AS9100 Clause 7.1.4 Control of Work Transfers clarification
G
GAF_QM
Regarding AS9100C, 7.1.4 Control of Work Transfers - The organization shall establish, implement and maintain a process to plan and control the temporary or permanent transfer of work (e.g., from one organization facility to another, from the organization to a supplier, from one supplier to another supplier) and to verify the conformity of the work to requirements.
I am addressing this clause under my purchasing/procurement procedure; however, I have a question: Does the work transfer have to be a lateral move; in other words, we are AS9100 certified. Would the supplier we use also have to be AS9100 certified? Ultimately, we are responsible for the quality of the work. I don't know if the Rev C standard anticipates this or not. Any opinions on this? Thanks.
F
Frank T.
IMHO, the supplier you chose to transfer the work to does not have to be registered (certified) to AS9100, as you control the supplier per section 7.4.
This link from the SCMH, found on the IAQG website, might be of some help as well.
:topic:, welcome to the cove. :bigwave:
Sidney Vianna
Post Responsibly
The short answer is no. You can use the information contained in this ISO Guidance on outsourced process page. Replace ISO 9001:2008 with AS9100 and the text still applies.
The organization has to demonstrate that it exercises sufficient control to ensure that this process is performed according to the relevant requirements of ISO 9001:2008, and any other requirements of the organization’s quality management system. The nature of this control will depend on the importance of the outsourced process, the risk involved, and the competence of the supplier to meet the process requirements. Based on the nature of the control, it should consider the processes referred to quality management system for management activities, provision of resources, product realization and measurement, analysis and improvement. The outsourced organization does not necessarily have to have a certified Quality Management System, but it has to demonstrate the capability of the previously mentioned processes.
G
GAF_QM
Thanks for the feedback. Just thinking out loud: The Control of Work Transfers clause was probably introduced because the Purchasing section did not adequately cover every aspect of work transfer (outsourcing). In certain cases, the purchasing department would not be involved; therefore, the requirements of the purchasing section would not be applicable. I would see this as a loophole.
This would not be the case with my company, so this section 7.1.4 deserves a mention, but not a lot of detail because the Purchasing section of the AS9100 standard adequately deals with the controls and requirements of any outsourcing we would do.
Am I on the right track? Your thoughts?
howste
Thaumaturge
I can't speak for the authors of the standard as to why it's there, but I believe that if the requirements of Planning of Product Realization (7.1), Risk Management (7.1.2), and Production Process Verification (7.5.1.1) are met, then 7.1.4 should already be taken care of. I think you're still not grasping the full scope of this clause though, because this could apply even if suppliers or outsourced processes aren't involved. Some of the biggest problems I've seen have occurred when work was transferred within the organization. The overall intent of this clause is that when work is moved anywhere within the organization's control it must be planned and executed to minimize risk.
dsanabria
..and in addition..
When writing procedure, please considered the inevitable...
Yes, What if something happens to your company (tornadoes, hurricane, roof caves in because of snow....) in fact I have a list but - what matters to the customer is that they will received their product on time - even when you transfer the product to another supplier or location.
HINT: CONTINGENCY PLAN:2cents:
Sidney Vianna
Post Responsibly
..and in addition..
Are you implying that organizations must have a business continuity plan in order to comply with the work transfer requirements of AS9100?
G
GAF_QM
I don't believe the Standard is directing that, but there are some customers that want to see a business continuity plan with some of their main suppliers, and this is about meeting customer requirements. I also see this as a risk management initiative. However, I'm hesitant to implement this because, first, I have to write it making it auditable. I would have to identify a supplier or suppliers. And, I would have to identify the controls to assure customer requirements are being met. Right now, we need ensure the company can successfully upgrade to AS9100C without putting any additional obstacles to that success.
I believe I've received the input I need from you guys out there to address this in my procedure. Thanks for all the help.
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AS9100 Clause 8.3 - Control of Nonconforming Product Q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q AS9100 Clause 8.3 Control of Nonconforming Product - Clarification wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Definition Repair Schemes - Definition - AS9100 Clause 7.5.1.5 Control of Service Operations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
C AS9100 Clause 7.5.1.5 - Control of Service Operations - We do not do servicing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I How to satisfy with AS9100 Clause 8.4.3 a, Information for external providers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
W AS9100 Clause 8.5.1.3 Production Run Verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
W Evidence for Review of Requirements - AS9100 Clause 7.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A AS9100 Clause 7.1.1 Project Management - Process vs Project. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Checklist for AS9100 Clause 7.2.2 Review Of Requirememts Related to Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Verification of Process Changes (AS9100 clause 7.5.1.2) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z AS9100 Clause 7.4.2.d Revision Letter Flow Down to Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Management Review - AS9100 Clause 5.6.3 Review Output AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
V Application of AS9100 clause 7.5.1.1 - Tooling Supplier AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9100 clause for Repeat Orders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Compliance with AS9100 clause 7.5.1.3 Ctrl of Equipment, Tools and SW Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Understanding AS9100 Clause 7.5.1.4 Post-Delivery Support Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Interpreting AS9100 Clause 8.2.2 Internal Audit Requirements Internal Auditing 28
J AS9100 Clause 7.4.3 Verification of Purchased Product - OEM C of C required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C AS9100 C Clause 8.3 - Personnel Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Clause 7.3.3 - Design and Developement Requirements d and e AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Production Process Verification - AS9100 Clause 7.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Intercompany Work Transfer according to AS9100 Clause 7.1.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
O Clause Interpretations related to AS9100 Implementation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I Standard vs. Specification & AS9100 Clause 7.4.2 (d) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Planning of Product Realization - AS9100 Clause 7.1 - Can we exclude 7.1f? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Problem Collecting In-Service Data (AS9100 Clause 7.5.1.4) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q What is considered a Training Record? AS9100:2004 Clause 6.2.2 Records and Data - Quality, Legal and Other Evidence 8
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Project Management Procedure - AS9100 Clause 7.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
