AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ
  • Thread starter Christopher Doherty
  • Start date
Christopher Doherty
"the basis of recognized statistical principles", gentlemen as a quality manager of a machine shop we state and use ANZI/ASQC Z1.4 level II AQL 4 as a vehicle for accepting received or shipping final parts. The auditor has NCR'd me for not defining the Machine inprocess frequency per ANZI/ASQC. My inprocess inspection reports say 1 out of every 5, in most cases, which ironically exceeds our standard AQL, in others where i know i have heavy tool wear or previous issues i have used 1 out of 3 or even 100%. To clarify, this is in between machining operation not a criteria for final acceptance. Does the auditor have a case?
dsanabria
How is the NCR from the auditor worded - you might have a case for appealing because the auditor has become an expert is SPC - out of scope.
Furthermore, what is your customer requiring as far as SPC?
Christopher Doherty
The customer requirement does not extend to our internal between machining operations as i'm unaware of any that do, I meet or exceed all customer requirements for shipping. The NCR references the AS9100 spec and states "The process of defining the sampling to be used in Machining operations for key characteristics verification is not accurately defined." My procedure for sampling was defined for receiving and Final inspection. How can i justify the fact that I decided what to do and how frequently? Should i just change my internal procedure to state" the Quality Manger and engineering will determine the frequency for Machining inprocess inspect frequency? will this satisfy "based on recognized statistical principles"? I don't think so but i'm sure not going to follow a spec that doesn't relate to machining 101.
dsanabria
OK lets try this again...
Does the customer requires that you need a sampling plan? yes or no
Mike S.
Happy to be Alive
"the basis of recognized statistical principles", ... we state and use ANZI/ASQC Z1.4 level II AQL 4... The auditor has NCR'd me for not defining the Machine inprocess frequency per ANZI/ASQC.
First, not having the auditor's exact wording for the NCR makes it difficult for us to assess, as does the limited context you provide.
However, IMO, the clause you mention states you monitor and measure at "appropriate stages". You, not the auditor, determine those appropriate stages.
Further, if you use sampling inspection for product acceptance, select your sampling plan "...on the basis of recognized statistical principles...matching the sampling plan to the criticality of the product and to the process capability."
Can you explain how and why you chose your sampling plan? Did your customer set the sampling rate/plan? Did you look at OC curves and process capabilities and consider the criticality of the parts and what would/could happen if a bad part made it through your sampling? You would want a different inspection plan if you were doing final inspection on artificial heart valves than if you were making water valves for sale to consumers at Home Depot.
Sidney Vianna
Post Responsibly
I know of, at least, one very large aerospace OEM which does not allow suppliers to use sampling inspection, unless formally authorized by them after their own assessment. Their actual requirement reads:
Seller's Inspection Requirements: Seller shall perform 100% inspection for in-process and final inspection, or Seller shall conform to requirements of document D1-8007 "Requirements for Supplier Statistical Plans" as may be amended from time to time. With the exception noted herein Seller‘s statistical sampling procedure/plan
conformance to D1-8007 will constitute Boeing Quality approval.
Note: Any characteristics identified in the design documentation as "Safety" or "Critical" (or "Safety Critical," et al.) characteristics shall not be accepted using statistical product acceptance methods unless prior written authorization is granted by the specific Boeing design authority, or the method for acceptance is specifically defined in the design documentation. A "Safety" or "Critical" (or "Safety Critical," et al.) characteristic is defined as a characteristic designated by the design authority, where the responsibility for its definition is outside the scope of recommended practice ARP9013.
Buyer reserves the right to disallow a supplier's statistical methods for product acceptance for specific sites/ programs, parts or characteristics, and to conduct surveillance at Seller's facility to assess conformance to the requirements of document D1-8007, available at Boeing Authentication within the "Supplier Quality" webpage.
Sampling inspection must have the risk based thinking treatment. Characteristics, criticality, process maturity, complexity, etc..all should be asssessed prior to determining if sampling is allowable and, if so, what AQL and Acc/Rej criteria.
Is D1-8007 an implicit requirement to PO note Q33/D6-84279? I'm still a newbie to aerospace, still waiting on my BSCP access, have met with my Supplier Quality Rep last week and things went well, but don't want to start peppering him with (likely) dumb questions... really need to get that access and get my head around the CSRs for our customers...
Thanks in advance!
Mike S.
Happy to be Alive
Boeing does not flow D1-8007 on all PO's. We have some Boeing jobs where it is specified, and some where it is not.
Christopher Doherty
Of course, as ive stated already for "we meet or exceed all customer requirements"
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R AS9100 REV D gap analysis matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
bryan willemot Documenting past problem history for fasteners for AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Definition of "Sensitive Products" Clause 8.5.4 (c) in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
S General Awareness Training for AS9100 Rev.D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P How To Transition From AS9100c to AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P AS9100 rev D Quality Manual wanted - 2017 Quality Management System (QMS) Manuals 4
A AS9100 Rev D - Procedure for Product Safety & Control of Counterfeit Part (Format) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9100 Rev. D - Question about 8.4.3 (k) - Supplier Certificates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D Transition Audit - Number of Audit Days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100 Rev.D Transfer of Work - Procedure and form templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
B AS9100 Rev D - Traceability of Consumables AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
K AS9100 Rev. D Transition - Internal Audits & Gap Analysis Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100 Rev D Quality Manual - How are you organizing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Design and Development Procedure example and Template wanted - AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Guidance and/or assistance on Transition to AS9100 Rev D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Mikishots Definition Issue - "Issue" vs. "Risk" in ISO 9001:2015 and AS9100 Rev D (Definitions) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
Kronos147 Quality Manager's Role in AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
T What is the Rev C equivalent for an RABQSA AS9100 Certified Lead Auditor course? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
G AS9100 Rev. C - Records created and/or maintained by Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
F Gap Analysis Matrix for AS9100 Rev C to TS16949:2009 IATF 16949 - Automotive Quality Systems Standard 1
R AS9100:2016 Rev. D - Status and Information - May 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
D Calibration Requirements for AS9100 Rev C Calibration Frequency (Interval) 5
Sidney Vianna AS9100 Rev.D - The revision work has started AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A AS9100 rev C Skill Examiner Audit to complete my RABQSA Auditor certification Career and Occupation Discussions 3
J Corrective Action Review - AS9100 Rev. C Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N Meeting AS9100 Rev C Requirements - Major help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
D We received our AS9100 Rev C. certificate! Thank you! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Implementing AS9100 Rev C - Electrical Harnesses and Cable Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9100 Rev C QMSM (Quality Management System Manual) Template Required AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100 - Upgrade to Rev C - Design & Manufacturing Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Please recommend preparatory reading for AS9100 Rev C Lead Assessor Course AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
D New to AS9100 and have a REV C Audit scheduled in Feb. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S Is it required to upgrade an AS9100 B Procedure Manual to AS9100 Rev. C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M AS9100 Rev C - Determining, Providing and Maintaining" Infrastructure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Audit Days Requirement for AS9100, Rev C Re-Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Upgrade Audit vs. Reassessment Audit (AS9100 Rev B to Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
