AS 9100 Rev C AATT Exam Retake Guidance
azlife4me
#61
Kindly add your points to those tips and if you feel that some points can be deleted,please let me know.Please do this after the test when memory is hot.
One thing to remember:hard work cannot be repalced by my tips.So prepare well.
Wish you good luck.
Thank you Joy!! :thanks:
#63
I was little hesitant to publish my tips as few may look foolish but I received many requests in recent months and many friends acknowledged that it helped them.I would request my friends to add more points if you find any more useful point.
1.Try to print the IAQG on-line training module. You can do this by using screen shot. After printing study them carefully and remember your answers. You may get 3-4 questions from this in your final exam.
2.Remember that the watch in the computer can be stopped. There is a button on top right hand corner. Ask the proctor before the test is started. Ask the guy,” In case I want to go to wash room, do I loose time?”.Also ask how many times the watch can be stopped. This is very important as you can stop the watch and go outside to think about the question. Time is individual’s. Use this privilege.
3.Do not select any answer in knowledge portion without 100% matching with the standard (AS9100 Rev.C).Do not use your memory as in many answers, you will find the mismatch of one word. You can score 100% if you select the answer only after practical matching through observation.
4.Keep a index of the AS9100 Rev.C for quick reference of the clause. This will save your time to find the clause.
5.You may consider to prepare one index for AS9101D.This would save time.
6.For class room exercise, you have to prepare your documents for each exercise and put them in envelope. This will be used for your interview. So, when you are making your documents, record what you are writing in a notebook. Other idea is to use the computer camera to record it. This will help you to prepare well for the interview.
7.There are some questions with negative marking, be careful about those.
8.Do not struggle with difficult questions, record the number and go forward. Later you come back to answer the recorded one.
9.Don’ keep any audit or consultancy work in the week prior to the course and test date. Use this time for serious reading.One week Off-work will give you work for many months.
10.Go through the FAQ portion for AS9101 Rev D, published by IAQG.
Disclaimer:tips are not alternative of hard work and publisher will not take any responsibility/credit of user's result.
L
LawrenceMD
#64
Joy could you please pass on your tips to my mail box. I will be going through the maze in September, so I have time prepare a bit more.
#65
Hello Lawrence,
I have posted it for all.Just look at the last post by me (before yours)
My prayer for your success.
K
kiwisfly
#66
Hello Lawrence,
Reading through this thread I thought it was getting close to breaching several aspects of the AATT material designed to make the examinations fair for all those who take them. Unfortunately, now you have published your list of recommendations, you have certainly overstepped the mark. I am a contractor for Plexus so declare up front that this is the case.
If you print off the on-line material you will be in breach of copyright rules. The IT system associated with the Plexus platform may be able to identify you so I suggest you don't do it, particularly the practise questions.
Secondly, I proctored an exam in Asia where a candidate contiually stopped the clock between answering questions. He remained in the examination room far longer than anyone else and was warned by both the proctor and myself that he was breaking the examination rules explained to him at the start of the exam. Stopping the clock is only allowed when taking a short bathroom break, not several times whilst you think about your answers, this is cheating. The candidate I reported subsequently failed (it was a resit), I suspect his exam was not even marked.
My recommendation to you is to obey the rules explained to you by the proctor, ignore any of Joy's recommendations that will put your exam result in jeopardy. Retakes are expensive and it is much better to pass the exam without resorting to some of the methods noted in his list.
Regards,
#67
Hello friend,
You missed my good points as my tips included the requirement of hard works also.I feel that is most important.Some tips are only to manage the test well.Is the system of test so weakly designed that participants can pass by using those tips which you mentioned?:)If so,there must be worries .
I am not an expert of copyright rules but I understand that once the participant is paying for the course and used by self for the benefit of self,would it violate copyright acts?If it violates,please don't do this.You can still memorise.Don't ask how to do it but writing in your note book also may be copyright violation.
Why don't you ask Plexus to strengthen the system?You have mentioned one example of Asia and that may be a case of malpractice but there are participants who are appearing in test after a long gap and due to tension they feel so nervous that they fail to select the correct answer.If they take few breaks to cool down,what is wrong in that?
Please note that if you are well prepared (hard work),you would never need to stop the watch and the test will be very smooth.I had to stop once in three tests when it was really needed.
I am little worried if giving idea of copyright violation is also punishable:tg:
K
kiwisfly
#68
Joy,
I think you have good reason to be concerned. I recommend you take your list off this site as soon as possible. I'm surprised other Covers had not recommended you do this already.
