AS9100D 8.4.2 Note 2 Significant Operational Risk
"When a customer or organization has identified raw material as a significant operational risk (e.g., critical items), the organization shall implement a process to validate the accuracy of test reports"
2 questions on this.
We are a material distributor/supplier moving from AS9120 to AS9100. How is "Significant Operational Risk" understood?
My understanding as a material provider is that the customer would identify this as "Critical" or "High Risk" etc in the purchase order.
Otherwise it seems this is more applicable to a machine shop that is making components to print, where the raw material is called out as a critical characteristic on the drawing. Does this sound about right?
Also, what would a "Process to validate accuracy of test reports" look like? I would think it would mean sending material to an independent lab to be tested to show that the chemical and mechanical properties meet the requirements as stated on the suppliers test report or C of C.
Am I understanding these requirements correctly?
This is not part of Note 2. This is a continuation of 8.4.2 AFTER the note. The reason that is important is that notes contain no shalls and are not auditable. They provide illumination and help with understanding.
This last portion of the last paragraph has some interesting history. The concept was part of AS9100B, was removed in AS9100C with some controversy. Reported was removed because it wasn't well understood and wasn't well applied. Typically a company would select a few samples each year and send them to a lab to confirm the material matched the material certs provided by the mill. Basically it was a waste of time and money.
Boeing wasn't happy with removing it but went along with it say that if they wanted material validation they would say so in their purchase orders. A few months later Boeing added it to their terms and conditions anyway.
It came back in AS9100D, but with a twist. This time instead of periodically sending off samples the determination to do so is based on risk. Significant risk is defined here as critical items. What is a critical item can be identified by either the customer and you, the organization. When significant operation risk (determined that something is a critical item).
As to how this would apply to a material distributor, I suspect that it would seldom apply, but you need to be aware that it could.
As for the first sentence (I wish they would have been separate paragraphs so they would not so easily mixed up), that entails checking certs on incoming material to confirm that you got what you asked for, something that should be routine anyway.
Also be aware that with the upcoming changes to enforcement of determination of which standard you can get registered to, a distributorship may not be able to move to AS9100.
LincolnQA AS9100D, Clause 8.4.1.1d - actions to take when external providers do not meet requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
T AS9100D Work Transfer Plan Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Company AS9100D External Audit Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
T AS9100D Risk-Based Internal Audit Schedule AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
C AS9100D to CMMI Dev 2.0 Mapping & Comparison Matrix Software Quality Assurance 1
H AS9100D Exclusions, if Not Excluded Is it Automatically Applicable? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F Surveillance Audit for AS9100D and new ERP system incorporated Document Control Systems, Procedures, Forms and Templates 4
Q Purchasing Clauses in AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Quality Specialist AS9100D Approved Supplier List requirements and how to apply Supplier Quality Assurance and other Supplier Issues 11
T Combining 2 companies with separate AS9100D certificates! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100D 8.5.1.3 First Article AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Stefan Mundt AS9100D Engineering sample purchases - Supplier not approved AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A AS9100D new certification cost?? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Moving from AC7004 to AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
I RCCA per AS9100D 7.5.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
M Best accreditation body for AS9100D Lead facility auditor? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A What To Clauses Exclude - AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F AS9100D Internal auditing requirements Internal Auditing 11
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100D -8.5.1j - Accountability For All Products Tiny Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Free downloadable AS9100D audit checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
DuncanGibbons Why is 8.4 post-delivery activities before 8.6 release of products and services in AS9100D? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100D 8.4.1.1 external providers question - Walmart, Home Depot, our lawn care team. etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
W Core Process Metrics AS9100D for Product Planning? Quotes and sales? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M AS9100D Competence and Training Records - X-Ray AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Claiming exemptions (N/A) in AS9100D - what is the methodology and location? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
