AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict
WCHorn
Rubber, Too Glamorous?
Per AS9100C 8.2.4, ?When the organization uses sampling inspection as a means of product acceptance, the sampling plan shall be justified on the basis of recognized statistical principles and appropriate for use (i.e., matching the sampling plan to the criticality of the product and to process capability).?
Some SAE parts standards and material specifications used to call out MIL-STD-105, 1.5AQL, Level II, Normal sampling for acceptance. They adopted ANSI ASQ 1.4Z as its replacement. All?s well and good up to there. The groups that controlled the standards and specs then changed them expediently by just continuing to use the sample size from that standard but change the acceptance number (C) to zero. This is by far a more stringent requirement and I think not well thought out.
I have argued that that change created a conflict with AS9100C because it?s not justified on the basis of recognized statistical principles. For example, sometimes a 2.5 AQL will be more stringent than a 1.5 AQL because the sample size will be bigger.
What do you think? Conforms to AS9100C, or not?
Michael_M
Re: AS9100 and Sampling - ANSI ASQ 1.4Z C=0 Conflict
As I understand it, when using sample inspection C=0 means that if you find a single defect then you must test 100% for that defect.
For example: An outside diameter of a shaft 1.000 +/-.005. As you are measuring your sample, if any one part within the sample measures (for example) .994 then the 1.000 diameter must be measured 100% on all parts before acceptance.
If I am not correct on this, please enlighten me.
WCHorn
You are correct; I don't see how that's germane to my question, though.
P
PeterWang
Hi WCHorn , I think you are right.In Automotive industry i meet the same problem.Actualy, i think the C=0 sampling plan is an idiomatic usage comes from OEM customer.The right C=0 plan should be MIL-STD-1916
Mandating c=0 plans in general is not statistically rational
Some c=0 plans are statistically valid
Many are not. What you describe is not rational or statistically justifiable.
They certainly do not stem from 'recognized statistical principles'. They are mostly an ill-conceived slogan that panders to a well intentioned yet uninformed belief concerning the existance of a defect in a sample and the defect rate in the lot. This makes them popular and 'politically correct'.
Does it conform to AS? depends on your quality rep and auditor...and how much they buy into the mythology.
a fun read on the subject:
"Acceptance Sampling? The Enterprise Strikes Back! AS9100 c =0 Plans; when Slogans Supplant Science" by Joe Maciulla, Quality Engineering, Vol. 18, No. 2. (June 2006), pp. 237-266
Michael_M
Sorry, I should have put in a :topic:or said something to the fact that I am asking an additional question. When I read your post, I must have mis-read or mis-understood. I thought you were asking something different and then I started questioning my own mind.
danielleecm
hi, not sure if i am right here. AS9100 is probably a guide on the sampling requirements and its quite up to the QA in question to determine the criticality of the product inspected and its conformance to customer requirements.
Likewise, if the parts inspected is critical to the customer in terms of performance, C=0 should be reasonable.
By the way, why change from MIL-STD 105 1.5AQL to ANSI ASQ 1.4Z ? Can advise?
T Acceptable AS9100 Receiving Inspection Sampling Plan - ANSI/ASQCZ1.4 vs. Mil-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S AS9100 Sampling Plan Requirements - 8.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
B AS9100 Process Sampling Plan Basics and Requirements Document Control Systems, Procedures, Forms and Templates 3
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Reduced Sampling based on Process Capability (AS9100 Standard) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L Sampling Evidence requirements - Pursuing AS9100 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 33
V Can give me the sampling plan for Receiving and Final inspection - AS9100? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Ethics and Legality AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
classical_quality AS9100 Surveillance Audit - advice on drafting strong responses AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L AS9100 - Infrastructure or Product? Inflight internet connectivity network AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100 - Changing PEARs target AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 41
