Article 22 Procedure Pack Labelling
Hi, I'm new to the forum and hoping that we can share some knowledge of the requirements for procedure pack labels under Article 22.
I'm working with a company that buys CE Marked components (could be 40 per pack), combines the components into a pack and sterilises the pack. The majority of the packaging is removed (with the approval of the Legal Manufacturers) prior to sterilisation.
Up until now, we have transferred very little information from the primary packaging of the components onto the procedure pack label however we have recognised that we need to correct this. The contact details on our current label is limited to our details (procedure pack company).
What are the thoughts around the requirements for procedure pack labels?
Should we be including the name and address of the legal manufacturer on the procedure pack label? Considering that we could have up to 40 components, this will be quite a challenge to include them all.
Also what about the EC representative details for those components that are originating from outside the EU, should these details be included?
I guess if we were to take a risk based approach and ask what is the risk involved in not including the LM details, the risk is that the customer does not know who to contact in the case of a vigilance incident.
Is it justifiable that in the event of a vigilance incident, that the customer is able to contact us as the procedure pack company? We have processes set up for handling customer complaints and forwarding to the relevant Legal Manufacturers so there's no risk from that point of view.
I'd appreciate any feedback from people working in this area and see what their experience has been.
L_O_B
Hello Spikey,
I would really like to provide a more satisfying answer, but I think you have quite a problem there.
As described in Article 16(1,a) a natural or legal person shall assume the obligations incumbent on manufacturers, if it makes available on the market a device under its name, registered trade name or registered trade mark. Same applies for modifications of a device already placed on the market in such a way that compliance with applicable requirements may be affected
Even if you have an agreement with all manufacturers that you may remove the packaging use your sterilisation procedure and you have proof that this does not affect the devices' safety and performance, you are not allowed to remove the accompanying information.
The information was added by the manufacturer to comply with annex I chapter III. You must not omit any of the information previously provided by the manufacturer. This includes obviously the contact details of the manufacturers and ARs but also warnings, precautions and each UDI carrier. Otherwise you will be seen as the manufacturer.
Hi LOB, it’s really good to get your perspective on this. Many thanks for your response, however, I disagree on this. This is common practice within the EU and there are many companies performing these activities. I am aware of Article 16 and cannot agree with this interpretation.
Article 22 acknowledges that procedure packers can sterilize procedure packs – but based on your argument, would this not also be considered to be a modification of a device which could affect it’s compliance with requirements? If so, why is Article 22 specifically outlining it as an activity performed by procedure packers and does not require that the procedure packer must take on the responsibilities of a Legal Manufacture and CE mark the procedure pack as a device in its own right?
If the LM gives approval for the procedure packer to place the device in a pack with their CE mark displayed alongside their product name and if they agree that the packaging can be removed prior to sterilization then Article 16 does not apply to procedure packers.
In this case, the LM must be in agreement that these activities do not affect compliance with applicable requirements (otherwise they could not give approval), and therefore it is up to the LM to justify in their technical file that the devices supplied to procedure packers are in compliance with the applicable requirements – they can validate this by requesting copies of the procedure pack labeling to check what information has been brought onto the pack label or by auditing the Procedure packer, there are many ways to validate this, but ultimately it is up to the LM to justify this to their notified body IF they sign an Article 22 agreement and provide approval for the packaging to be removed.
The notified body for the sterilization of the procedure pack will want to see that the procedure packer have Article 22 agreement with the suppliers, they have approval to remove the packaging and that they have transferred any relevant information to the PP label. The process to determine the relevant information is what we are working through right now.
L_O_B
I was not trying to say, that you are not allowed to unpack the devices.
The (re-)sterilisation process has without a doubt the potential to affect the compliance of the devices. But as you mentioned it is also common practice. That is the reason why they added this option to article 22 and made the involvement of a notified body obligatory.
So far, this is fine for the sterilisation part.
Regarding the accompanying information, there are still issues. According to article 22 you must draw up a statement that you "supplied relevant information to users incorporating the information to be supplied by the manufacturers of the devices or other products".
You cannot omit information that was intended by the manufacturer for the user. This includes at least all information that is required by annex I 23.1-23.4. If you do this, the device is no longer in compliance with the regulation.
M Article 22 - Include statement in procedure pack? EU Medical Device Regulations 1
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
R How to draft a good First Article Inspection Procedure (when AS9100 is overkill) APQP and PPAP 6
I What do you have to put in place for Sterile Procedure Packs? MDD Article 12 ISO 13485:2016 - Medical Device Quality Management Systems 1
B Article 12 MDD... Procedure packs! Requirements to Repack already CE Marked Products EU Medical Device Regulations 4
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
O First Article Inspection notification procedure Supplier Quality Assurance and other Supplier Issues 3
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
S Summary of safety and clinical performance and Article 120(3) of the MDR EU Medical Device Regulations 4
E Article 17 MDR - (Re-)Processing EU Medical Device Regulations 0
H Article 22 MDR System EU Medical Device Regulations 16
F MDR – Article 120 – Transitional provisions EU Medical Device Regulations 8
H MDR Article 13(c) EU Medical Device Regulations 6
Ed Panek Is anyone familiar with Article 60 Certificate of Free Sale EU Medical Device Regulations 6
Ed Panek Interesting Article Coffee Break and Water Cooler Discussions 1
A Medical First Article - Can it be a Delta? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Addition of IFU on local language by distributor - Article 16? EU Medical Device Regulations 1
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
M Examples of Combination Products - MDR Article 1 (8) and MDR Article 1(9) Medical Device and FDA Regulations and Standards News 3
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
M Vigilance - incident found in an article EU Medical Device Regulations 3
dgrainger Informational MHRA guidance on CE UKNI - Article 5.5 - 2021-02 EU Medical Device Regulations 0
U MDD Article 12/ MDr Article 22 interpretation EU Medical Device Regulations 2
M MDR Article 22 Interpretation EU Medical Device Regulations 3
L EU MDR Article 86 PSUR EU Medical Device Regulations 1
K Article 18: Implant Card and information to be communicated. EU Medical Device Regulations 5
R Requirements for MDR Article 22 Systems EU Medical Device Regulations 1
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
S Translational Requirements - Article 120 EU Medical Device Regulations 5
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
K Expected lifetime of the device-Article 18 EU Medical Device Regulations 4
R Clinical evaluation without clinical data - MDR Article 61(10) EU Medical Device Regulations 9
A MDR Article 22 applicability - Legal manufacturer EU Medical Device Regulations 8
T Implant Card - Article 18.1(a) and MDCG 2019-8 clarification EU Medical Device Regulations 3
P Economic operator responsibilities - when the Importer is also Distributor - Article 13 EU Medical Device Regulations 1
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
K Article 18 in the Implant Card - Expected lifetime of the device EU Medical Device Regulations 3
S Article 61 - MDR Clinical Investigation Requirement EU Medical Device Regulations 9
C Article 16 MDR - Medicine packaged together with Medical Device EU Medical Device Regulations 0
F MDR system/procedurepack (article 22) with device acc. to MDD and MDR CE Marking (Conformité Européene) / CB Scheme 2
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
N EUDAMED postponement and compliance with Article 120 (3) MDR for Legacy Devices EU Medical Device Regulations 10
T EU MDR Article 61- Clinical Evaluation EU Medical Device Regulations 2
