AS9100, ISO Standard Applicable to Lighting for Workstations and Inspection Stations
carol4832
Can anyone quickly point out what the Quality Standard is specifically applicable to Aerospace for Ft/Candles Lumens in the inspection area's.
I have seen the Typical light levels and Medical / Automotive specs.
What Exactly is the Standard for Aerospace.
DannyK
Re: AS9100,ISO Standard Applicable to Lighting for Workstations and Inspection Statio
There is no general industry standard for aerospace that is referenced in AS9100C and ISO 9001:2008.
I have seen aerospace customer requirements that specify the lighting requirements for inspection areas.
somashekar
Re: AS9100, ISO Standard Applicable to Lighting for Workstations and Inspection Stati
Got this guidelines for you to read and adopt. Read it HERE
good luck ...
carol4832
thank you!!
Big Jim
Keep in mind that AS9100C just isn't very specific on the topic. You can find what little there is in element 6.4, including the note.
"6.4 Work Environment
The organization shall determine and manage the work environment needed to achieve conformity to product requirements.
NOTE: the term 'work environment' relates to those conditions under which work is performed including physical, environmental and other factors (such as noise, temperature, humidity, lighting or weather)."
Guidelines such as Somashekar provided a link for is probably where you will find the most help.
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 10
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
E AS9100 / ISO 9001 Cert Suspended AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 23
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
A Does AS9100 require Suppliers to be Certified to ISO or AS? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Other Remote Locations - Do they need to be under our ISO/AS9100 System? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
N Losing your ISO Certification if you Lose Your AS9100 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
K What do I need to do to "upgrade" from ISO 9001 to AS9100 Registration AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
W Incorporating an ISO 9001 Company into an AS9100 QMS AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
P AS9100:2009 compared to ISO 13485 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
T Combining Sector Specific Quality Standards - TS 16949, AS9100 and ISO 9001 Other ISO and International Standards and European Regulations 3
C Differences between ISO 9001:2008 and AS9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K ISO 9001 vs AS9100 Gap Analysis on Delivery Performance and Document Control AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
G Implementing Dual Standards in a Company - ISO 9001 & AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
M Combine ISO 9001 and AS9100 into a single Quality Manual and System? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
M Everything to AS9100 vs. ISO 9001? Commercial Jobs require AS9100 "Extras"? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
D "Simplified" AS9100 and ISO 9001 Internal Audit Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
L Developing a QMS Manual for AS9100 and ISO 9001 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 20
M AS9100 Requirements and ISO 10013 Quality Management System (QMS) Manuals 4
K Job Shop - Registering to AS9100 vs. ISO 9001 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 27
J ISO 9001/AS9100 Requirement for Management Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001 to AS9100 Gantt Chart AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
quality1 AS9100 Rev C Certification and ISO 9001 with one audit for both AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
K Registering to AS9100 - Already ISO/TS-16949 Registered AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
T Definition Rework vs. Repair in ISO/AS9100 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
C AS9100 and ISO 9001 - Dual Certifications Suggested at AS9100 Internal Auditor class AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
T Transition to AS9100 from ISO 9001 (Cost) - We are an Aerospace and Military Supplier AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 31
G Combining AS9100, ISO 9001, & PRI (NADCAP) into 1 Internal Audit Internal Auditing 8
J Registrars Doing Synchronized (Combined) Audits to AS9100 and ISO 13485 Registrars and Notified Bodies 8
W AS9100 Rev C vs. ISO 9001:2008 Comparison AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
C Do you keep ISO 9001 when going AS9100? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
W ISO 13485, ISO 9001, and AS9100 Combined QMS Manual Quality Management System (QMS) Manuals 14
G AS9100 & ISO 9001 Internal Audits (-+) - Auditor Qualifications AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 26
J Both AS9100 and ISO 13485 registered? ISO 13485:2016 - Medical Device Quality Management Systems 1
V Can I apply for AS9100 Straight Away? (We don't have any ISO certificates) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M ISO 9001 and AS 9100 Registrations - AS9100 applicability to a software company AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
J List of ISO 9001, AS9100 and TS 16949 certified companies in India Registrars and Notified Bodies 6
P Software to help meet ISO & AS9100 Design & Development Rqmts Design and Development of Products and Processes 2
W ISO 9001:2008 and AS9100 combined Quality Manual (Systems Manual) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 53
K Are ISO 9001:2008 and AS9100:2009 going to be the official dates used? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
D Production and Service Provision - AS9100 vs. ISO 13485 - Numbering Issues ISO 13485:2016 - Medical Device Quality Management Systems 2
T ISO 9001 and AS9100 Training Tools for all Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T AS9100 timeline from ISO 9001 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
P Can I perform an ISO 13485 audit? I'm a registered RABQSA QMS and AS9100 Auditor ISO 13485:2016 - Medical Device Quality Management Systems 3
R ISO 9001:2000 vs. AS9100:2004 Rev B Comparison Matrix AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
J ISO 9000 vs. AS9100 in a Local Fabrication and Machine Shop AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R AS9100 vs. ISO 9001 Comparison (Cross Reference) Matrix AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
GStough Anyone Here Ever Move from ISO 9001 / ISO 13485 into AS9100? Career and Occupation Discussions 3
