AS9100D Approved Supplier List requirements and how to apply
Quality Specialist
Hello quality friends!
I have been conscripted to be the one who is responsible for the Approved Supplier List and metrics of our suppliers/vendors. I have never done this before and questions have arisen since our AS9100D 3rd party audit last week. The auditor discovered that we had two companies we purchased items from for assembly in which these two companies were not on our approved supplier list.
My question is this. Our company buys numerous small parts such as screws, kaplon tape, loctite, copper wire, etc., for examples, all of which are used in the build and assembly of a customer designed products. Sometimes it is a one time purchase and sometimes we purchase these items more often.
So, in having no previous experience with being the one who maintains and updates the AVL, I don't really understand if all of these suppliers need to be on our AVL or just the ones who play a more critical role. Oh sure, I get that our outsourced calibration vendors are a critical supplier and why they need to be on the list but what about when they order from Amazon for tinned copper wire or eBay for screws and such? How much control do we need to apply to these types of vendors IAW AS9100D?
Quality Specialist frustrated in Oregon.
P.S. I am the sole employee in the quality department for a small company (10 employees total).
Michael_M
As I remember it, if the vendor supplies anything that goes into the final product, then they must be on the AVL. So things like hand soap most likely will not need to be on an approved vendors list but if you use bolts in the product, who you purchase the bolts from do. The control is up to you but I will really look at having good controls or you will continuously have issues. One way that may help: Find two or three vendors that supply most of the stuff and use those two or three. You may find that you can get Loctite from multiple locations but does company A keep track of expiration date? Are you getting older bottles that may be past their shelf life? Again, this is just an example but things that need to be looked at.
mattador78
Biggest ache is when you can only use the customers approved product and there is only one supplier so no matter how poor they are they ahve to be approved, thats a pain i have to deal with.
Quality Specialist
I suppose for "non-critical" suppliers who supply items such as Loctite or screws wouldn't need as much control as they can be obtained from different vendors if need be. We have incoming inspections to assure that product received is accounted for against the PO and conform to requirements that we convey. In the case of Loctite, you bring up a good point, for example, we check the expiration dates then place a label on them showing the expiration date so as not to use expired product and in addition, operate on the FIFO program (first in, first out) I do this for our fridge at home each week too :geek:
bryan willemot
If you go over clause 8.4.1 in AS9100D it should tell you in there, the proper how to... your Quality manual also should follow the provisions of AS9100D and should have similar guidance in there but more specific to how you handle the vendors. we are a company of 50 and any PO we cut to vendors better be on our AVL. our materials manager and myself being the QC manager manage the AVL. officemax is not on our AVL because we buy pens and paper from them and cut PO's but Granger is on the AVL when getting hand soap and such products. its a judgment call as to who to put on the AVL and who not to put on the AVL, i'm sure after an explanation to your 3rd party auditor they would understand. BTW we categorize our vendors if they are critical or non critical and we use risk management as well (prime example for risk management would be the situation
mattador78 is dealing with).
Quality Specialist
Hi Bryan, your input is straight forward and makes sense. We have an AVL that categorizes our vendors from critical to not critical. I've decided to include all current and future suppliers that impact product and processes on the AVL. I have found quite a few by looking at the receiving log which were not on the list - controls will be by evaluation of risk. I'm not going to put our suppliers from whom we order office supplies and other day to day necessities such as paper towels, toilet paper, coffee, water, etc.
bryan willemot
Just Remember, as the QC Manager, you MUST qualify vendors to be put on the approved vendors list, if you look at my attached approved suppliers list you will see a qualification method. that can be as easy as sending the vendor a questionnaire, or going and doing an audit. or if they are certified AS9100D or ISO 9001 then you certainly can use that as the qualification method. but if its a fire alarm company that comes in and checks your plant for the expired fire extinguishers, if it has no direct quality impact then you just need to annotate it on the AVL. just remember the qualifications should be the following :
1.) Audit (must pass without major Non-Conformance)
2.) Survey (Send to them, they fill it out, and if you have questions you can go there and audit or ask to clarify your questions)
3.) Certs (AS9100, ISO 9001, or NADCAP...and if it is NADCAP then I usually do a survey as well as the NADCAP Cert (Bad Experience with a certified NADCAP HT))
Stefan Mundt AS9100D Engineering sample purchases - Supplier not approved AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T AS9100D Work Transfer Plan Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Company AS9100D External Audit Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
T AS9100D Risk-Based Internal Audit Schedule AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
C AS9100D to CMMI Dev 2.0 Mapping & Comparison Matrix Software Quality Assurance 1
H AS9100D Exclusions, if Not Excluded Is it Automatically Applicable? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F Surveillance Audit for AS9100D and new ERP system incorporated Document Control Systems, Procedures, Forms and Templates 4
Q Purchasing Clauses in AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Combining 2 companies with separate AS9100D certificates! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100D 8.4.2 Note 2 Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D AS9100D 8.5.1.3 First Article AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A AS9100D new certification cost?? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Moving from AC7004 to AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
I RCCA per AS9100D 7.5.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
M Best accreditation body for AS9100D Lead facility auditor? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A What To Clauses Exclude - AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F AS9100D Internal auditing requirements Internal Auditing 11
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100D -8.5.1j - Accountability For All Products Tiny Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Free downloadable AS9100D audit checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
DuncanGibbons Why is 8.4 post-delivery activities before 8.6 release of products and services in AS9100D? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100D 8.4.1.1 external providers question - Walmart, Home Depot, our lawn care team. etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
W Core Process Metrics AS9100D for Product Planning? Quotes and sales? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M AS9100D Competence and Training Records - X-Ray AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Claiming exemptions (N/A) in AS9100D - what is the methodology and location? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
