Re: ARP9013 Compliance (Boeing based) and ARP9013/1 Lot Sampling Plan example Procedu
I can't send you the specs, but I can send you the abstracts.
You can purcahse these specs from SAE. BTW there are 5 different documents
ARP 9013 Abstract:
Abstract:
This SAE Aerospace Recommended Practice (ARP) establishes the general requirements when implementing any of the statistical product acceptance methods as defined in ARP9013/1, ARP9013/2, ARP9013/3, and ARP9013/4. This recommended practice also establishes the minimum content required to be covered in an organization's documented procedures that govern their application of statistical product acceptance methods. These general requirements and documented procedures apply the requirements of AS9100 plus requirements for retrievability, safety/critical characteristics, quality parameters, and that these parameters protect the customer. This recommended practice is to be used in conjunction with the variety of sampling strategies, statistical techniques, and process control methods of the ARP9013/1 through ARP9013/4 recommended practices as chosen by the organization.
ARP 9013/1 Abstract:
Abstract:
The purpose of this SAE Aerospace Recommended Practice (ARP) is to ensure conformance for each product characteristic being verified in a lot, without maintaining information from previous lots. ARP9013/1 specifies a product acceptance system for isolated lots. For example, isolated lot sampling avoids keeping track of the normal, tightened, and reduced levels of sampling formerly used in MIL-STD-105 and currently used in ANSI/ASQC Z1.4. Because those switching rules provided significant long-term protection for product quality, these isolated lot tables replace that protection in other ways.
ARP 9013/2 Abstract:
Abstract:
The purpose of ARP9013/2 is to ensure conformance for each product characteristic being verified in each lot in the series. ARP9013/2 document specifies a product acceptance system using either attribute or variable lot acceptance methods documented in ANSI/ASQC Z1.4, ANSI/ASQC Z1.9, and 'Zero Acceptance Number Sampling Plans' by Nicholas L. Squeglia.
ARP 9013/3 Abstract:
Abstract:
ARP9013/3 recommended practice specifies a product acceptance system using process control methods. Its purpose is to assure conformance for specified characteristics. Use of process control techniques for product acceptance requires maintaining process stability and capability. A stable and capable process is the best assurance of conforming hardware for the customer. There can be lower inspection costs associated with a process control acceptance approach.
ARP 9013/4 Abstract:
The purpose of ARP9013/4 is to ensure conformance for each product characteristic being verified under these methods. ARP9013/4 provides the requirements for continuous sampling, skip-lot sampling, and for statistical methods for product acceptance that do not derive from industry standard tables.
