AS9100 C - 7.5.1.3 - How do you handle Production Equipment Maintenance?
Jon123
Hello All,
Im very new to the cove, but I have allready learned alot just reading through old posts. Lots of great information on here... so for that thank you.
As to my question, I am new to AS9100, and I have been put in a position where i need to learn fast. I work for a small AS9100 Certified manufacturing company who produces parts for Aerospace and defense. I was issued a Corrective Action from a nonconformance found in an internal audit, concerning Maintenance sheets on machines not being filled out. The quality manager who issued the CA says it doesnt comply with 7.5.1.3 of the standard "control of production equiptment, tools and software programs" The problem here is that the maintenance logs are getting properly filled out, but when nobody runs a certian machine durring that day there is a blank spot on the sheet.
My problem is that our company's procedure manual doesnt say anything about daily machine maintenance.
So what should I do?
Do other machine shops have dialy maintenance sheets?( if so how are they set up?)
Do I add a procedure?
Any help would be greatly appreciated. Thank You
Jason PCSwitches
Re: 7.5.1.3 AS9100 C. ?? How do others handle production Equpt. Maintance.
Hello All,
I would start with reviewing how the organization "defines" this in your procedures. How it's defined is up to the organization.
At the same time where does it say in your procedures that maintenance will be completed daily & what was the justification (evidence) for the NC? A statement that it doesn't comply isn't enough to justify an NC, they must provide some justification of why it is an NC. Is it procedure that ALL equipment have daily maintenance & it is to be recorded?
It should be a simple matter to resolve. You may want to add something in the procedures that addresses when & how equipment will be maintained, referencing machinery not utilized.
You can also state that maintenance is conducted prior to and after use of equipment & then stretch-out the recording aspect, i.e. weekly, monthly, quarterly.
Jon123
Thanks for you imput Jason PCSwitches, So in order to be within the guidelines of the AS9100 REV C standard, can I just write up a statment in the procedures book that defines our Maintenance procedure as a weekly routine with a sign off?
Jason PCSwitches
All the standard requires is that it is defined. Define it however you want, but don't forget to take into account any recommended maintenance practices outlined in equipment manuals. This is not usually a big deal but if you have sensitive equipment it may require more attention.
You also don't need to be time specific (weekly) if it could cause problems. You can state that departments will outline equipment maintenance criteria & have a maintenance sheet for each piece of equipment listing the frequency.
Golfman25
Re: AS9100 C - 7.5.1.3 - How do you handle Production Equipt. Maintenance
I assume your procedure is compliant. Sounds like the auditor might be questioning the execution of the procedure. My guess is your procedure is silent on filling out the logs when nobody uses the machine. The question I would ask is how or why should a log be filled out if the machine is not used? What is the point? Is there a way to prove that that machine wasn't used? Good luck.
Ninja
Looking for Reality
Good stuff so far...
I would simply add that a positive record is much easier to show during an audit than an absence of record. You might consider adding to your procedure the specific statement that "machine maintenance is not required if the machine is not used more than X in the time frame Y."
Now the auditor would see a verifiable record that you are indeed following procedure and that the procedure anticipated such an occurence.
Proof of non-use or extent of use could be as easy as an appropriately placed hour counter or stroke counter (depending of course on the type of machine).
:2cents:
Jon123
Thank you all for the help, I am going to adjust the companys procedure to a just a satement that covers daily machine checks and machines not in use, but with no required sign-off. And just a weekly sign off by machine operator/maintenance people. Based on what im hearing that might be enough to clean this up.
Something to keep in mind is that neither 7.5.1.3 or 6.3 require records of maintenance.
It is required if you say you will, but it is not part of the standard.
I'm not advocating that companies should not keep maintenance records, especially for expensive or sensitive equipment. You are free to do so if you want, and indeed, many companies feel that is the best way to run a company. But it is your choice, not something mandated by the standard.
Figure out how you want to handle it, and write the procedure accordingly.
V
ValleyGirl
We've run across a problem at our shop. Machinery Maintenance. All operators are supposed to take care of their machine (lubing etc) and then mark of a check sheet to show that it has been performed. Lately, we see that half the machines do not appear to be maintained because the sheet is not checked off. Operators say that they have performed the maintenance but forgot to check off the sheet. There is also a problem with machines that are not used often or used by more than one operator. Our Production Manager thinks that the there should be a dedicated Maintenance person that is responsible for all the machinery. We are a small shop and do not have the resources to hire someone for this position. Also, this would require the maintenance person to interrupt the operator when they need to perform the maintenance on a machine.
I suggested a different approach, I took our equipment list and assigned all of the machines to different operators, this insures that the machines that are used infrequently or by different operators are also covered. The production Manager is certain this system will not work.
How is machiney maintenace handled at your company? How can I get the operators to perform ther maintenace and complete the paperwork to show they have performed the maintenance?
dsanabria
The best idea is to talk the the operators / machinist how they could demonstrate compliance to the requirements of the standards.
They will come up with log books, magnetic stickers, calendar with initials when items were done, log book, pictures of what was done and dates next to it, electronic log book, assignment of duties to an individual...:notme:
Hope this helps!
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
A How does your registrar handle 2 certificates, one for AS9100 and one for ISO9001? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 45
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
