AS9100 Calibration Register
bguarino
Our company is ISO9001 and is moving towards AS9100 compliance. Our current system for production equipment that can inspect, measure, or test production materials is to identify its status with a unique number and a calibration label. This equipment is then tracked and recalled thru a calibration database.
Equipment (that can inspect, measure test) that is not used on production materials is just tagged with an "Engineering Use Only" label. No unique number. Not tracked in the database.
As we move to AS9100 our QC Manager is stating that all equipment needs to be numbered and tracked in the calibration database regardless of where it is used. They have issued a corrective action to the entire site to do an inventory of all equipment (thousands of pieces) to update the database and label everything.
However, AS9100 states "When measurement traceability is a requirement, or is considered by the organization to be an essential part of providing confidence in the validity of measurement results, measuring equipment shall be: " And then goes on to list A, B, & C requirements.
If measurement traceability is not a requirement for an engineering lab, then all the requirements that follow this statement would not apply?
Mike S.
Happy to be Alive
A properly issued CA in this case should clearly state the requirement that is not being followed. What are they saying is wrong about your current practice?
If they are saying Management has determined that the measurements made in the Eng lab require the added confidence provided by calibrating those instruments, then it makes sense to proceed down that path.
But if they are only doing it because of some perceived need in AS9100 they may be misunderstanding the requirements. The clause you quoted is ISO9001.
John Predmore
The first sentence under AS9100 7.1.5.2 contains a qualifying clause, "When measurement traceability is a requirement...". The sentence after a,b,c contains a qualifying clause, "for ... measuring equipment requiring calibration or verification." The third sentence states, ""The organization shall maintain a register of the monitoring and measuring equipment.", with no qualifying clause. Taken literally, the third sentence says anything that is measuring equipment must be listed in the register. I can see your interpretation, as well, that the qualifying clause in the first sentence applies to every sentence in the section . From a quality assurance perspective, it is probably safer to list all equipment in the register, because sometimes gauges and portable tools move around without the quality department's knowledge, and then you would know where the device came from.
Mike S.
Happy to be Alive
Going further the entire clause is:
The organization shall maintain a register of the monitoring and measuring equipment. The register shall include
the equipment type, unique identification, location, and the calibration or verification method, frequency, and
acceptance criteria.
How could you list a "calibration or verification method, frequency, and acceptance criteria" if it is not to be calibrated or verified? You can't. This is why I believe tools not needing calibration do not need to be in the register. But I agree the clarity is lacking from AS writers. I have never had that interpretation challenged. :cfingers
It would be interesting to see of 3rd party auditors like Randy would write a NC in that case.
dwperron
The interpretation I have always seen used is based on the first sentence: "When measurement traceability is a requirement, or is considered by the organization to be an essential part of providing confidence in the validity of measurement results, measuring equipment shall be:....."
There is a differentiation made between equipment that requires calibration and equipment that does not.
The organization shall determine which is which, and establish a recall system.
A register shall be maintained of the calibrated equipment. This is for calibrated equipment, as the elements required in the register include "calibration or verification method, frequency, and acceptance criteria" - things that do not apply to uncalibrated equipment.
There is no AS9100D requirement for the register to contain all measuring and test equipment, but some companies force this upon their calibration organization as an asset management function. That should not end up as an AS9100D CAR, but it could be a finding if your command media requires that all T&ME be recorded in your calibration register and you don't.
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100/AS1180-1 - Handling of Equipment and Calibration Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
R AS9100 Calibration Requirements General Measurement Device and Calibration Topics 4
D Calibration Requirements for AS9100 Rev C Calibration Frequency (Interval) 5
E AS9100 Equipment Calibration Recall Methods and Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E AS9100 Utilizing Calibration Equipment during Processing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Does each shot peening timer require calibration - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Calibration of Pin Gages - AS9100 Calibration Requirements General Measurement Device and Calibration Topics 23
H Employee owned gages not entered in calibration system - AS9100 Clause 7.6 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9120 to AS9100 due to value added activities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 45
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
