AS9100 Requirement - Verification of characteristics results with drawing requirements
Prashant G
Every standard talks about verification of characteristics results with drawing requirements,but can someone advice with the help of AS9100 do we required to write down all the results for all characteristics?
Mike S.
Happy to be Alive
Does this help?
8.5.1.c.1 "....measurement results to be retained (at a minimum an indication of acceptance or rejection);"
Cari Spears
Hi, Prashant -
We make non-flight hardware (tooling and ground support equipment) - our customers only want us to report actuals to them for critical dimensions. All other non-critical dimensions are covered by a statement in our Tooling Inspection Report that all non-critical dimensions were verified and in tolerance. Our customer defines "critical", as they are often different.
Michael_M
We verify using the drawing. When we do Setup inspections (and in process inspection), we record the actual dimension on the drawing. We have added additional requirements for our inspectors to review that are not specifically on the drawing and these also get written on the drawing itself. We then scan the drawing into our system. The operators are required to measure the parts as they make them, but are not required to record the dimension unless specific requirements require it.
Prashant G
It does it satisfies AS9100 D requirement in an audit.
Eredhel
Quality Manager
Is your question, do you have to 100% document every dimension on every part? If so, no.
Edit: To the point others are making, yes it could be possible that certain characteristics might become 100% documented. Depends on the actual situation.
Sidney Vianna
Post Responsibly
Along the lines of what Cari Spears mentioned, typically, key characteristics (a subset of critical items) have to have the actual result recorded because variation is something that is concerning as well.
So, if you have key characteristics identified in the design, actual readings will have to be recorded.
D AS9100 Inspection records - Is there a requirement to have gauge ID and calibration status AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
S AS9100 and Confidentiality requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
C AS9100 Requirement Definition - Defined vs. Documented AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
J Corrective Action Review - AS9100 Rev. C Requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
T Requirement for each Company Plant to be AS9100 Registered? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
C AS9100 C Requirement for a Document and Data Control Table AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
J Audit Days Requirement for AS9100, Rev C Re-Certification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
J ISO 9001/AS9100 Requirement for Management Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Selective Application of AS9100 by Requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
Z AS9100 Requirement - CMM Temperature Logger AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
A AS9100 Awareness Training Requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
C Is SPC a requirement of AS9100? Small Machine Shop and Assembly AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
P AS9100 4.2.3 Control Of Documents - Requirement to retain Obsolete Documents? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
J PRI - NADCAP Certification requirement - AS9100 audit first before NADCAP audit? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 12
H AS9100 - Right of entry requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 10
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 9
M Ethics and Legality AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 25
classical_quality AS9100 Surveillance Audit - advice on drafting strong responses AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
L AS9100 - Infrastructure or Product? Inflight internet connectivity network AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
T AS9100 - Changing PEARs target AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 41
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
G AS9100-8.1.2 Configuration Management AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
R AS9100 REV D gap analysis matrix AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
E Recommendations for CBs south of England AS9100 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
E AS9100 installtion procedure AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
Q Connecting AS9100 D Clause 4.2 to 9.3.2 b - Interested parties and relevant issues AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 16
L AS9100 and Agile development processes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
I Is this a Major AS9100 QMS change - Quality Concerns AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
T QMS Training for my organization - IATF16949 and also AS9100 or 9145 Manufacturing and Related Processes 2
