AS9100 - 7.4.2d Purchasing - Specification revision for raw material needed?
L
littleRoot
I have an upcoming AS9100 and I seen that POs going out to raw material vendors did not state the specification revision, only the spec. Then the Raw Material Test Report we receive back from vendor will typically state the current revision to the spec we called out on our PO.
After seeing this, I checked to see if we had the current spec revision and we did not. When I inquired, I received comments like 'we thought spec and revision status only apply to processes so we don't state revs on raw material POs and we cant confirm if vendors have current spec'.
My question is does 7.4.2d apply to raw material also? Currently we only control spec revisions for outside processes like anodizing, plating, etc and check for the current rev when the certs come back.
If someone could please assist me, I'd appreciate it!
Pjservan
Just like anything we do in Quality the answer is, it depends. I assume the raw material specs you refer to are industry wide type specs. Since this a AS audit you can assess the risk of not having the spec revision called out in your POs. Take into account the type of changes that have occur in the specs in the past and how these affected your raw materials and how it affected your product plus your ability to meet customer requirements.
somashekar
Is that the current revision of the spec sheet you see or the current revision of the material spec ?
Typically a raw material spec (Ex: ABS 300 natural from ABS company) will remain unchanged, while the spec sheet (TDS) of this material can be a current revision released by the company, to which the test report aligns.
This does not mean that the ABS 300 natural has changed properties. You need to review the TDS, both current and the obsolete to make sure your material is what you wanted.
A lot of clarity will come when you also look into ordering information / code, which will remain unchanged for a material of a specific grade, and specific packaging, making it unique to what you want to order.
S AS9100 7.4 "Purchasing of a Service" - Stress and Design Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Satisfying AS9100 7.4.2 Purchasing Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Exclusion to Purchasing - AS9100 Clauses 7.4.1 & 7.4.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9100 Tooling Purchasing Process Manufacturing and Related Processes 5
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
E Compliance with AS9100 Rev C Risk Management Purchasing Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Purchase Order (PO) Quality Clauses - AS9100 7.4.2 Purchasing Information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 45
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
