AS9100 Tooling Purchasing Process
Deburr
I am in the process of writing my QMS for AS9100C certification. I am a service company that preforms material removal operations (deburring and blending/polishing only) and uses no subcontractors and no raw materials or commodities that are incorporated/integrated in the finished product.
We buy off the shelf tooling we specify by standard catalog descriptions (abrasive products and carbide burrs/cutters). Many of these items are proprietary in the composition of the abrasive mix or coating and none of these items are made by companies that claim conformance to a specific industry standard. Example: 3M is listed in IAQG OASIS for the tapes and adhesive products used in aircraft assemblies, but the abrasives divisions are not listed.
Section 7.4 seems to deal mainly with subcontracting, and I find it difficult to apply all the requirements of that section to a company that makes sand paper and sells it through a distributor to my company, especially when it comes to testing abrasive products that goes way beyond our expertise. I understand the subtier manufacturing part of that section and we do none of that. How do other companies deal with the design, test, inspection, verification, spc, and related instructions for the supplier of sandpaper?
P
Phiobi
In short: You don't need to. You as a business decide to what level you control your suppliers. If they are deemed low or no risk to product then you can consider these low risk companies and maybe just monitor their performance with regards to quality and delivery.
I don't know where you got that narrow interpretation from. Let's look at the opening statement from 7.4.1:
"The organization shall ensure that purchased product conforms to specified purchase requirements."
Do you not confirm that you obtain the materials that help you with your deburing operation will meet your needs, or do you use anything and end up messing up the parts?
The next statement covers what the last poster mentioned:
"The type and control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product."
What you have described that you are purchasing simply doesn't require much scrutiny, but some is needed to ensure that you don't mess up the final product.
How difficult can it be to list those suppliers, indicate that you have approved them, and indicate that they are currently approved? It should be very easy.
You do need to think how the rest of 7.4 applies to you, but it should be very easy, as what you buy has minimal impact (unless you get crazy) on the final product.
Deburr
I should have added more supporting information to my question.
I do not a a problem with7.4, 7.4.1, or 7.4.1 a),b),c). I have all that. I think even d) is easy enough to address by listing the catalog description which includes for ( using my sheet of sand paper for example) the part number and size of the item, size and grade of the grain, and type of grain, and maybe even the type of bond.
It is how to address the requirements of e), that was my question.
When the material comes in, it is easy enough to check the quantity of the sheets and look at the back to see what the size of the grain and type that is printed on the sheet. But how do I verify that what the sheet has printed on it is actually what is on the sheet. We have no way to verify ( and I doubt most companies do) that the material is what it should be. If 3M does not make any statement that they conform to AS9100 or to some recognized authority, how is an auditor to know that even a C of C from them has any value? Just because they do millions in sales or they claim to be an industry leader? I could do the same, but it doesn't carry any weight with my customer that wants AS9100 certification from me.
So my question is still, how do other companies address this? Not having any experience with an AS9100 audit yet, I'm concerned about just how far does the scrutiny go?
Deburr
Big Jim
In looking at your reply again, I think the key is your quote from the standard-"The type and control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product." That gives me a good argument for the way I plan to approach 7.4.3. Thanks again.
Unless you have a customer requirement for material certs, you don't need them.
That doesn't mean you should not be diligent about checking the materials as best you can. You use the same stuff day after day and I'm sure you would notice a sudden change in grit size or color.
And again, that is why you use trusted suppliers, suppliers that you know will consistently deliver what you need.
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V Application of AS9100 clause 7.5.1.1 - Tooling Supplier AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 Section 8.4.2 - External provider test reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Can we combine AS9100 and DO-254 certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A AS9100 - 7.1.5.2 In-House Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Transferring AS9100 to new Legal Entity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Lapse in AS9100 Certificate AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100 News AS9100 Rev. E? Any news? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 45
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
