AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming
J Allen
I'm having a disagreement with management regarding changes to NC programming. We have completed FAIs per AS9102 but production has decided to change the NC program as well as change a work center from automatic to conventional machining. I have informed management that QC will have to perform a new FAI because several characteristics will be directly affected and the opportunity exists for the change controls the position of holes, may affect form, fit , or function. I believe that a new complete FAI is in order, they say I should do a partial as the part will still be the same configuration (no change in dimensions or revision.
How many changes would mandate a complete FAI.
Coury Ferguson
Moderator here to help
Re: AS9102 FAI Full or Partial
I agree with your Management to a point. When there are changes to dimensional characteristics via NC, a partial FAI is required to verify the characteristics that changed. A complete FAI is not required, on dimensions that weren't affected by the change, in my opinion.
Why waste manpower to perform a complete FAI when it isn't required?
alspread
Partial for the affected features only. I wouldn't go overboard. Remeber the goal of a first article to to verify the process intended to be used for production. If this change (auto to manual) is a one time thing, then just inspect the parts to be sure they conform and move on (not the intended process). But if this is intended to become the new standard production method, then a first article would be required on the affected features only.
Good luck
The Organization shall perform a full FAI, or a partial FAI for affected characteristics, when
any of the following events occurs:
1. A change in the design affecting fit, form or function of the part.
2. A change in manufacturing source(s), process(es), inspection method(s), location of
manufacture, tooling or materials, that can potentially affect fit, form or function.
3. A change in numerical control program or translation to another media that can
4. A natural or man-made event, which may adversely affect the manufacturing process.
5. A lapse in production for two years or as specified by the Customer
nismoynr
Good luck
I have 2 situation about FAIR here.
1) During Initial FAIR stage, we found a nonconformance for the part. After a few brainstorming, we claim that the tool is the cause of the defect. What we did for that part is we did a customer tag and they disposition it as UAI. What I understand is, the Initial FAIR is rejected because it have a nonconformance. For the next part, I did a delta FAIR for that particular process and still rejected. We sit with our design engineer and they said that we must do something on the tool. Since the 1st Delta FAIR rejected, I never did any Delta FAI anymore because my point of view is, we already know that we use a bad tool to produce part. What for I must re-run the Delta FAIR again and again? why not we just do a delta FAI after we 100% confirm that the new tool will give the acceptable result?
2) Continue to the situation1, prior to get a new replacement tool, we did some improvement in manufacturing process and I attach Delta FAIR for that. The report for the part is still rejected, and my Delta FAIR is failed again. After the failure of Delta Fair, I did not attach Delta FAI anymore for the next and continuous part because I know that the report is will be rejected again and it’s correct.
So, for both of the situation, Am I violate any procedure especially AS9102 to not to do the Delta FAIR for all the production part although I know that the FAIR for the part is not 100% accept yet?
can anybody answer for my questions above?
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 30
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How often can AS9102 FAI be invoked? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
A AS9102 FAI Case Outline Difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Another FAI AS9102 form question Document Control Systems, Procedures, Forms and Templates 3
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Charged for an AS9102 FAI Report when requested as part of a Purchase Order? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R AS9102 Info - Must each Assembly Component have FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Does the AS9102 FAI requirement apply to wire assembly sub-kits? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M What are the FAI requirements for an assembly? New to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J AS9102 FAI Reports. Need for Standard Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
T AS9102 Section 5.3 - FAI anytime a machinist tweaks a CNC program? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - Do I have to do FAI for all Standard Catalog Hardware items???? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 FAI acceptance - Currently having issues getting prompt approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
