AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items
CanadianQA
Hi All,
I have a question about Key Characteristics / Critical Items. How would these typically be identified on a drawing? A symbol of some sort? Any measurement within a specific tolerance (+/- 0.0005")?
Also, what constitutes Key Characteristics / Critical Items? I know how the terms are defined in the standard, however the way I'm understanding them, pretty much any dimension that would affect fit form or function would be considered key or critical.
Consider this example. A 4" X 4"x 4" square piece of 6061T6 aluminum with edges radiused to .125" on all corners, with a 1" hole drilled directly in the middle of the block for a bolt to go through. The part fits into a mating cavity and is retained by the bolt. All dimensions have a tolerance of +/- .005". Would all dimensions for this block be considered key / critical as any outside of the tolerance affect fit form or function? I appreciate any advice.
Sidney Vianna
Post Responsibly
Re: AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical It
Most OEM's have their published way of documenting it. For example from this Boeing document:
Dimensions are just one of many parameters that could be deemed KC/CSI. Normally, when you have a dimension identified as KC, one must record the actual dimension, instead of just checking it is within tolerances because variation management is associated with the management of these critical items. The IAQG Supply Chain Management Handbook has material that might assist you and you should also familiarize yourself with the IAQG AS9103 document.
CanadianQA
Great, thanks so much Sidney! I'll have a read of the AS9103 and the Boeing document.
D Design and Development Procedure example and Template wanted - AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Auditing ISO9001/AS9100 7.3 Design and Development Quality System Effectiveness Manufacturing and Related Processes 12
M Mapping Processes to 7.3 Development and Design - AS9100 Process Maps, Process Mapping and Turtle Diagrams 3
W AS9100 7.3.1 Design and Development Planning template or form wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A From ISO9001 to AS9100 Section 7.3 - Presentation to our Development and Design group AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Software to help meet ISO & AS9100 Design & Development Rqmts Design and Development of Products and Processes 2
K Seeking AS9100 B 7.3 Design and Development Procedure Examples Design and Development of Products and Processes 3
C Advice on becoming a AS9100 Auditor - Need to audit organizations that are Design Responsible AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C AS9100 7.3 - Prototype Design Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B AS9100 - Exclusion for 7.3 Design and Developement as we do not design AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Plastic Injection Moulder - Design exemption from AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
S AS9100 7.4 "Purchasing of a Service" - Stress and Design Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T AS9100 - Upgrade to Rev C - Design & Manufacturing Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S New Requirements for Design Control in AS9100 C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Clause 7.3.3 - Design and Developement Requirements d and e AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 Design - Machine shop offering Drafting Services? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G AS9100 Design Contract Issue - Contractor without AS9100 Quality System AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Sidney Vianna Looking for input on the design/syllabus of a 2-day AS9100 Transition Course AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Section Applicability for a Design Center's Technical Publications Design and Development of Products and Processes 2
I AS9100 - Would like to know if I can exclude the design Design and Development of Products and Processes 6
H Excluding Design - Would like to go straight to AS9100 for the Aerospace Industry Design and Development of Products and Processes 6
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
