AS9100D Clause 7.5.2.a) - What is considered to be "documented information"?
Kokolita
What is considered to be "documented information" as it pertains to para 7.5.2.a?
Do these type of postings have to be on our master forms list?
Mens bathroom cleaning sign-off form?
Internal telephone list with extensions listed?
Informational postings? (ie: in the shipping area: "Verify an ITAR stamp is used for the following jobs")
Sign near the fax machine (rapid dial shortcut numbers)
We have papers we print out to put on completed jobs that states, "DONE".
Any help in what needs to actually be given a form number and retained on our master doc list would be great!
Thanks in advance for your input.
The answer is a little above where you are looking, in 7.5.1 a & b.
"The organization's quality management system shall include . . . documented information required by this International Standard . . . documented information determined by the organization as being necessary for the effectiveness of the quality management system . . "
So if it isn't required by the standard and your organization have not determined there is a need it looks like control isn't needed.
Mens bathroom cleaning sign-off form - doesn't look like a need for you system to me.
Internal telephone list with extensions listed - also doesn't look like a case could be made for being essential to your system to me.
Informational postings - in some instances I think a case could be make that they need to be controlled.
FAX machine instructions - doesn't seem likely to me.
DONE labels - some instances I think that should be controlled.
Others may have other opinions.
Sidney Vianna
Post Responsibly
Documented information, in the context of a quality management system is any piece of command media that can affect product conformity and/or customer satisfaction, as well as evidence that required operations, activities, etc. have been performed. Examples:
− Organization charts
− Process maps, process flow charts and/or process descriptions
− Procedures
− Work and/or test instructions
− Specifications
− Documents containing internal communications
− Production schedules
− Approved supplier lists
− Test and inspection plans
− Quality plans
− Quality manuals
− Strategic plans
− Forms
On the records side,
  • Documented information to the extent necessary to have confidence that the processes are being carried out as planned (clause 4.4).
  • Evidence of fitness for purpose of monitoring and measuring resources (clause 7.1.5.1).
  • Evidence of the basis used for calibration of the monitoring and measurement resources (when no international or national standards exist) (clause 7.1.5.2).
  • Evidence of competence of person(s) doing work under the control of the organization that affects the performance and effectiveness of the QMS (clause 7.2).
  • Results of the review and new requirements for the products and services (clause 8.2.3).
  • Records needed to demonstrate that design and development requirements have been met (clause 8.3.2)
  • Records on design and development inputs (clause 8.3.3).
  • Records of the activities of design and development controls (clause 8.3.4).
  • Records of design and development outputs (clause 8.3.5).
  • Design and development changes, including the results of the review and the authorization of the changes and necessary actions (clause 8.3.6).
  • Records of the evaluation, selection, monitoring of performance and re-evaluation of external providers and any and actions arising from these activities (clause 8.4.1)
Seek more guidance on the ISO APG paper related to this:
and for AS9100D specific guidance, access the document from the IAQG:
Kokolita
− Procedures
− Specifications
− Quality plans
− Quality manuals
− Strategic plans
− Forms
Thanks Sidney! This helps a lot!
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C AS9100D, Clause 8.1 - Operational Planning and Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J AS9100D Clause Brain Fade - Tool was past due for Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
A AS9100D, Clause 8.4.1.1 - External Provider Scope of Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
D Product Safety in AS9100D Clause 8.1.3 - Hazards Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
A Moving from AC7004 to AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
I RCCA per AS9100D 7.5.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
M Best accreditation body for AS9100D Lead facility auditor? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
K AS9100D 8.2.1 Review Requirements for Products and Services AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
T Transition from ISO9001 to AS9100D: O&G to Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Stefan Mundt AS9100D Major nonconformity due to recurrence of a NC during a subsequent CB audit. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100D Sampling Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A What To Clauses Exclude - AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
F AS9100D Internal auditing requirements Internal Auditing 11
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9100D -8.5.1j - Accountability For All Products Tiny Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Free downloadable AS9100D audit checklist ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
T AS9100D - Scope of QMS for New Company - Only Choosing a Function Subset Due to Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
DuncanGibbons Why is 8.4 post-delivery activities before 8.6 release of products and services in AS9100D? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS9100D 8.4.1.1 external providers question - Walmart, Home Depot, our lawn care team. etc. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
W Core Process Metrics AS9100D for Product Planning? Quotes and sales? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M AS9100D Competence and Training Records - X-Ray AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
N Claiming exemptions (N/A) in AS9100D - what is the methodology and location? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9100D implementation question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Y Time gap for First Surveillance Audit of AS9100D after initial certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
H AS9100D Cert question - Small machine shop - Where can I buy a certificate? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M AS9100d Controlling External Provided Processes (purchasing 8.4) - The customer want us to use supplier X AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
