ARGH Too Many Internal Audits
chris_gray1980
#11
Re: ARGH Too Many Audits
AndyN
Thhank you so much for your help, i have printed of the articles and im now going to make a cup of yorkshire tea and sit and have a read of them..
I do understand the process approach from my training but i have always seemed to fail when i try and impliment it, im not sure if im approaching it in the wrong way or starting at the wrong place.
This is where company 5 is quite good there procedures are written as process flow diagrams and there is one for each process so auditing is very good and logical i just end up with a lot in my reports which doesnt actually say anything really (if you get what i mean) i write out the question or what is required of the process and then i write what i have sampled BUT it seems very repetitive. i know auditing is going to repetitive to an extent but..
my CB hates the way the audits are BUT technically we are not doing anything wrong, everything we do complies with the standard its just the way we do it is utter rubbish.. he hates seeing check lists because yearly they say near enough the same things BUT they comply to the standard, he does try and advise me best he can but he knows what and who im up against. (we have had the same person from the same CB for the last 18 years... ive only been doing this job for 2 ish and i have NO previous quality experience i was shall we say 'thrown in the deep end')
Thanks again, keep the advice coming :rolleyes:
Chris..
Next time your in York i will by you a cup of tea and a scone :notme:
pkost
#12
Is there any justification for doing the audits twice a year? do they generate large numbers of non conformances each time? are there any audits that don't turn up many non conformances or are in less risky areas? These could be cut down to once a year or once per certificate renewal.
i wouldn't normally encourage cutting audits down to a minimum as they are beneficial, but in this case?!?
#13
Happy to help!
Firstly, you can audit a process, whether the documentation is process maps or not. It just takes preparation. I use a 'football' (rugger ball) diagram and each of the 'bubbles' (shown in the article diagram) is where I complete the information from the documents. This then replaces the old checklists.
On another point, I'd contest the assertion that you aren't doing 'anything wrong', technically or otherwise - the audits aren't being planned based on status and importance - if you are doing the same things over and again!
He's done you no favours by not raising this as an opportunity to look at things differently - in fact if he's looked at it for 18 years, he has copious evidence - he just has become 'comfortably numb'...
But let's focus on what will make your life easier, give management some benefit and engender an opportunity to recruit some others to assist in the deployment of a value-added internal audit service.
I'm off to make a mug of steaming Tetley...
chris_gray1980
#14
PKost
This is something that i have considered, the external auditor has said plan your audits 3 months in advance and base them on a critical basis..
If im honest MOST of the audits i carry out do not raise non-conformance's (i suspect the questions on the check lists are written in that manor because i suspect there are issues - its all a load of rubbish if you ask me.. i want to erase ALL of them)
I understand what your saying but im not sure how i could approach it.. could you really not audit a non critical area for 3 years ? (in between certificate renewals) for example company 2 is a very small company and never have any problems with them at all i would be happy and confident to leave them and only audit them once a year but surely i would have to do it yearly? i would need a very good argument to put to my manager to explain why im not carrying out audits in certain areas, he likes to see my audits so he can see whats going on whether is the same yearly or not..
This also leads in to the management review it ends up being MASSIVE by the time i have analyses all the internal audits and actually is says nothing (if you get what i mean)
I would be interested to hear some more thoughts on this though...
I really need to sit down and get my head around all this..
MY HEAD HURTS NOW....
#15
Head hurts? = Learning new stuff!
The answer to the last post is in the process approach! Don't forget, you'll be touching between 60 - 80% of the processes each time you do an audit. Forget what your CB says about setting a schedule of 3 months ahead based on 'critical' - what the heck is that? Take a look at what I wrote about 'status and importance' or, in different words, 'risk and impact'.
It's highly unlikely that any process in a business won't have changes or performance issues in a 3 year period. If you use that as your criteria, you'll get on top of it.
