AS9100 D 8.3.4.1 a - Parameters to be recorded" - What is this asking for?
magister38
Greetings,
A little background. I work at a small company that that makes parts to print for aerospace and it's own line of hoppers, hopper lids, and trash cans. We provide spun metal products. I know that I am making a mountain out of a mole hill, but I am setting up our processes across the board to meet AS9100 D. Our own parts will be covered by the ISO portion which we are design responsible. So, I am making our processes meet the AS9100 spec so in the future if we have to design any product for aerospace, our system is already set-up. I know, more work that needs to be done...
I have a question about the requirements listed in 8.3.4.1.a of AS9100 D. I am stuck on "parameters to be recorded". What is this asking for?
TIA,
Scott
Sidney Vianna
Post Responsibly
When you are testing a prototype, aiming at V&V of the product design, the parameters of the test to demonstrate acceptability of the product. For example, if you are performing a destructive testing to show that the wire can withstand a minimum of 25,000 lbs(f) before yielding, or the device can be cycled 15,000 times before any cracks are visible, or a landing gear can be lowered in less than 6 seconds, etc...
dsanabria
Greetings,
TIA,
Scott
This is the paragraph that you are having trouble with...
Quote
" 8.3.4.1 When tests are necessary for verification and validation, these tests shall be planned, controlled, reviewed, and documented to ensure and prove the following:
a. test plans or specifications identify the test item being tested and the resources being used, define test objectives and conditions, parameters to be recorded and relevant acceptance criteria; "
bottom line - if test are necessary - you need to define how, when, what and range of what is acceptable
Example - thickness of material - .125 +/- .005 so the parameters are .120 - .130.
Note: Sidney gave excellent examples.
Let us know if you need additional information.
T What should be considered or asked to certified body auditors before selecting them for AS9100 Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Counting contractors for determining AS9100 audit days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 Internal Audit (Quality System) Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Clarity on requirements for indirect suppliers per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 work for another site outside scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sam.F ISO9001/AS9100 Software Quality Assurance and Compliance Software Tools and Solutions 1
L Collateral Duty Inspectors - Ok for AS9100? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Production not following AS9100 std AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B AS9100 applicability to aircraft operation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Supplier AS9100 certificate suspended - still ship goods ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Pros and cons to transition to AS9100 for non aerospace company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B AS9100 Certification Audit Accounting for Additional Customer QMS Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
Q AS9100 Facility Relocation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Do we need to raise concessions for every noted deviation under AS9100 Manufacturing and Related Processes 3
S Minimum Retention Time for Records of internal audit results as per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
PowerJunkie Cancelling AS9100 Certification - How and Who to notify? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Exclusions allowed in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Minimum/ mandatory core processes AS9100 Process Maps, Process Mapping and Turtle Diagrams 6
M Lack of qualified AS9100 Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
F AS9100 and FAIR - When to do them AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS9100 examples of procedures, quality manual, etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O AS9100 8.4.3 Supplier Terms and Conditions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100 Supplier Audit Checklist example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Design Authority questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9100:D Counterfeit internal audit questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B SPOC 001/SPOC 002 AS9100 FAIR REQUIREMENTS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9120 to AS9100 due to value added activities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
