AS9100 Section 8.4.2 - External provider test reports
lorenambrose
Quality Assurance Manager
Regarding the requirement below, how could I address this?:
Section 8.4.2
When external provider test reports are utilized to verify externally provided products, the organization shall implement a process to evaluate the data in the test reports to confirm that the product meets requirements. When a customer or organization has identified raw material as a significant operational risk (e.g., critical items), the organization shall implement a process to validate the accuracy of test reports.
We provide product X:
1) We completely outsourced the D&D. We have NO hardware or software engineers on staff.
2) Our product X is completely manufactured by an external PMA manufacturer (not the D&D org). Our organization does not manufacture and has no PMA certification. All product X is received with an 8130-3 Airworthiness Certificate from the PMA manufacturer.
3) We do not buy any materials for production.
4) The finished product X is received by an EXTERNAL logistics provider that provides receiving, inventory, order aggregation, packaging, and shipping functions.
5) we literally never physically handle product X ourselves.
I am a bit stuck on this.
Randall Beck
We are design exempt in our processing functions so we only follow outlined specifications and test accordingly in house to verify, so I certainly am looking forward to any input from more experienced others. Just to ask a couple specific questions about the worst case scenario to help others understand your issue better, if your product X failed in the field or did not meet the requirements of safety, color, form, fit or function you advertise or claim it can/does, how would you know if you never see it first? Do you at least perform periodic audits of your supplier or just completely rely on the 8130-3 Airworthiness Certificate from the PMA manufacturer?
lorenambrose
We do manage the supply chain properly and we do have some of the product X in our lab for system testing. As a PMA article, form, fit, and function are very closely managed between us and the manufacturer. Design changes all go through is but we do not actually do any of the development work in-house.
I should mention that we do test the design and verify that it meets our system requirements. DO-160 is part of that.
Sidney Vianna
Post Responsibly
You outsource pretty much everything, so you obviously have to flow down all the proper requirements to the involved parties, such as the (PMA) supplier to comply with all of the applicable requirements, including the verification of test reports and raw material certs.
As a side note, I wish the IAQG would heed to one of my suggestions and follow the IATF model that only manufacturing plants could be certified.
As in this case, companies doing "brokerage services", having products directly shipped or directly delivered to customers should not be eligible for AS9100 certification, IMO. The chain of accountability can get lost very easily.
lorenambrose
We do rely heavily on outsourcing and in some ways act as a giant program management office. All requirements are flowed down and activities are verified via, auditing, performance indicators, etc.
darkopsghost
You still have Trace and Retention requirements.
We are an AS9110 FAA/EASA Repair Station with a Permissible Design Exclusion, but before we split, our company was also AS9100, AS9102, and NADCAP certified.
When you receive a product in, it should be as simple as how the Trace is reviewed, by whom, and how those Trace documents are stored and the retention time of those records. This would be true if you had Design & Development, were Manufacturing, or just kitting parts.
One thing I might add... the FAA, DCMA, and your Prime or other Customers will want to see how you select and control Special Processors. I keep it simple by using Prime Approved sources whenever I can and I record all of them in a log with their capabilities. if they are not Special Processors, just identify that they are COTS. Things like Commercial Off The Shelf (COTS) and Time & Temperature Sensitive items (TATS) which have a Shelf Life still have the same Trace requirements and TATS will require some sort of control log and all will require identification to insure proper usage and what to do with expired product.
Military will require separate holding areas from Civilian and all will require some sort of Red Tag system to identify Product Non-Cons. We also buy from the OEM when we need an article so we don't have to worry about Counterfeit Parts and how we handle them if ever discovered.
darkopsghost
Can you get certified to AS9102?
I know 9102 is invoked by 9100 and 9110, whether there is an actual certification for it, I will have to leave that to someone more knowledgeable than myself.
Working with the Military, they can't force you to do something outside of your normal day to day so it is acceptable to just be "compliant".
The Primes on the other hand can force you to become ISO/AS, NADCAP certified through a P.O. Clause or a Supplier Statement of Work (SSOW). By doing some negotiation, you can work to a Letter of Deviation but that only works for so long while you are getting set up, audited, and become certified. It boils down to Swim or Get Off The Ship and you loose any chance of getting new or run-on contracts. They have you by the Registrar if you would.
I do know there is training available and they sell that training as if it was something a company could achieve, I just can't remember for sure it it was a ride-on or that we actually had a separate cert. I'm thinking we might of had an actual cert. Been too long and all of that could have changed too.
DarkOps
DarkOps
For the record, there is no certification available for AS9102, Also AS9102 is not invoked by AS9100 or AS9110. AS9100 requires production verification of a representative sample of the first production run. The note (which is not auditable) following that statement says this activity is often referred to as first article inspection. This clause is only two short paragraphs.
AS9102 is much more involved comprising of some 20 or so pages. It specifies the forms to use and provides instruction on how to fill them out. It can be required by customers, but it certainly isn't mandated by either AS9100 or AS9110.
darkopsghost
What I should have said is that it is invoked by the Customer, but the use of the proper forms and proper usage of those forms are invoke by AS9102 itself.
and a 9102 does not have to be 20 or so pages. I have completed plenty that are only 3 pages...Part Number Accountability, Product Accountability, and Characteristic Accountability. There does have to be Objective Evidence unless that's what you are referencing. Most of our contracts are Repair so there is no FAI requirement ever nor do we have to worry about FPQ any longer either.
W Tying the need for Demand Planning to a section of AS9100/9110 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Complying with AS9100 D Section 8.4.3 m. Ensuring that persons are Aware of... AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
D AS9100 section for Warehouse/Preservation of materials? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
E AS9100 Section 7.6 - What is the meaning of "check method"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS9100 (FCA / PCA) of section 7.1.3 - Configuration Management - Audit question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Definition Recall - Definition of AS9100 Section 7.6 F for Recall Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
E AS9100 Section 7.4.3 Test Validation for Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A From ISO9001 to AS9100 Section 7.3 - Presentation to our Development and Design group AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E AS9100 section 7.6 "D" - Equipment shall be safeguarded from adjustments General Measurement Device and Calibration Topics 17
B AS9100 Section Applicability for a Design Center's Technical Publications Design and Development of Products and Processes 2
G Nuclear - ASME Section III N-Stamp - Requirements over and above AS9100 and ISO 9001 Various Other Specifications, Standards, and related Requirements 12
J AS9100 A - Small aerospace company - What section do I follow? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
U Scope of approval portion of AS9100 section 4.6, 04 (AS 9101, sec 4.6.2, Q4) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P AS9100 and Raw Material Traceability AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS9100 examples of procedures, quality manual, etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O AS9100 8.4.3 Supplier Terms and Conditions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100 Supplier Audit Checklist example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Design Authority questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9100:D Counterfeit internal audit questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q AS9100 Counterfeit Parts Prevention/Mitigation Work Instruction? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B SPOC 001/SPOC 002 AS9100 FAIR REQUIREMENTS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Do all products fall under scope of AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9120 to AS9100 due to value added activities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