Let's be honest and open here: Your auditor isn't helping you. He's made only vague statements about scheduling and checklists, and, if he really knew what he was talking about, you'd have made changes by now, because you'd have had to respond to NCs about the audit programme!
chris_gray1980
#16
HAHA yes learning new stuff but im ashamed of myself because this is stuff i should know...
I guess you could be right about the CB, im not sure.. but yes if there was an NC then changes would have been made.. by critical processors i assume he means high risk/impact.
i am also still trying to re-write ALL the procedures (re-jig or what ever is needed because they do not represent what we do now BUT its down to me even though is shouldnt be but i guess im stuck with that, i will have to sit and pester people to get things right but it has already taken MONTHS and got know where... ok feeling rather depressed now)
I need to back to my books i think and the planning will have to be done in my own time because i get bugger all time when im at work... in fact i am my own worse enemy because i FLIPPING HATE IT and i will try and avoid it but if it worked for me and the system i would be a lot more content and willing but.. some times i wish we would loose our certificate just to show top management what a bloody mess this system is because NO ONE listens to me.... but any way its Friday and i have 1 1/4hrs left and that's it im out of here to forget about it until Sunday when i will be dreading coming back for another horrid and frustrating week... how i wish i was a proper QA Manager...
Thanks again.. if you come across any literature that could help me PLEASE DO POST IT..
Chris
#17
Let me share something I learned while driving around metro Detroit back in the 90s...it is a key to success!
On AM radio, there used to be a show by Dr. Joy Brown. She's a clinical psychologist. People call in with all kinds of (bizarre) relationship questions (not the kind of thing I used to hear on BBC Radios 1-4!)
After a while you realize that she had approx 4 canned answers for all such callers. One of them was "If you want other people to stop doing something which annoys you, you have to do something different"!
What does this have to do with audits? Well, management don't take them 'seriously' - in many ways - lack of support for time, people, corrective actions. whatever. Audit process owners get frustrated. So what to do?
Do something different! If you don't involve management in planning the audits, start doing it! Stop focusing on ISO, focus on what keeps them awake at night or similar. Make them see you as doing things which affect them...
Try it - you might like it...:mg:
pkost
#18
you shouldn't be ashamed of yourself, you are working in an impossible situation. Top management is giving you no resource or authority.
Your situation is exactly why top management is so critical to the effective implementation of a quality management system
Additionally you have already said that this is the first quality job and that you came into it with no experience. To me it seems like you are eager to do the job right and are just hitting a brick wall through no fault of your own.
You are in the right place to get information and support!
#19
pkost - thanks, you've prompted a thought.
The existing auditor courses, really don't give any clue as to how an audit programme should be managed. Sure, they teach (basic skills) but certainly not how to do all the other things ISO 19011 talks to. No shame in attending class, therefore and not 'getting it'.
Bunny
#20
Well, my first thought is "Where is your support from top management?" You need them to set the stage to get all department managers to take responibility for their own procedures and to get you proper resources.
If you do not have that, I can suggest that you decrease the frequency audits. Why do you audit every procedure twice a year? You should only audit the critical activities that often. For instance, if the company is heavy into design, audit that twice a year and do everything else once a year.
Regarding the checklists. I never use a checklist for each procedure, I use one checklist based off the standards I audit. That checklist has all elements listed from ISO 9001, ISO 13485, FDA regs, etc. I then write a summary report from the checklist data, but it is not detailed because the details are in the checklist. The external auditors review the checklist and the summary reports.
I also use a top down approach and group similiar functions together. So if I audit the production department, I can tie together identification, inspection, handling, documentation control, training, and calibration. When I audit the testing department, I may or may not cover training and calibration - it depends on the circumstances.
Does that help?
