AS9100 Rev. C - Records created and/or maintained by Suppliers
G
Genepool1960
I have a question regarding the AS9100C and records.
Control of Records, 4.2.4 states "the documented procedure shall define the methods for controlling records that are created by and/or retained by suppliers.
Purchasing Information 7.4.2 Purchasing information shall describe the product to be purchased, including, where appropriate, ... h) Record retention requirements.
My question is this: According to AS9100 do I have instruct my supplier to maintain records of product listed on my P.O. in accordance with AS9100C. That the supplier must have a system for identification, storage, protection, retrieval, and disposition. As well as making sure they are legible, readily identifiable and retrievable?
Thanks for your input!!!
If you expect a supplier to maintain records above and beyond what they usually do, you simply need to tell them. Purchase orders may be the main way to tell them, but there can be other ways to deliver purchase requirements, including additional record keeping requirements.
G
Genepool1960
Thanks BG for the response. I understand the need to request the info on a PO for a supplier. My question is, according AS9100C, do I need to have the supplier maintain a system that controls the records in accordance to the AS9100C?
Michael_M
It depends on your procedures and what your customers require. The standard (Note: I am working towards certification now so am not an expert) says "the documented procedure shall define the method for controlling records that are created by and/or retained by suppliers". All this is saying is your procedures will define how supplier records will be retained.
Our procedure address this with the following line:
Suppliers shall create and maintain records required as prescribed by the specific information provided by the purchase orders issued by
Again, we have not 'passed' our stage 1 (that's October) or Stage 2 (that's November) but we do have the services of a consultant who is also an Auditor.
The short answer is is sort of but not specifically.
The closest AS9100C comes to that would probably be part of 7.4.2g and all of 7.4.2h.
(7.4.2) "Purchasing information shall describe the product to be purchased, including, where appropriate . . . (7.4.2g) requirements regarding the need for the supplier to . . . flow down to the supply chain the applicable requirements including customer requirements . . . (7.4.2h) record retention requirements . . . "
If outsourcing is involved, then part of 4.1 comes into play.
"Where an organization chooses to outsource any process that affects product conformity to requirements, the organization shall ensure control over such processes. The type and extent of control to be applied to these outsourced processes shall be defined within the quality management system."
Then there is always that part of 4.2.4 that needs to be considered.
"The (control of records) documented procedure shall define the method for controlling records that are created and/or retained by suppliers."
So you do not need to enforce those elements of AS9100C upon your suppliers, but you do need to pass on the requirements that you are required to pass down the supply chain and they need to have a reasonable method of maintaining those records.
Don't forget that right of access (7.4.2i probably fits here too when right of access is a requirement that your customer specified for you to flow down.
G
Genepool1960
Thanks for the input. I think it gets tricky when I start to pull the requirements for control of records from the AS9100 and place it on our suppliers. I just think that AS9100 gurus wanted us to control our records methodically and probably wanted the same for our suppliers....
rickpaul01
Involved in HankyPanky
The short answer is no. This requirement is in the standard in the event that you want your supplier to maintain records which are important to you. For example most companies what to receive a certificate of conformance with the delivery of the raw material. But let's say you want your suppliers to keep them on file instead of sending them to you. This clause would now come into play. Got it?
Q AS9100 Rev B List of Required Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
A Controlling the records of suppliers - AS9100 Rev B Clause 4.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R AS9100 REV D gap analysis matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
S General Awareness Training for AS9100 Rev.D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P How To Transition From AS9100c to AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
A AS9100 Rev D - Procedure for Product Safety & Control of Counterfeit Part (Format) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9100 Rev. D - Question about 8.4.3 (k) - Supplier Certificates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D Transition Audit - Number of Audit Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100 Rev.D Transfer of Work - Procedure and form templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
K AS9100 Rev. D Transition - Internal Audits & Gap Analysis Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Design and Development Procedure example and Template wanted - AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Guidance and/or assistance on Transition to AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
T What is the Rev C equivalent for an RABQSA AS9100 Certified Lead Auditor course? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
F Gap Analysis Matrix for AS9100 Rev C to TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 1
R AS9100:2016 Rev. D - Status and Information - May 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
D Calibration Requirements for AS9100 Rev C Calibration Frequency (Interval) 5
Sidney Vianna AS9100 Rev.D - The revision work has started AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A AS9100 rev C Skill Examiner Audit to complete my RABQSA Auditor certification Career and Occupation Discussions 3
J Corrective Action Review - AS9100 Rev. C Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N Meeting AS9100 Rev C Requirements - Major help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
D We received our AS9100 Rev C. certificate! Thank you! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Implementing AS9100 Rev C - Electrical Harnesses and Cable Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9100 Rev C QMSM (Quality Management System Manual) Template Required AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100 - Upgrade to Rev C - Design & Manufacturing Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Please recommend preparatory reading for AS9100 Rev C Lead Assessor Course AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
D New to AS9100 and have a REV C Audit scheduled in Feb. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S Is it required to upgrade an AS9100 B Procedure Manual to AS9100 Rev. C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M AS9100 Rev C - Determining, Providing and Maintaining" Infrastructure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Audit Days Requirement for AS9100, Rev C Re-Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
