AS9100 Clause 7.4.2.d Revision Letter Flow Down to Suppliers
Z
z28tt
Recently one of our special process suppliers stopped processing our parts unless we specify a spec revision letter on the PO.
Our major aerospace customers (P&W, UTAS) flow to us "latest revision at time of PO applies" to specifications used. We flow this down to our NADCAP suppliers (Heat Treat, NDT, Coatings, Passivation).
I can't find any reference within AS9100 that requires a revision letter, and from what I've read, NADCAP is AS9100 word-for-word. The revision status that we (and our customers) flow down is "latest at the time of PO" with a clause # on our PO terms and conditions.
7.4.2. Purchasing Information
Purchasing information shall describe the product to be purchased, including, where appropriate:
d.
the identification and revIsion status of specifications, drawings, process requirements,
inspection/verification instructions and other relevant technical data,
It would be nice to have someone verify and add the rev letter to each PO, but that's a lot of extra work with the volume of outgoing jobs, as well as a greater risk of making a mistake than a supplier missing the latest rev. Our suppliers are the specialists in their processes, so we've delegated it to them. This has never been an issue on our audits either.
Thoughts?
Sidney Vianna
Post Responsibly
Thoughts?
The standard is VERY clear on this: revision status is mandatory. To simply state the latest revision at the time of the PO represents a failure to comply with that requirement, in my assessment. I suspect that the supplier is taking this hard line because they probably got burnt at least once.
It is the responsibility of the customer to define the appropriate revision level of a process specification for an outsourced process. With the information provided, I would side with your supplier.
E
Eotfofyl
Following a change in upper management, the company I work for has recently changed the purchase order procedure from requiring that a revision letter follow every drawing and specification call out to simply indicate "Latest revision". According to them it is "What all the primes do". I fear this will get us into trouble come audit season.
I would like to see more opinions from the cove if possible on this matter as I have done quite a bit of research and come up with nothing but the clause from as9100 referenced above. I am told that the new SOP verbiage complies with the requirement.
Sidney Vianna
Post Responsibly
By whom? As I already stated, in my assessment, such practice clearly violates the AS9100 requirement I copied in my previous post. If you read the IAQG AS9100C Auditor Guidance document for that paragraph, it reads
What to look for
Examples of objective evidence:
? issue control of documents specified on purchase order
If your customer (OEM?) practices that, assuming that they are also AS9100 certified (not all are :mg:), you can let their CB know of the discrepancy via a OASIS feedback loop.
According to AS9104/1, CB's will have to audit the purchasing process every year, adequacy of information in PO's will be scrutinized continually and, I am afraid your process will be found nonconforming.
Big Jim
Just because that is "what the primes do" doesn't make it right.
andygr
For Boeing D1-44426 approved process houses
As a special processer you must know by way of flow down:
what revision level of the spec,
which division is the part being processed for ( Commercial, Defense, Rotocraft),
what aircraft the part will be used on.
Without this information you cannot process parts since you cannot properly determine which departures will apply.
This is addressed under the “Document D1-4426 - User Instructions & Processor Requirements"
http://active.boeing.com/doingbiz/d14426/UserInstProcReq.cfm
Here is the applicable para
6.6.4. Processor/Suppliers are required to adequately define and document prior to accepting an order, including but not limited to: specification, specification revision, Type, Class, Grade, program number, design authority, pre/post processing steps, as applicable.
To find out what the current status is for Boeing specs you can go to the links on the D1-4426 site right below the link for frequently asked questions.
http://www.boeingsuppliers.com/d14426/
This is a big issue and there will be requirements supplied by all of the Boeing special process groups around midyear to clearly identify what our special process houses working under D1-4426 must see on their PO's.
IF the required information is not getting to the process houses then the system reps at the upper food chain location that is not supplying the required info will be tasked to "fix" the condition.
IF you as the supplier can not show that you forced the issue to ge teh missing info and did not contact your process rep for help then you are at risk of loosing your approval.
E
Eotfofyl
By whom? As I already stated, in my assessment, such practice clearly violates the AS9100 requirement I copied in my previous post. If you read the (link removed) for that paragraph, it reads
By whom?
Upper management.
Yes.
Thank you for your responses, my concerns have been validated. Unfortunately our as9100 has already taken place and our audit was... less than thorough. I will make another attempt to convince my leadership that they are incorrect with their decision as happy as it made the purchasing group.
E
Eotfofyl
Quick update,
A recent audit found us non-compliant to 7.4.2. Upper management finally agreed to change things back to specifying the specific revision levels on purchase orders to sub tiers. But, not before I ask our SAI as9100 auditors. So i ask, and apparently this specific question is causing quite a bit of confusion but they have decided that indicating "latest revision" IS acceptable as long as you "[FONT=&quot]reference a website where the latest configuration can be downloaded". [/FONT][FONT=&quot]Obviously this cannot be accomplished as not all sub-tiers have access to customer websites.
Thoughts?
[/FONT]
andygr
That is exactly right. If the supplier can not access the configuration how can they know if the have the latest? If it is available on line then latest rev on the PO is fine since if they check and if they find they do not have the latest they can request it.
What does your firm require from your customers to assure that you are building to the correct configuration?
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I How to satisfy with AS9100 Clause 8.4.3 a, Information for external providers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
W AS9100 Clause 8.5.1.3 Production Run Verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
W Evidence for Review of Requirements - AS9100 Clause 7.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A AS9100 Clause 7.1.1 Project Management - Process vs Project. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Checklist for AS9100 Clause 7.2.2 Review Of Requirememts Related to Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Verification of Process Changes (AS9100 clause 7.5.1.2) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Management Review - AS9100 Clause 5.6.3 Review Output AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
V Application of AS9100 clause 7.5.1.1 - Tooling Supplier AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9100 clause for Repeat Orders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Compliance with AS9100 clause 7.5.1.3 Ctrl of Equipment, Tools and SW Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Understanding AS9100 Clause 7.5.1.4 Post-Delivery Support Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Interpreting AS9100 Clause 8.2.2 Internal Audit Requirements Internal Auditing 28
J AS9100 Clause 7.4.3 Verification of Purchased Product - OEM C of C required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C AS9100 C Clause 8.3 - Personnel Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Clause 7.3.3 - Design and Developement Requirements d and e AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Production Process Verification - AS9100 Clause 7.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9100 Clause 7.1.4 Control of Work Transfers clarification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S AS9100 Clause 8.3 - Control of Nonconforming Product Q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q AS9100 Clause 8.3 Control of Nonconforming Product - Clarification wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Intercompany Work Transfer according to AS9100 Clause 7.1.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
O Clause Interpretations related to AS9100 Implementation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I Standard vs. Specification & AS9100 Clause 7.4.2 (d) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Planning of Product Realization - AS9100 Clause 7.1 - Can we exclude 7.1f? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Problem Collecting In-Service Data (AS9100 Clause 7.5.1.4) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q What is considered a Training Record? AS9100:2004 Clause 6.2.2 Records and Data - Quality, Legal and Other Evidence 8
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Project Management Procedure - AS9100 Clause 7.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Definition Repair Schemes - Definition - AS9100 Clause 7.5.1.5 Control of Service Operations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
L How to comply with AS9100 Clause 7.6 - Monitoring and measuring devices to be used AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
