AS9100 Shop Travelers - Six Questions
#11
As I said earlier, router/travelers vary tremendously in format and details. I've seen documents like those which identified the actual production equipment and fixtures that needed to to be used for a given operation. In such cases, if a specific machine is down, and the operation can be performed in another production equipment, the authorization for temporary deviation (redlining) is perfectly acceptable, as long as it is done by authorized personnel with the knowledge to allow the change.
My point is: It's the PLAN. I'm not debating content. I'm commenting on purpose and what appears to be an ineffective one at that...
CASHIB
#13
Thanks to all for the input.
Will present them to management who is allowing random changes, on a job to job basis, to a controlled traveler.
:D:applause:
#14
And I am saying that the plan sometimes cannot be executed and revising the document via authorized redlining is totally acceptable.
In which case, having a formal method of documenting the change and reason - and not the ad-hoc changes the OP mentions - should be used to refine the planning process. As we know, it's not strictly a document control issue - that's the mechanism - and some analysis should be done on why the plan has to undergo such changes.
Tyler
#15
AS9100 D 8.5.6 said:
The organization shall retain documented information describing the results of the review of changes, the person(s) authorizing the change, and any necessary actions arising from the review.
Can redlining be as simple as writing changes with a pen and authorizing it with a signature or stamp, or does there have to also be a record of the review?
Kronos147
#16
Yes. It's enough to demonstrate it was reviewed.
The standard also talks about responsibility for making the change. The person making the change needs to have the authority to do so.
E Small one man shop with QMS (shoptech e2) | AS9100 cert help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 46
D AS9100 Routing (Shop Traveler) requirements per 7.5.1 g and h AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Start Up of a small AS9100 Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Current Inspection Standard for AS9100 Certified Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 Shop Moving to a New Location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
O NET-INSPECT is it worth it? Small Machine Shop doing AS9100 Quality Manager and Management Related Issues 8
K Job Shop - Registering to AS9100 vs. ISO 9001 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 27
S Does all work in a shop need to meet AS9100 standards in order to be certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
D AS9100 Design - Machine shop offering Drafting Services? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Contract Machine and Fabrication Shop - AS9100 Exemptions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Is SPC a requirement of AS9100? Small Machine Shop and Assembly AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Requirements for AS9100 Contract Machine Shop in FAA Certification Process Federal Aviation Administration (FAA) Standards and Requirements 2
D Separating Customers not requiring AS9100 - Sheet metal and machine job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Legacy products in an AS9100 QMS precision machining job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J ISO 9000 vs. AS9100 in a Local Fabrication and Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