Regards,
dsanabria
#69
Regards,
Please do not use the Cove to harass or threatened users. You post does not help members gain knowledge, experience or helping people taking exam.
Yes, you could stop the clock as often as you wish.... not in the rules not to.
Yes, Joy printed common sense ideas that we all have agree, enjoyed and support.
Please friend... do not use this forum for vague legalism and to scare other users in using standard everyday day information in taking test:mad:
dsanabria
#70
Joy,
Regards,
Joy;
You have done nothing wrong...
Thanks for helping other people... Keep up the good works and hope that the cove does not begins to remove everyday common sense approach in taking test - in colleges, schools or professional environment.
Nicole Desouza AS 9100 Rev D Gap Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Audit Checklist for AS 9100 Rev C wanted Quality Assurance and Compliance Software Tools and Solutions 3
B Service Provider in NC Programing and Design - Exclusion clause in AS 9100 Rev C Quality Manager and Management Related Issues 5
M AS 9100 Transition Checklist to ensure all areas of the new REV C are covered AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS-9100 rev C Clause 4.2.4 - Supplier Records Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T AS 9100 Rev C Clause 7.4.2 - Supplier Nonconforming Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS 9100 Rev C - Risk Management Procedure and Template Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Phase 2 Revision to AS 9100 Rev C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D AS 9100 Rev C "10 Minutes" Presentation to Non-Users needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
L AS 9100 Rev.C guidance for the final exam Training - Internal, External, Online and Distance Learning 2
L Explanation of the note attached to 7.1(a) in AS 9100 Rev.C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L AS 9100 D consultant in Delhi, India AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Prashant G MSA Study - AS 9100 and and our customer want us to do MSA study for their parts dimension Reliability Analysis - Predictions, Testing and Standards 4
M AS 9100 - Requirement to become Certification Body (CB) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q AS 9100 C and D Purchasing requirements difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Marc AS/EN/JISQ 9100:2016 IAQG Sanctioned Aerospace Auditor Training Available (Nov 2016) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Marc IAQG 9100:2016 - QMS Requirements for Aviation, Space and Defense AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A AS 9100 - Risk Management Procedure and Flow Chart examples AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AATT 9101E/9101:2014 - Suspension of all AATT 9100,9110,9120 classes and examinations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A AS 9100 7.5.1 g Accountability for all parts - Implementation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S 'Over Compliance' Error message in Wavetek 9100 General Measurement Device and Calibration Topics 10
M AS 9100 4.2.4 Process for making changes to records is not fully effective Quality Manager and Management Related Issues 4
K Guidance on AS 9100 4.2.3 Control of External Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B How to apply Clause 8.2.4 from BS En 9100 & ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ISO 9001 vs. AS 9100 vs. Malcolm Baldrige National Quality Award AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Explanation of AS/EN 9100 Clause 7.4.1 Special Process Sources AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B AS 9100 Revision C Transition and Recertification Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Douglas E. Purdy Inspection & Test Laboratory Accreditation Requirements for AS 9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Definition Design Responsible - Good Definition in the context of AS 9100 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
S Differences between the SAE AS9100C and BS EN AS 9100:2009 versions of the standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J The Hierarchy regarding AS 9100 C and TS 16949 - is there one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Best Training Provider for AS 9100 C Lead Auditor Training Professional Certifications and Degrees 6
Project Man What is the most current ISO 9000 standard? I heard there is an ISO 9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Survey or Statistics on the use of the AS 9100 Standard Worldwide AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A ISO 9001 and EN 9100 Training in Europe Training - Internal, External, Online and Distance Learning 2
L AS9100 in Japan convert from JISQ 9100 to AS9100 consultant needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Your views and comments on these AS 9100 Related Audit Non Conformities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS 9100 Related Audit Non Conformities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Y What is the first step in implementing AS 9100 for a 4 person shop? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L Employee Training for the ISO 9001 and AS 9100 Standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Records of New Processes for AS9100 - AS 9100 certification audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Looking To Find AS 9100 Audit Day Experience AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Customer Authorization for Use As Is & Repair - AS 9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M ISO 9001 and AS 9100 Registrations - AS9100 applicability to a software company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A EN/AS 9100 - Subcontractor audit and auditor requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B As 9100 Imported Legacy Blogs 0
B AS 9100 Follow Up Scheduled Imported Legacy Blogs 0
A Defining your Scope of Approval - AS 9100 7.4.1(a) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
