AS9102 COTS Form 1 vs. 2
bguarino
I understand Form 1 is for unmodified, purchased COTS items to be reported, and Form 2 is for modified COTS items.
Please advise if this is correct,
Form 1: purchased 4-40 screw installed into assembly?
Form 2: raw plastic molded into the shape of a part or raw foam die cut?
A little harder...
Form 2: list a purchased blank label, but the FAI report is for the printed label version? report on form 2 or form 1?
Eredhel
Quality Manager
I might be misunderstanding your question. But form 1 is for the part number and its related information, form 2 is for that part's material, special processes, and testings information, and form 3 is for dimensional inspection information. Or do you mean something different?
bguarino
Yes a little different. For either an assembly or a component...if you look at the AS9102 FAQ guide from IAQG section C
C. Standard Catalogue and Commercial-Off-The-Shelf (COTS) Items
C1. Question:
Where is Standard Catalogue and Commercial-Off-The-Shelf (COTS) Items entered on the First Article Inspection Report (FAIR)?
C1. Response:
Standard Catalogue and Commercial-Off-The-Shelf (COTS) Items, when used as purchased, are entered on form 1. If Standard Catalogue or Commercial-Off-The-Shelf (COTS) Items (e.g., AN, MS fasteners) are modified, then list that Standard Catalogue or Commercial-Off-The-Shelf (COTS) Items on form 2, field 6.
C2. Question:
Are COTS and Standard Catalogue Item C of C required with a FAIR, for items recorded on Form 1?
C2. Answer:
The standard requires that non-modified Standard Catalogue Items and Commercial-Off-The-Self items are listed on form 1 of the FAI. Field 18 is for the FAIR number and does not require the CofC number to be recorded in this field. Since no CofC number is required to be documented on form 1 of the FAI, the CofC would not be required for supporting documentation.
So COTS items can be listed on either form 1 field 15-18 or Form 2, field 6.
My question goes to what defines "modified" in terms of modified COTS item? For example we have a printed label with 2 parts on the BOM- ink + label.
Is taking the purchased COTS label and printing ink on it considered modifying it? Should the purchased COTS label then be listed on Form 2? And the ink is listed on Form 1?
RCW
How are you controlling the modification of the COTS part? Do you have a drawing or other document stating what to do? If the answer is yes, you should have a separate FAI done against the drawing for that part.
bguarino
If you consider a printed label a modified COTS item...then yes in this case the label has its own drawing and its own report. Question is where does the raw COTS label material go? Form 1 or 2?
RCW
Hopefully I'm understanding the scenario you are describing. Here's what I'm seeing and how I have addressed this in the past.
There is a printed label that is controlled by a drawing/part number. The material used for that label is a COTS label (Dymo, Avery or whoever). I would do an FAI against the part and callout the COTS label on Form 1 under the parts list. Include the 15. Part Number and 16. Part Name. for 17. Part Serial Number that would be "N/A". Then for 18. FAI Report Number I specify the purchase order number the COTS part was bought on. This provides traceability back to who it was purchased from and depending where it was bought, there might also be a certificate of compliance along with the purchase order.
That's the way I've been doing similar items. I do see though that there is more than one way to do FAIs and I'm sure others here would support putting the COTS label callout on Form 2. In my mindset when I am looking at the "Material" on Form 2, I'm thinking items like metal and plastics which are processed to a specification. That's where 6. Specification Number would kick in.
I hope this helps. The biggest thing is that you understand and are comfortable on how you address this in your system so that you can defend your process when outside sources say you did it "wrong".
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
A AS9102 for Electronic Circuit Card Assembly that contains COTS Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B New AS9102 Rev B--CA vs UAI--purist vs. pragmatic AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 Form #3 modification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C Customer Documentation Errors when completing an AS9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9102 Requirements - What information from the PO should be included in the FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 Interpretation on Form 2 field 6 - Specification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9102 Handwritten Revisions on Ballooned Drawing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Two AS9102 Applicability and Interpretation Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9102 FAIR - Customer Drawing Revision Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
