AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a repair
QLearning
All,
Hope you can help. We are small electronics manufacturer that has both aerospace and non-aerospace customers. We are AS9100c/ISO 9001:2008 certified.
Do we have to notify/get approval from a non-aerospace customer prior to conducting a repair, if the customer does not seem to have a notification of change clause or terms in their contract?
Thanks.
Sidney Vianna
Post Responsibly
Re: AS9100 repairs
If your organization and your registrar were not careful when defining your scope of certification and your certificate implies that your AS9100 compliant (and certified) system applies to all customers and products, even the non-aerospace ones, you can not disposition any product for repair without the consent of the customer and/or the design responsible organization, as it would violate the AS9100 requirement in 8.3 which reads:
Dispositions of use-as-is or repair shall only be used after approval by an authorized representative of the organization responsible for design.
QLearning
Re: AS9100 repairs
Dear Sidney,
Thank you very much for your reply. It is very helpful. I checked our certification, which says it's applicable to the type of work we do, but does not distinguish between aerospace vs. non-aerospace (ugh!).
Again, your response is pretty definitive. Thanks.
Sidney Vianna
Post Responsibly
Re: AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a rep
If this is a serious issue for your organization, you could work with your CB to clarify that the AS9100 certified system applies exclusively to the aerospace customer/products and ISO 9001 applies to the commercial customers/products.
As ISO 9001:2008 does not have the requirement mentioned below, you would not infringe any requirement if you dispositioned commercial products for repair, as long as the commercial customers do not have any contractual clause limiting your MRB authority.
It might sound just a bureaucratic procedure, but certification scopes should be paid attention to, in order to remain relevant.
I would recommend you to work with your AS9100/ISO 9001 registrar and have the certificate revised to clarify the intended field of certification coverage.
Good luck and thanks for the feedback.
P
PaulJSmith
While agreeing with Sidney, I'll also add that you need to ensure that your own internal procedure allows this as well. If it states that you must have customer approval, then you either need customer approval or you need to re-write that procedure to allow repair without it (I'm not convinced this is a good idea, especially if the customer owns the design).
John Broomfield
Rework is not a design change but repair is.
...so which is it?
P
PaulJSmith
Good point, John. OP said "repair." I inserted "rework." Poor choice of word on my part. Sorry.
Edited to correct that post.
QLearning
Paul,
Thanks for your input. Our own internal procedure for nonconforming material/product states that we need customer approval for repairs, so we at a minimum, we didn't follow our own requirements. But, if the customer is not an aerospace customer, and they do not have any specific terms/requirements for us to obtain approval prior to performing repairs, can they issue us a CAR?
QLearning
John, we are dealing with a repair for a non-aerospace customer who does not have specific terms/requirement for us to seek their approval prior to conducting repairs. They issued us a CAR. Is it legit?
Big Jim
Sydney said it best.
It depends on how you set up your system, specifically on your scope statement.
I often see a dual scope statement with wording similar to this:
AS9100C requirements apply for all work performed for customers who require AS9100C by contract. ISO 9001:2008 requirements apply to all other work.
If you didn't set up your scope with this flexibility, you will need to apply AS9100C requirements for everything.
T What should be considered or asked to certified body auditors before selecting them for AS9100 Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Counting contractors for determining AS9100 audit days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T AS9100 Internal Audit (Quality System) Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Clarity on requirements for indirect suppliers per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 work for another site outside scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sam.F ISO9001/AS9100 Software Quality Assurance and Compliance Software Tools and Solutions 1
L Collateral Duty Inspectors - Ok for AS9100? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Production not following AS9100 std AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B AS9100 applicability to aircraft operation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Supplier AS9100 certificate suspended - still ship goods ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Pros and cons to transition to AS9100 for non aerospace company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B AS9100 Certification Audit Accounting for Additional Customer QMS Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
Q AS9100 Facility Relocation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Do we need to raise concessions for every noted deviation under AS9100 Manufacturing and Related Processes 3
S Minimum Retention Time for Records of internal audit results as per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
PowerJunkie Cancelling AS9100 Certification - How and Who to notify? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Exclusions allowed in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Minimum/ mandatory core processes AS9100 Process Maps, Process Mapping and Turtle Diagrams 6
M Lack of qualified AS9100 Auditors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
F AS9100 and FAIR - When to do them AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS9100 examples of procedures, quality manual, etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O AS9100 8.4.3 Supplier Terms and Conditions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100 Supplier Audit Checklist example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Design Authority questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9100:D Counterfeit internal audit questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B SPOC 001/SPOC 002 AS9100 FAIR REQUIREMENTS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9120 to AS9100 due to value added activities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
