AS9100 and related AS9102 Supplier First Article Requirements
turnit
We currently utilize multiple plating sources for outside processing of the same particular part number.. If we do a AS9102 First Article for Supplier A than do one for Supplier B are we required to perform again if we return to supplier A?
dsanabria
Re: AS9100 and related AS9102 first article req.
If you meet the requirements of AS9102 - Paragraph 5.3 (then you don't).
"The Organization shall perform a full FAI, or a partial FAI for affected characteristics, when any of the following events occurs
1. A change in the design affecting fit, form or function of the part.
2. A change in manufacturing source(s), process(es), inspection method(s), location of manufacture, tooling or materials, that can potentially affect fit, form or function.
3. A change in numerical control program or translation to another media that can potentially affect fit, form or function.
4. A natural or man-made event, which may adversely affect the manufacturing process.
5. A lapse in production for two years or as specified by the Customer.
turnit
I am aware of the 5.3.2 statement. My intent was to solict opinions on whether the scenario I outlined would satisfy the intent of the statement or not
Thanks to any who respond!
dsanabria
1.2 Purpose
The purpose of the First Article Inspection is to give objective evidence that all engineering, design and specification requirements are correctly understood, accounted for, verified, and recorded. The purpose of this standard is to provide a consistent documentation requirement for aerospace components FAI.
Remember that FAIR are used to verify that your process meets customer requirements.You do not have control over the plating processes so if your process meets the requirements of 5.3.2 - then your are good to go.
Cari Spears
..."The Organization shall perform a full FAI, or a partial FAI for affected characteristics, when any of the following events occurs
Changing plating sources is a change in a manufacturing source. Any customer I've done FAIs for would have me submit a delta FAI for changing a plating source. I've never gone back and forth - perhaps if Supplier A hasn't had a lapse of 2 years since they plated them for you, you may not have to resubmit - but the point of the FAI is to represent the current process, including suppliers.
surfguy72
Just wanted to say thanks for this dicussion. It helped me out some, as myself a non-engineer seems to want AS9102's alot more often than the engineers I work with do.
I've been met with the opposition that anything that can be inspected from a print, doesn't require an AS9102 (talking about changes, not the first time using a supplier.) So in the above case, their thinking would be no, that you can inspect if plating has been done correctly (to some extent) and therefore wouldn't require an AS9102. If it were me, I would. But thats why I posted here, is because I don't know if I'm correct.
Anyways, thanks to the poster!:D
W Checklist for AS9100 Clause 7.2.2 Review Of Requirememts Related to Product AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
E AS9100 7.2.2 Review of Requirements Related to the Product AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
B Containment Actions for NCRs (AS9100 C) that are not Product related AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
O Clause Interpretations related to AS9100 Implementation AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
L Outsourcing Special Processes such as Plating, Painting, NDT as related to AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
D AS9100 & Related Aerospace Standards - List AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 37
Marc Available AS9100 and Aerospace related Consultants Paid Consulting, Training and Services 2
Sidney Vianna AS9100 related documents AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 10
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
M Ethics and Legality AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 25
classical_quality AS9100 Surveillance Audit - advice on drafting strong responses AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
L AS9100 - Infrastructure or Product? Inflight internet connectivity network AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
T AS9100 - Changing PEARs target AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 41
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
G AS9100-8.1.2 Configuration Management AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
R AS9100 REV D gap analysis matrix AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
E Recommendations for CBs south of England AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
E AS9100 installtion procedure AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 16
L AS9100 and Agile development processes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
T QMS Training for my organization - IATF16949 and also AS9100 or 9145 Manufacturing and Related Processes 2
W Tying the need for Demand Planning to a section of AS9100/9110 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
