AS9100C Clause 8.2.4 Monitoring and Measurement of Product
dsanabria
2 Question on the interpretation of:
"AS9100C 8.2.4
Measurement requirements for product acceptance shall be documented and shall include
d) any specific measurement instruments required and any specific instructions associated with their use."
What is a good definition of SPECIFIC MEASUREMENT INSTRUMENT
when do we stop writing specif intruments in the final report?
W
w_grunfeld
In my opinion what is meant here is any special purpose built measuring/checking equipment that is not a commercially available COTS
Mike S.
Happy to be Alive
In my opinion, if a specific instrument is to be used, whether COTS or not, you need to list it.
If only an Acme Model 1234 LCR meter is to be used for a given measurement, and an Agilent or other brand LCR meter would not be acceptable for some reason, you would state that only the Acme 1234 is to be used.
If the Acme 1234 is only to be used with a certain test voltage, you would state that.
If the Acme 1234 or any similar LCR meter can be used, you might list the Acme 1234 or equivalent, or you might list the make/model of several acceptable units.
Does this make sense? Does it answer your question?
Mikishots
"AS9100C 8.2.4
A specific measurement instrument can be an item that has been certified for specific use in order to show compliance. An example: An aircraft scale for weight and balance reports. In my workplace, we have a set of scales that is certified by Measurement Canada in order to be accepted for use under Transport Canada rules. We have to identify the make, model, serial number and last certification date of the scale whenever we use it for W&B measurements. We also have formal instructions for using them.
A more general example would be a conformity measurement that can only be made by a purpose-made tool or a tool that has a particular degree of accuracy require.
Not sure about your question regarding "stop writing specif requirements in the final report". I don't know what you're asking.
dsanabria
OK - the background....
Many top Aerospace companies would make a request to meet AS9102 requirements. Then they ask to complete "their" AS9102 forms. Those form are similar to AS9102 except for form 3 block 14. These blocks have additional requirements. The customer is requiring that the customer provides the specific measuring instrument that accepts the final product.
Once they have done that, they also want you to submit a quality plan that demonstrate measuring devices that accepts the product (AS9100C element 8.2.4d) during the production process.
Furthermore, they do emphasize that this is done in order to demonstrate effectiveness of the inspection process and to enhance the recall process of product more effective.
The logic is that once a complaint against a product is determined - the supplier should be able to go and find the affected measuring device that accepted that product AND to identified which other products were also accepted with that specific measuring device.
Thus the question....
"When do we stop writing specific measuring instruments requirements in the final report" - ex.. micrometer, vernires plug gages etc.
Mike S.
Happy to be Alive
If I understand correctly, it sounds like your customer wants you to always record the measuring device used for any recorded measurement. But without seeing the exact requirement, I am only guessing.
Why not just ask the customer exactly what their expectation is?
dsanabria
I did - and yes the big guys want that information for recall purposes of the products and identification of other affected products accepted with the specific measuring instruments.
Thanks for the inputs.
Kronos147
...information for recall purposes of the products and identification of other affected products accepted with the specific measuring instruments.
Funny, that discussion came up in an internal audit yesterday. Specific tool ID on the 9102 form. Double edged sword:
1) Can limit your exposure and scope of recall if that tool is found to be out of calibration
2) Can lead to ticky tack findings where the ID was skipped on the report
dgriffith
Yes, reverse traceability. This from AS9100C, paraphrasing:
(SAE) AS9100C, 8.3 Control of Non-Conforming Product, (d): by taking action appropriate to the effects of the non-conformity when detected. (e): by taking actions necessary to contain the effect of the non-conformity on other processes or products.
This is for the recall of product in case the instruments you used were found non-conforming during recalibration.
A good reason to use a check standard with data tracking, so if that occurs, you need only recall product from the last known time the instrument was good, instead of an entire year's worth.
dsanabria
?(SAE) AS9100C, 8.3 Control of Non-Conforming Product, (d): by taking action appropriate to the effects of the non-conformity when detected. (e): by taking actions necessary to contain the effect of the non-conformity on other processes or products.
Thanks - I will continue to write every Specific Measuring instruments so that I could also meet the requirements of 8.3 d & e.
Q Interpretation of Clause 7.1 Planning Of Product Realization in AS9100C standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Buckyb AS9100C Clause 7.4.1 Appoved Supplier "Conditional" Status AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G AS9100C Clause 4.1.1 Requirements Clarification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A AS9100C Clause 7.5 Applicability for Design House AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Exclusion of AS9100C Clause 7.1.1 and Clause 7.1.3 for a Small Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Different types of Design and Development - AS9100C Clause 7.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J AS9100C Clause 7.4 - Supplier Delegation - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
Q AS9100B Clause 7.5.1.5 - Where did it go in AS9100C? Servicing/Post Delivery Support AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9100C Clause 6.1 Provision of Resources - New employees as Preventive Actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Personal Data as it pertains to clause 7.5.4 of AS9100C - Definition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R AS9100C Clause 7.3 Design & Development - Designing a System and Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J AS9100B vs AS9100C - Clause 4.2.2 - Relationships between requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
P How To Transition From AS9100c to AS9100 Rev. D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Nonconforming product AS9100C, 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100C to D - Has anyone done a gap analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AS9100C 8.2.2 - Selected Tools & Effectiveness of IA Process and Performance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100C 7.5.1 Control of Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W AS9100C Process based manual Design and Development of Products and Processes 4
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A AS9100C to AS9100D Transition Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Need help on QMS Development in an AS9100C certified organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I AS9100C Lead Auditor Training Courses being Cancelled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q What are the differences between ISO 13485 vs. AS9100C ISO 13485:2016 - Medical Device Quality Management Systems 3
W Certification on AS9100C - FAI or PPAP? Project Management or APQP? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
A AS9100C Out Of Tolerance (OOT) Equipment - Customer Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B AS9100C 7.5.1 d and calibrated equipment in the production areas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100C Processes which need to be documented AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W AS9100C/ISO9001:2008 Dual Certification (to both standards) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A AS9100C. 7.1.2 Risk Management - Interpretations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W AS9100C registration - How long does the system have to run before initial audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I Guidance for Transition from ISO9001:2008 to AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS9100C Quality Policy Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M AS9100C Document Control for Machine Set Up Work Instructions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
alonFAI Update an existing QMS manual or write a new one for AS9100C Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9100C "Split" Audit Stages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Is instrument ID required in the in-process inspection report per AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D AS9100C 4.2.3 - Obsolete Electronic ERP Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Auditing AS9100C Section 7.5.1.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Adding AS9100C Lead Auditor Certification to an IRCA ISO 9001 LA Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D AS9100C - New requirements to existing standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K AS9100C for Non-Aerospace Military Equipment? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K How Can I Implement the Process Approach in AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Q Basic questions about AS9100C Quality Standard Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Number of Audit Days for AS9100C Surveillance Audit (20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9100C 8.2.4 a-d Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Documented procedures requirements for AS9100C requirement 7.5.1 a) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A AS9100C 7.4.3 Delegation of Verification (to a supplier for a specific circumstance) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AS9100C Complete Internal Audit Software Package Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
