AS9102 FAI for Circuit Card Assembly - Measure each hole and document it?
Al Rosen
Holed-up in a Hotel in South Florida
I was wondering how to meet the AS9102 FAI for a printed circuit board that has hundreds of holes. Circuit boards typically contain many groups of holes. Each group is of the same size. Do we have to measure each hole and document it on the form or can we take a sample? If we must measure each hole, can we document the range of the measurement?
Re: AS9102 FAI for Circuit Card Asembly - Measure each hole and document it?
One of the problems with printed circuits is plating consistency across the board. This can cause holes to be plated more in some areas, less in others (I'm assuming you're talking of plated thru holes).
Some, by design may just be 'via' holes, others are component holes. One way to quickly assess size is to have a pin jig made, rather than individually measure all holes - since the only practical way is with a tapered hole gauge which isn't the most accurate. Once you've got the gauge you could drop a board on it periodically just to check process control.
Al Rosen
We design and manufacture to customer spec. We might build 6 to 12 pieces and may not build any more. It doesn't make much sense to do it under these conditions. Can we take exception in the case of a small lot?
Frank T.
Involved in Discussions
I know its fustrating, I do FAI's on pieces we only make one or two of.:mad:
You can take exception only if your customer agrees. Unfortunately you will still have to show compliance to 8.2.4.2 of AS9100. If your an AS registered organization.
Al Rosen
I know its fustrating, I do FAI's on pieces we only make one or two of.:mad: You can take exception only if your customer agrees. Unfortunately you will still have to show compliance to 8.2.4.2 of AS9100.
We have a process in place and can do it, but at what cost to the customer? There is the law of diminishing return.
Frank T.
Do you not include the cost of performing the FAI, prior to accepting the contract?
Al Rosen
Yes, but unfortunately someone failed to include the cost in the original quote.
domingue
That is unfortunate indeed. To the best of my knowledge though, AS9102 requires that every feature be verified without exception. I wouldn't buy off a FAIR from a supplier otherwise, and I'm sure I wouldn't hear the end of it if I did.
Wes Bucey
FWIW: A neighboring company in the industrial park where my business was located came to me with a similar query about a thin metal plate which had 625 holes of varying sizes.
It so happened I had visited another neighbor who had just installed a closed circuit TV with magnifying, measuring lenses, which compared and measured very small products with a three decimal accuracy. I walked the one neighbor over to the other to see the system. They struck a bargain where the TV guy performed the first article inspection with video-tape record of each of the 625 holes with exact[?] measurement for 3 first pieces (one from each of three production machines.) The whole process was completed in less than one day from their first meeting.
The system was capable of being programmed to perform a rapid test of either EVERY product (100%), or of the samples in SPC charting. It was very cool.
Perhaps you have an organization near you with similar equipment? (I'd go to manufacturers and distributors of such equipment to find "satisfied customers" where you can go "see it in action.")
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How often can AS9102 FAI be invoked? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
A AS9102 FAI Case Outline Difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Another FAI AS9102 form question Document Control Systems, Procedures, Forms and Templates 3
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Charged for an AS9102 FAI Report when requested as part of a Purchase Order? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R AS9102 Info - Must each Assembly Component have FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Does the AS9102 FAI requirement apply to wire assembly sub-kits? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M What are the FAI requirements for an assembly? New to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 FAI Reports. Need for Standard Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 30
T AS9102 Section 5.3 - FAI anytime a machinist tweaks a CNC program? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - Do I have to do FAI for all Standard Catalog Hardware items???? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 FAI acceptance - Currently having issues getting prompt approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