C CMM Granite too hard General Measurement Device and Calibration Topics 4
G Too many customer complaints Customer Complaints 16
M Do I Expect Too Much of Job Candidates? Career and Occupation Discussions 33
M Informational From RAPS – Another Notified Body Bows Out Ahead of EU MDR: ‘Investment Too High’ Medical Device and FDA Regulations and Standards News 2
M Informational FDA Panel: Too early to pull textured breast implants over cancer risk, need more data Medical Device and FDA Regulations and Standards News 0
F Looking for a Japan MAH recommendation that is not too expensive Japan Medical Device Regulations 6
S FDA Inspections and Pest Control - Pallets too close to walls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
L Nonconformity's risk is too low, so don't report it? General Auditing Discussions 25
O Is the Quality Objective for Company-wide Training as >90% too high? Training - Internal, External, Online and Distance Learning 4
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
K Too Simple an Internal Audit Check Sheet? Internal Auditing 10
GStough Rejecting a Supplier's Corrective Action Plan When It's Too Weak Supplier Quality Assurance and other Supplier Issues 22
B Is the ISO 13485 auditor being too picky concerning CMDCAS? ISO 13485:2016 - Medical Device Quality Management Systems 5
J Sourcing a Sterile Product - Asking for supplier for too much regulatory stuff? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Reduced Device License Fee was rejected for being sent in too early Canada Medical Device Regulations 2
N Calibration Lab unable to issue Accredited Certificate when error is too high? General Measurement Device and Calibration Topics 3
H "Too little" variation in gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J ISO13485 File-Index getting too large Document Control Systems, Procedures, Forms and Templates 2
N Boss is too hard on me.... Career and Occupation Discussions 48
C How to Write Procedures without too many Details ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
Sidney Vianna The frequent flyers that flew too much... Unlimited AAirpass Coffee Break and Water Cooler Discussions 11
B Management Review Meetings too Long - How to Shorten and Improve Effectiveness Management Review Meetings and related Processes 7
B NAFTA Requirements - Finished Product or Materials/Parts from Suppliers, too? RoHS, REACH, ELV, IMDS and Restricted Substances 2
A When a Company is Too Big for Quality Service Industry Specific Topics 20
Q Document Control Procedure - Too much detail? Document Control Systems, Procedures, Forms and Templates 8
G Histogram Interpretation when a process is "running too high" or "running too low"? Quality Tools, Improvement and Analysis 4
somashekar Too much data, Too little analysis - Manual Stages Assembly Shop Data Collection Quality Tools, Improvement and Analysis 2
B Can the Variation on Data be too small in a Variables Data Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A Customer SQE - Within Specification but too much Variance Customer Complaints 7
A What to do when customer requirements are too much? Quality Manager and Management Related Issues 29
A Are Risk Analysis Studies required only for devices, or other processes too? ISO 13485:2016 - Medical Device Quality Management Systems 11
R MSDS Sheets for Products - How much is too much - Or is there ever too much? Occupational Health & Safety Management Standards 12
BradM Definitely too old to Trick or Treat Funny Stuff - Jokes and Humour 0
Jim Wynne Is this ISO 9001 Registration Scope Statement Too Vague? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Late CA (Corrective Action) excuse or I'm too important or no response Nonconformance and Corrective Action 19
4 Change Control Systems - How much is too much? Document Control Systems, Procedures, Forms and Templates 10
Q How much detail in DHR (Device History Record) is too much? US Food and Drug Administration (FDA) 3
J The Dude abides, and this weekend Hub ?Lebowski? fans will, too Coffee Break and Water Cooler Discussions 2
Q Issuance of Corrective Action - Too many related to safety ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Sidney Vianna Too many competing schemes for "approval of responsible recyclers"? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
R Audit N/C - Quality Policy too generic? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Jim Wynne Another way to tell that you've got too much money Coffee Break and Water Cooler Discussions 16
Randy I got a new ride too! 1990 'Vette Coffee Break and Water Cooler Discussions 50
J How to know how many procedures are too many? Document Control Systems, Procedures, Forms and Templates 7
P Improvement Problem - Too few data points and scope is wide Six Sigma 6
P Too Many purchasing/supplier procedures How do I fix them? Document Control Systems, Procedures, Forms and Templates 6
E How would you make an Improvement Plan work? Production is too busy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Claes Gefvenberg I suppose it was too good to last. Imported Legacy Blogs 10
