G
Does it matter if the measurement is wrong?
In my opinion ...
If the instrument is used to make a measurement that something or someone else relies on, it should be calibrated.
Let's say A performs an experiment and piblishes a report. B reads the report and wants to replicate the experiment, but gets results that are quite different. What are the possibilites?
Development is to turn research into marketable products. Products have attributes that must be defined and measured so that they can be manufactured repeatably. If development measurements are made using uncalibrated instruments, how can the design specifications be correct? If those are not correct then the manufacturing tooling and gaging will not be correct, which means the product will not be correct -- and the company has just wasted a whole lot of money.
From time to time I have heard people try to justify using uncalibrated instruments to set up new systems by saying that the final test is done with calibrated instruments so that will catch anything. Hmmm. That means you are catching a problem at the most expensive time, just before turnover to the customer, when the customer is probably watching the certification test, and now you have to rework the entire setup using calibrated tools anyway, and rework is a cost that can't be charged to the customer!
Anyway, I believe R&D tools & equipment are no different from any other. To quote a friend who is no longer here,
Also, clause 7.6 references ISO 10012:2003 which contains further requirements as well as guidance on measurements. While you could decide to exclude areas from the measurement management sytem, you have to determine the associated risks and decide what to do about them. From the beginning of section 4, General requirements:
The measurement management system consists of the control of designated measurement processes and metrological confirmation of measuring equipment (see Figure 2), and the necessary supporting processes.
The measurement processes within the measurement management system shall be controlled (see 7.2). All measuring equipment within the measurement management system shall be confirmed (see 7.1).
(BTW, this version replaces the old 10012-1 and 10012-2 standards.)
(Lots of people have said that this standard can be ignored because "it's just guidance". But how many "shall" items are there in those three paragraphs?)
In my opinion ...
- If B used calibrated instruments and A did not, then if B publishes and says A is mistaken it will cause greate embarassment (at least) to A. Even worse if B lists the instrument uncertainty and shows how much difference is outside that.
- If A used calibrated instruments and B did not, then if B publishes and says A is mistaken it will be B who gets embarassed.
- If neither A or B used calibrated instruments, nobody knows who is right or wrong. Then when C publishes yet another set of results, determined using calibrated instruments, then both A and B will be embarassed and half the people reading the reports will be confused.
- The best case is that A and B both use calibrated instruments. Any difference in their results can be evaluated, and any difference that is greater than the combined measurement uncertainty of the instruments can be targeted for further investigation.
- Does it matter if the result of the measurement is wrong?
- If it does matter, then calibrate the instrument.
- If it doesn't matter, then why are you (wasting your time by) making the measurement?
The organization shall specify the measurement processes and the measuring equipment that are subject to the provisions of this International Standard. When deciding the scope and extent of the measurement management system, the risks and consequences of failure to comply with metrological requirements shall be taken into account.
