AS9102 FAI (First Article Inspection) per standard or contract?
Boze63
I'll get right to the point here, which can be viewed as a bit complex.
We have been doing FAIs & FAIRs for some time now. Because of several conflicting issues, we have released an internal procedure describing our FAI process using AS9100 & AS9102 as standards & references for requirements.
Our customers purchase product and these products have a Top Level DWG. Per our procedure, we perform a "Top-Level" FAI per the dwg which includes all characteristics (dimensions, applicable testing, id marking, etc). These products or Top Assemblies have sub-assemblies but these are not identified on the related dwg, but we do list the sub-assemblies on form #1. This is clearly layed-out in our procedure.
So here are my questions:
1) If one of our customers simply requires per contract that an "FAI per AS9102" be done, does our Top Level Assembly FAI hold up?
2) Does mentioning "FAI per AS9102" force an FAI for all sub-assemblies when the top dwg does not detail them?
Thanks in advance for any help. This site may become a great source in information.....
BadgerMan
In my opinion, no.
In my opinion, yes. AS9102 requires FAI for all components and/or sub-assemblies as well. If you purchase the components or sub-assemblies, you can flow the FAI requirement down to your suppliers. If the components or sub-assemblies are "standard catalog hardware" (per the definition in AS9102) those items can be exempted from the FAI requirement.
Boze63
Thanks for the reply.
That's interesting.
The reason I say that is because I've read somewhere (don't remember where but it was on this topic...) that if a contract requires a FAIR to a part #, and that DWG reflects only the Top Level, that is the depth of where the FAI needs to go UNLESS by contract it needs to go further down.
Keep in mind that AS9100 suggests using AS9102 for guidance.
Also keep in mind that you always need to live up to customer requirements. You might try opening some dialog with your customer as to exactly what they expect for First Article Inspection.
BadgerMan
That's interesting.
If your customer requires compliance with AS9102, then the following applies.
From AS9102:
4. APPLICABILITY:
This Aerospace Standard applies to assemblies sub-assemblies, and detail parts including castings and forgings. This Standard applies to organizations that are responsible for producing the design characteristics of the product. The Organization shall flow down the requirements of this Standard to Suppliers who produce Design Characteristics.
This Standard does not apply to procured Standard Catalog Hardware or Deliverable Software.
Boze63
Well, that's pretty clear.
The only variation I can see, as suggested, is to establish with the customer if a Top Level satisfies their contract requirements.
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 35
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How often can AS9102 FAI be invoked? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Al Rosen AS9102 FAI Case Outline Difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Another FAI AS9102 form question Document Control Systems, Procedures, Forms and Templates 3
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Charged for an AS9102 FAI Report when requested as part of a Purchase Order? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R AS9102 Info - Must each Assembly Component have FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Does the AS9102 FAI requirement apply to wire assembly sub-kits? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M What are the FAI requirements for an assembly? New to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Al Rosen AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J AS9102 FAI Reports. Need for Standard Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
T AS9102 Section 5.3 - FAI anytime a machinist tweaks a CNC program? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - Do I have to do FAI for all Standard Catalog Hardware items???? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L AS9102 FAI acceptance - Currently having issues getting prompt approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
D AS9102 and proprietary info AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
