AS9100 FOD (Foreign Objects and Debris) Requirements
SharedVisionCV
I just went through my first AS9100 audit. This is my first year in the quality management position. Through the audit I learned that our quality manual needs some major cleaning up.
My question is this: During a previous audit one of our nonconformances was no FOD procedure at all. As a corrective action, a procedure was written by a previous QM. I am reviewing the procedure now and trying to clean up some unnecessary language that paints us into a corner. The current procedure states that we measure the effectiveness of the FOD procedure via semiannual FOD audit.
I have referenced paragraph 7.5.5 of the standard and see where it states that "prevention, detection and removal of foreign objects" is required. I do not see, however, where it states that measurability is. I'd like to remove this portion of our procedure. Can anyone point me to where the standard states, if it does, that we need to be evaluating the procedure? (Beyond corrective actions initiated in the case of FOD findings.)
DannyK
There is no requirement for a FOD audit in AS9100C but it is a good practice.
You can include the review of FOD during the internal audit of production, inspection, assembly and shipping.
Mike S.
Happy to be Alive
Real quickly?..if you do not measure results in some way, how will you know if you are being effective? Look at 0.2c, the ?C? in ?PDCA?, 4.1e, ......
SharedVisionCV
I could implement something into our internal audit procedure to cover FOD, as the first response suggested. At the time of our audit, I was unaware that our procedure held us to a semi annual FOD audit. The auditor was asking for the documentation of these audits. Our manual was overwritten. We are a small company and there are only so many resources to implement, audit, evaluate, etc. I am trying to eliminate anything unnecessary to make our manual more manageable.
SharedVisionCV
Thank you for your help. I have looked where you suggested. I see what you are saying. If the FOD is part of our manufacturing process, than the measurement of it's effectiveness would be checked when I and measuring the effectiveness of the manufacturing process. I am trying to avoid additional audits and monitoring.
dsanabria
Please note that the ISO standard does not require a procedure all that it requires is an awareness in the facility. This is usually done by posters, newsletter, annual refresher presentation.
That does not mean that you are doing something wrong - but an 3rd party auditor can not write a non conformance for not having a procedure.
Be careful with customer requirements - that is another story.
For additional information on FOD - check out the material on the Supply Chain Management Handbook (SCMH) - Chapter 3.4 http://www.sae.org/servlets/registr...HGeneral&PAGE=getSCMHBOOK&vgenNum=184&scmhs=1
SharedVisionCV
dsanabria, thank you for your response. This is what I was under the assumption of, but wanted confirmation. I will look at the SCMH where you suggested.
Q
QA_Newbie2000
As I'm sure you already know, even if it's not a requirement of the standard once you put it in a procedure it becomes a requirement:mad:
As you indicated FOD is specifically mentioned 7.5.5b, so it needs to be documented somewhere how you control it and like Mike S said earlier how will you know if the controls in place are effective if it's not measured.
What we do is we have added a section for FOD to our area audits. While we are auditing a process we verify that the correct controls are in place for FOD, ESD, Calibration, etc
Kronos147
So if there were some internal audits done after the initial FOD finding, and you have judged the process of continual FOD awareness prevention effective through other means (training, work order notes, etc.), then you could revise the process with justification of revision, to exclude the continual audits.
But, can't the FOD audit just be incorporated into an item of every (applicable) process during the internal audit? Is it that much more work to help prevent plane crashes? :rolleyes:
A FOD audit can be easier than that. You can do a FOD audit with every final inspection. That is a FOD audit for that item.
K FOD (Foreign Objects and Debris) - AS9100 & Hook Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FOD (Foreign Objects and Debris) and AS9100 compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S AS9100 and Nadcap vs. NAS412 (FOD program) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q AS9100 Facility Relocation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Do we need to raise concessions for every noted deviation under AS9100 Manufacturing and Related Processes 3
S Minimum Retention Time for Records of internal audit results as per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
PowerJunkie Cancelling AS9100 Certification - How and Who to notify? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Exclusions allowed in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Minimum/ mandatory core processes AS9100 Process Maps, Process Mapping and Turtle Diagrams 6
M Lack of qualified AS9100 Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
F AS9100 and FAIR - When to do them AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS9100 examples of procedures, quality manual, etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O AS9100 8.4.3 Supplier Terms and Conditions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100 Supplier Audit Checklist example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Design Authority questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9100:D Counterfeit internal audit questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B SPOC 001/SPOC 002 AS9100 FAIR REQUIREMENTS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9120 to AS9100 due to value added activities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
