AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements
bigbirdy
Hi to all,
Bigbirdy needs your help again! My question is about section 8.2.3.C Monitoring and Measurement. The requirement is stated as.
“Determine if the process nonconformity is limited to a specific case or whether it could have affected other processes or products”
:bigwave: My question is, is this related to section 8.5.2.i. corrective action requirement i. ?
“Determining if additional nonconforming product exists based on the causes of the nonconformities and taking further action when required.”
:bigwave: The intent of these two requirements, are they same? Any suggestion how to best approach these requirements.
Thanks a lot!
Jason PCSwitches
Re: Question 8.2.3.C Monitoring and measurement and 8.5.2 requirements
Hi to all,
Thanks a lot!
What you need to do is 1st evaluate the initial NC. 2nd determine if the NC or the cause of the NC could have had any affect on anything else.
So if you had a bad part produced, did any of the lot get supplied internally/externally? If so what have you done to contain & control the escapement? If not have you properly isolated the NC product?
Have you looked at the process that produced the NC? Was it related to inspection, machinery, etc? Once determined have you properly addressed the cause to ensure other product has not & will not experience an NC related to the original cause.
See you may notice NC product at a given phase, but it is possible that NC product may have escaped further down your line. The standard is requiring that you not only look at the immediate NC, but take it as far as you can go to ensure nothing has gotten past that initial point of awareness.
bigbirdy
@ Jason PCswithces thank you very much.
That is how we intended to approach 8.2.3 Monitoring and measuring processes but do we need to document this approach ( I.E. CAR form,work instruction or procedure)?
Thanks again
Jason PCSwitches
Thanks again
You don't necessarily need a documented procedure, one is not required at least, but you need to show objective evidence of the actions you take & demonstrate that your methods are properly communicated and understood.
How you chose to do this is entirely up to your organization. Do whatever works/adds value to YOUR organization. I caution you to think on this as many try to simply comply to the standard instead of applying the standard!!
bigbirdy
8.2.3 is monitoring and measurement of the process and 8.5.2 is corrective action. The requirements that i mentioned above are new to AS9100C standard.
8.5.2 Corrective action calls out for documented procedure. I wonder if changing our CAR form to include an extra step for checking the extent of escapement enough to satisfy the intent of the requirements 8.5.2.i and 8.2.3.c?
Thanks.
H
Hodgepodge
Thanks.
A form can’t always be everything for everybody. A corrective action report is a record that is sufficient to show an investigation was made and that actions were taken. The problem, cause, and corrective action statements should be succinct, however, for a form to be large enough to cover every corrective action, it would need expandable ranges for all the free form text you might need. An investigation might lead down many possible paths, the corrective action report isn’t intended to be the paper you keep your notes on. It is the final document that wraps it up.
The format for investigating and implementing corrective actions is what is important. There may be more than one problem. There may be more than one root cause. Team members should keep notes and all problems should be traced to their roots. PRI has a really good root cause tutorial. The format is great. A form can help you to remember to address all the “required” items but often times they can be limiting. Beware of forms with spaces only big enough for small problems. The format is what is important. I would go so far as to say you don’t even need a form as long as you have a good report. Check out the PRI tutorial here. (I've also attached a copy) If you apply the principles and action items and take good notes, you’ll have all you need. When you are done, you may find you need more than one of your corrective action forms for documenting all the root causes you have uncovered.
Big Jim
Thanks.
Your corrective action procedure needs to address 8.5.2 i.
bigbirdy
@ Big Jim, Jason PCswitches and Hodgepodge Thank you very much!
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L How to comply with AS9100 Clause 7.6 - Monitoring and measuring devices to be used AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I How to satisfy with AS9100 Clause 8.4.3 a, Information for external providers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
W AS9100 Clause 8.5.1.3 Production Run Verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
W Evidence for Review of Requirements - AS9100 Clause 7.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A AS9100 Clause 7.1.1 Project Management - Process vs Project. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
W Checklist for AS9100 Clause 7.2.2 Review Of Requirememts Related to Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Verification of Process Changes (AS9100 clause 7.5.1.2) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z AS9100 Clause 7.4.2.d Revision Letter Flow Down to Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Management Review - AS9100 Clause 5.6.3 Review Output AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
V Application of AS9100 clause 7.5.1.1 - Tooling Supplier AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9100 clause for Repeat Orders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Compliance with AS9100 clause 7.5.1.3 Ctrl of Equipment, Tools and SW Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Understanding AS9100 Clause 7.5.1.4 Post-Delivery Support Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Interpreting AS9100 Clause 8.2.2 Internal Audit Requirements Internal Auditing 28
J AS9100 Clause 7.4.3 Verification of Purchased Product - OEM C of C required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100 C Clause 8.3 - Personnel Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Clause 7.3.3 - Design and Developement Requirements d and e AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Production Process Verification - AS9100 Clause 7.5.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9100 Clause 7.1.4 Control of Work Transfers clarification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S AS9100 Clause 8.3 - Control of Nonconforming Product Q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q AS9100 Clause 8.3 Control of Nonconforming Product - Clarification wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Intercompany Work Transfer according to AS9100 Clause 7.1.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
O Clause Interpretations related to AS9100 Implementation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I Standard vs. Specification & AS9100 Clause 7.4.2 (d) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Planning of Product Realization - AS9100 Clause 7.1 - Can we exclude 7.1f? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S Problem Collecting In-Service Data (AS9100 Clause 7.5.1.4) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q What is considered a Training Record? AS9100:2004 Clause 6.2.2 Records and Data - Quality, Legal and Other Evidence 8
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Project Management Procedure - AS9100 Clause 7.1.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Definition Repair Schemes - Definition - AS9100 Clause 7.5.1.5 Control of Service Operations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
