AS9102 FAI (First Article Inspection) Form example
Bogie
Re: AS9102 FAI Form example
I customized the form into an Excel workbook so that when inspectors enter measured dimensions (Tab 3), any dimensions that are out will be highlighed in red (a lot of typos will show up too).
Obviously I only left a couple things in there to give you an idea of the set up, but when there are 200-300 measurements, it makes it a heack of a lot easier for the inspector to know where problems are before anyone reviews it.
Y
Yoyo1er
Thank you very much, Frank T. The web link has helped me a lot.:)
Lionel F.
F
Frank T.
Glad I could be of help Lionel.
BTW, welcome to the cove.:bigwave:
If you have any questions about FAI's don't be afraid to ask. Thats what were here for.
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How often can AS9102 FAI be invoked? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Al Rosen AS9102 FAI Case Outline Difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Another FAI AS9102 form question Document Control Systems, Procedures, Forms and Templates 3
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Charged for an AS9102 FAI Report when requested as part of a Purchase Order? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R AS9102 Info - Must each Assembly Component have FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Does the AS9102 FAI requirement apply to wire assembly sub-kits? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M What are the FAI requirements for an assembly? New to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Al Rosen AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J AS9102 FAI Reports. Need for Standard Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
T AS9102 Section 5.3 - FAI anytime a machinist tweaks a CNC program? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - Do I have to do FAI for all Standard Catalog Hardware items???? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L AS9102 FAI acceptance - Currently having issues getting prompt approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
M AS9102 Form 1 Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
