Are two separate procedures required for Corrective action and preventive actions
G
Gundam_W
#21
Just for discussion purposes...
IMO... A Preventive Action can be a Corrective Action while a Corrective Action cannot be a Preventive Action.
At Least this is how i interpret it.
It might not be the right way to do it but it is the best way.
Sam4Quality
#22
Gundam_W
Well....what have we got here now?:rolleyes:
Implying that B = A but A NOT= B?? Went a little mathematical though; there may be other non-quality related instances comparing the above equation to be true, but here in this case, I beg to differ.
Both preventive and corrective action are independent of each other. Define.
Corrective Action - Action taken to eliminate the cause of a detected non-conformity (so, that NC does not occur again!)
Preventive Action - Action taken to eliminate the cause of a potential non-conformity (so, there will never be a corrective action in this case!)
I dont see any direct similarity between these two independent actions. On second thoughts though, corrective action may be the outcome of a failed preventive action, but both cannot be the same, never the same.
If there are any examples of B = A or even A = B:evidence:, I would love to know.
Ciao.
SAM :cool:
Sam4Quality
#23
no it is okay i succed to get it thanks Ajit.
for us in my previous job, we got one procedures which treat the Corrective and ¨Preventive action
even in the current work we got one.
my explication of ISO requirement is that the mandatory is to get a procedure of CA & PA, but not necessary separate one! if it is written two time, it is just because the CA & PA are nitified in two separate chapter and of course in order to avoid any confusion, to have a procedure written is mentioned in the 2 chapter ! :bonk:?
And I see an old friend here! :bigwave:
Maverick SAM
bobdoering
Stop X-bar/R Madness!!
#24
I suggest defining the Preventive Action process and the Corrective action process. Use a turtle diagram if it helps. The inputs of preventive actions should not be things that have already occurred - unless they were similar things that you are extrapolating. The inputs of corrective actions should be things that have occurred, your process should analyze their root causes, etc., and the output should be eliminating the problem. Then determine if the processes are really similar enough to write into one procedure.
Sam4Quality
#25
Originally Posted by selena15
my explication of ISO requirement is that the mandatory is to get a procedure of CA & PA, but not necessary separate one! if it is written two time, it is just because the CA & PA are nitified in two separate chapter and of course in order to avoid any confusion, to have a procedure written is mentioned in the 2 chapter!
If that's the case then, no where in the entire standards does it say that there should be six separate mandatory procedures as a statement in itself. It has been interpreted based on the number of times the phrase "A procedure shall be maintained......" has been mentioned. So, then we have the liberty to actually make one document for all six mandatory procedures. True?
Then why only CA and PA to be included in one? Part of the Clause 4.2.1 Note1 of the ISO 9001:2008 version says "A single document may address the requirements for one or more procedures. A requirement for a documented procedure may be covered by more than one document."
So now its crystal clear. The standard does give us the liberty to include more than one procedures into a single document AND/OR have many documents for a single procedure. Period.
There is NO similarity between Corrective Actions and Preventive Actions. So there is no requirement for the determination of similarities for procedure purposes. The standard itself has clarified that.
Ciao. :agree1:
______________________
Sincerely, SAM
"To achive the impossible, it is precisely the unthinkable that must be thought!"
selena15
#26
Agreed Sam
ISO 9001:2008 had clarified it enough.
For just the discussion purposes:)...
Even before, we use to make also in one procédure the document control and the Forms in the same document
Lets say that normaly we can make together the document which go in the say spirit
isn't it ?
#28
Of course they're similar. They both deal with prevention of defects, one with recurrence and the other with preventing defects from happening to begin with.
I'm not speaking for Bob, but he didn't suggest that there was a requirement to gage similarities before combining process documentation. There is no requirement in the standard for using common sense, but some of us insist on doing it anyway.
Sam4Quality
#29
isn't it ?
I believe so! However, I would like to know others comments, past experiences on this, especially concerning audits. Do auditors really raise a hue and cry if they dont see the six mandatory procedures as independent separate documents? Also, about other procedures?
Ciao. :cool:
Sincerely, SAM
"To achieve the impossible, it is precisely the unthinkable that must be thought!"
Sam4Quality
#30
Originally Posted by Joe Cruse
No similarity?????
Well, I think I used the incorrect word here :eek:. I meant to say they (CA & PA) were not the same, in keeping with my earlier post.
And yes, I do agree, they're similar. :agree1:
Ciao.:cool:
Sincerely, SAM
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
M Should QA procedures be separate processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R CAPA (Corrective Action Preventive Action) Procedures Separate or Combined Nonconformance and Corrective Action 9
A Do you need a separate procedure for the 6 mandatory procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Separate procedures for ?identification, collection,..." etc. - ISO 17025 - 4.13.1.1 ISO 17025 related Discussions 4
I Non-ISO9001:2000 'related' procedures - A separate NC system for Customer Service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
I Separate procedures for parallel operations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Preventive and Corrective Procedures - Separate Procedures? Special Procedures? Nonconformance and Corrective Action 8
Marc Corrective vs. Preventive Systems and Procedures - Separate Procedures? Nonconformance and Corrective Action 12
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
H ISO 13485 - Separate Microbiology Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
P Two separate 510k submissions for one device from the same company Other US Medical Device Regulations 10
B ISO 9001:2015 8.4 External Providers - If work is transferred to a separate facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
T Two Separate Businesses - Only Part of Company Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Separate Classifications for Medical Device Accessories EU Medical Device Regulations 2
R One-Time parts separate from QMS? Quality Manager and Management Related Issues 9
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
C Do separate sites need separate documents? Document Control Systems, Procedures, Forms and Templates 7
A Newly Incorporated Business - Separate Scope and/or Separate Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Two Separate Legal Entities - Manufacturer Vs. Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 20
Q Separate Quality System? Product line of a parent company spins off 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
C Separate Certification - Can I combine documents for ISO14001, OHSAS18001 & AS4801? Miscellaneous Environmental Standards and EMS Related Discussions 3
S IEC 62366 - Embedded Software in separate Usability Engineering File? IEC 62366 - Medical Device Usability Engineering 1
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
F Multiple Business Lines (Separate Corporations) in one Facility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Separate Clinical Trials in the US and the EU - When one fails - question US Food and Drug Administration (FDA) 3
