the machine will cause a hard, easily detected failure at a later point, such as not making a hole when a later step requires something to be put in the hole. Assume scrap and downtime cost is acceptable. In this case can the AS9100 company simply wait until the machine breaks to perform maintenance and not violate AS9100D?
Marc
#15
Please do not take this personally - This discussion is related to ISO 9001 requirements. It would be more appropriate to start a new discussion (thread) in the appropriate AS9100 forum to avoid confusion.
somashekar
#16
Can I hear some folks weigh in on ISO9001 requiring a Preventive Maintenance Program (whether documented or not...)? I fail to see where it is called out as required (like 13485). I am not looking for whether its "good" to have one but rather if it is required.
Thanks folks: Ed
The ISO 9001 does not require the organization to have a preventive maintenance program. ISO standards do not prescribe any technique that has to be adopted, and so the ISO 13485 smartly uses the work "interval of performing the maintenance activities"
Where necessary, the NOTE in the end of the clause description will indicate towards the techniques that could be adopted by the organization.
It gives you the freedom and triggers the risk based approach.
Now it all boils down to your business, your industry and the risks that you can foresee to apply preventive maintenance program where necessary.
John Broomfield
#17
Thank you Sidney. I was thinking prediction was part of preventive maintenance. Essential when your machine is delivering your service directly to your customers.
#18
I agree with all folks stating that it is good to perform preventive maintenance and typically based on the equipment manufacturers recommendations and / or historical information/use. For custom equipment, this takes time to define. As putting into place an ISO9001 system, performing maintenance of equipment and infrastructure and recording those events should suffice until such time as to build a full PM system AND perform/maintain it. (To be honest I like 13485 much more as it is more prescriptive and allows for less interpretation.)
Marc
#20
I think of these this way:
Preventive: Change your car's engine (or transmission) oil every X miles driven. Generally the machine or assembly (the motor if it's a car) manufacturer determines an 'appropriate' interval in various ways.
Predictive: Using fluid analysis at X hours of use to determine what parts are wearing and the content expected over that time period. E.g.: Increasing and/or high levels of chromium indicates piston wear so Time to Overhaul may be reduced.
Also see: Definition - Preventive Maintenance vs. Predictive Maintenance - Distinction between
W ISO9001:2015 - Clause 7.5.2 - Requirements for Creating & Updating Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Changes in ISO9001:2015 to the requirements for a management representative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO9001:2015 Implementation / update plan template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S ISO9001:2015 Clause 9.1 - What the external auditor will look at? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S ISO9001:2015 6.3 - Planning of Changes - OFI from auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Is writing out the ISO9001:2015 standard full name a requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
E Interesting Discussion Was this the fastest ever stage 2 ISO9001:2015 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod ISO9001:2015 Cl. 9.1.1 and 9.1.3 evidenced with only improvement actions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Effect of ISO9001 2015 transition on ISO IEC 80079-34 Other ISO and International Standards and European Regulations 3
A ISO9001:2015 Process Matrix with clauses General Auditing Discussions 13
S ISO9001:2015 Cl. 4.4.1 - What Processes Do I Need Documented ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q ISO9001:2015 Cl. 6.1 - What evidences of risk addressing is needed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B Bare Bones/Under the Radar ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Is ISO9001:2015 required for AS9100:2016 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Icy Mountain ISO9001:2015 & IATF 16949:2016 Gap Analysis Tool IATF 16949 - Automotive Quality Systems Standard 7
D Internal Audit During the Transition Period from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Does ISO9001:2015 require any specific "processes"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N ISO9001:2015 clause 7.1.5 "Resources" (Formerly "Equipment") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Icy Mountain ISO9001:2015 Upgrade Diary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO9001:2015 and ISO14001:2015 Readiness/Self Evaluation Checklists wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Understanding ISO9001:2015 - 8.3: Design and Development of Products and Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Process Map Transition from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Auditor Training Materials Training - Internal, External, Online and Distance Learning 2
M ISO9001:2015 Clause 8.4 Control of External Processes and Purchased Goods & Materials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Corporate Manual - Global Multi-Site ISO9001:2015 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO9001:2015 comparison with AS9100:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Auditing Clause 5 - Leadership in ISO9001:2015 Internal Auditing 4
S Informational ISO9001:2015 Process Interactions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO9001:2015 Section 4.4.1 - Support Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Risks involved in requesting Cert to ISO9001:2015 right when released ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Customer Waiver in ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Lean in the ISO9001:2015 World Lean in Manufacturing and Service Industries 1
A Has anyone made an ISO9001:2015 vs. ISO9001:2008 Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
T COVID, Furlough and ISO9001 Surveillance Audit Coffee Break and Water Cooler Discussions 2
D ISO9001 for one man company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Calibration: Conforming to ISO9001 Requirements General Measurement Device and Calibration Topics 6
H Communication plan according to ISO9001 - Pharmaceutical field Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
N Is consultant prohibited in ISO9001 audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
R ISO13485/ISO9001 Convenient Document Management System Document Control Systems, Procedures, Forms and Templates 3
R ISO9001 & ISO13485 QMS for 2 types of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
