AS9100, Clause 8.5.1.3 - First Article Inspection Costs
CanadianQA
Hi All,
We are moving down the road to our AS9100:2016 certification with our stage 2 planned for early January. I'm finding our FAI process very cumbersome and am looking for some input in ways to make it not take so much time. Our current process involves:
1. Bubbling the characteristics on the drawing (could be anywhere from 5 to 500 depending on the part being made.
2. Transferring all the characteristic and requirement data from the drawings to our AS9102 based FAI forms (this is a manual typed process on a fillable pdf form).
3. Inspector fills out the results sections of the form then forwards the form for applicable review.
It can take 4-5 hours to get one part processed! Is that a normal amount of time for an FAI?
Is using AS9102 forms a mistake when there has been no specification made to use AS9102 requirements? Is there any software out there that handles bubbling drawings / transferring the characteristic and requirement data to the recording forms? Can we exempt certain parts from FAI requriemetns but still meet AS9100 requirements? How do you handle FAI when a customer has only given us a sample of a part to make?
My General Manager had a bit of a freak out today about "how we're supposed to make money when we have to FAI every new part". Any input on how others are handling this process more efficiently are greatly appreciated.
dsanabria
Hi All,
So what happened to the original prints?
Second - ask your customers if they would accept grouping families or similar parts with identical features but different diameter.
third - do the FAIR as the customer demand them - not all of them at a time.
and finally, each feature takes approximately 2 minutes - based on complexity - so do the math.
Big Jim
First of all, you don't need the detail of AS9102 unless a customer requires it. AS9100D 8.5.1.3 requires much less than AS9102. AS9102 IS NOT a requirement of AS9100D.
AS9100D essentially requires that a representative sample of the first production run be evaluated to confirm that the process verification activities are able to products that meet requirements. It requires keeping records of that evaluation. It doesn't tell you the method or format of the records.
You may be making too much of all of this.
If a customer requires AS9102 then you need the detail you have encountered. Make sure you allow for it when bidding. Some customers allow it as a line item. Even if they don't allow for it as a line item, cover it somewhere. You shouldn't be doing it for free.
I'm sure others will chime in with methods and techniques to become more effecient than you seem to be now.
William55401
FAI productivity software exists. I am working a project to validate DISCUS for a medical device organization. The tool helps you create ballooned drawings and FAI data sheets. Full disclosure: I did not select the software and was not aware of alternates. I am also not affiliated with the DISCUS org. If you are in an org where you do not have to validate the s/w, this tool may help you get running more quickly.
Eredhel
Quality Manager
AS9102 FAI forms are not a requirement of the AS9100 standard. If your customers aren't requiring the AS9102 forms then you don't have to use them.
CanadianQA
First: There never were any original prints. The customer (our sister company) takes a part and says, "here, make us a bunch of these".
Second: It's not really realistic for us to ask this of all our customers. We have several. The parts are not really that similar.
Third: How does that meet the requirement of 8.5.1.3? I didn't think you could say that you meet clauses of the standard only when the customer requests them?
Finally: Yes, I realize that each feature takes maybe that amount of time to measure, however there's the bubbling of the drawing and the entering of the data. I'm looking for ways to reduce the time it takes to do all of this.
CanadianQA
That's a huge relief! What do you suggest for a FAI process then? The only experience I have with FAI is AS9102, so what other means would meet the requirement?
I'm quite sure you're right!
I would really appreciate it if someone could post their NON AS9102 FAI form that they are using.
Thansk Big Jim.
Big Jim
I hope someone post their form too.
However, think in terms of the minimum you would need to record to show that your representative sample demonstrates that your equipment, any software programs (CNC programming for the part), Work Order (Traveler, Router, or whatever you call it in your shop), Work Instructions (if you have deemed any are needed), and employee competency come together to make the part correctly.
Kronos147
Plan your review of the requirements to determine what needs to me measured. Put those dimensions on the traveler and measure parts per your internal AQL and document the results on the traveler as well.
If you want to be extra safe, send that determination to your 'customer' for approval as part of the process (prior to acceptance).
Hypothetical:
AS9102 talks about what do you do if you get a digital product definition. What would you do then?
Michael_M
We have to do AS9102 for most of our customers, however for the AS9100d requirements, do you perform a setup inspection and record the data somehow (we write the setup dimensions directly onto the print and scan that onto our server).
D First Article Inspection Required? AS9100 Clause 8.2.4.2 - Lubricant manufacturer AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
A AS9100 Clause 8.2.4.2 - First Article Inspection (FAI) - How do you comply? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
J Not Design Responsible - Can we exclude all or parts of AS9100 clause 8.3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
I How to satisfy with AS9100 Clause 8.4.3 a, Information for external providers? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
oldqamanager How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 39
W AS9100 Clause 8.5.1.3 Production Run Verification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
W Evidence for Review of Requirements - AS9100 Clause 7.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A AS9100 Clause 7.1.1 Project Management - Process vs Project. AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
W Checklist for AS9100 Clause 7.2.2 Review Of Requirememts Related to Product AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
R Verification of Process Changes (AS9100 clause 7.5.1.2) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Z AS9100 Clause 7.4.2.d Revision Letter Flow Down to Suppliers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 12
M Management Review - AS9100 Clause 5.6.3 Review Output AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 12
V Application of AS9100 clause 7.5.1.1 - Tooling Supplier AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G AS9100 clause for Repeat Orders AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
M Compliance with AS9100 clause 7.5.1.3 Ctrl of Equipment, Tools and SW Programs AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
M Understanding AS9100 Clause 7.5.1.4 Post-Delivery Support Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
K AS9100 Clause 7.2.2 - Documenting "Special Requirements" and risks AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
G AS9100 Clause 7.5.1.1 Production Process Verification Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
M Interpreting AS9100 Clause 8.2.2 Internal Audit Requirements Internal Auditing 28
J AS9100 Clause 7.4.3 Verification of Purchased Product - OEM C of C required? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
C AS9100 C Clause 8.3 - Personnel Approval Process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
B AS9100 Clause 7.3.3 - Design and Developement Requirements d and e AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
J Production Process Verification - AS9100 Clause 7.5.1.1 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 37
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
G AS9100 Clause 7.1.4 Control of Work Transfers clarification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 12
S AS9100 Clause 8.3 - Control of Nonconforming Product Q AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
quality1 AS9100 Clause 8.3 Control of Nonconforming Product - Clarification wanted AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
P Intercompany Work Transfer according to AS9100 Clause 7.1.4 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
O Clause Interpretations related to AS9100 Implementation AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
I Standard vs. Specification & AS9100 Clause 7.4.2 (d) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
H Planning of Product Realization - AS9100 Clause 7.1 - Can we exclude 7.1f? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
S Problem Collecting In-Service Data (AS9100 Clause 7.5.1.4) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
Q What is considered a Training Record? AS9100:2004 Clause 6.2.2 Records and Data - Quality, Legal and Other Evidence 8
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M New to AS9100 - Clause 7.5.3 - Do you have to identify each part produced AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
J Project Management Procedure - AS9100 Clause 7.1.1 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 15
E Meeting AS9100 Clause 6.3 Infrastructure Requirements - Preventive Maintenance AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
