AS9102 Field 19 Signature Requirement
K
Kanadamike
In regards to a AS9102 FAI. Is an authorized stamp and printed name acceptable in lieu of a hand written signature in field 19 of Form 1?
Can someone help?
Thank you
Kanadamike
Shoes
Re: AS9102 Field 19 Signature Requirement.
Ours are all electronic. Both stamp and signature.
Michael_M
Can someone help?
Thank you
Kanadamike
I have gotten some FAIR's rejected for not having a signature, even though I have stamped them. Now I sign and stamp them.
P
PaulJSmith
It was always my opinion that if the field asks for a signature, you give it a signature ... no different than citing on Form 3 a measurement in centimenters when it asks for inches. I used to reject FAIs for stamps instead of signatures.
Darrell B
It appears to me that in AS9100, a stamp and an electronic signature are given the same weight.
P
PaulJSmith
True enough, if it is a controlled stamp.
However, my point was that it is always the safest bet to provide the information as requested. If it says stamp and date, then stamp and date. If it says "signature," well...
silentrunning
Many of the signatures I run across each day are totally illegible and little more than a squiggly line. I feel better when I have an inspector?s stamp on the signature line. I think it all depends on your customer?s preference.
P
Phiobi
AS9102:A Page 12 the definition of the requirements for Form1 box 19 states: "Signature: Name and signature of the person who prepared FAI form 1..."
A signature IS needed though it can be electronic if your internal process / procedure permits.
Mikishots
Many of the signatures I run across each day are totally illegible and little more than a squiggly line. I feel better when I have an inspector’s stamp on the signature line. I think it all depends on your customer’s preference.
It doesn't matter if the signature is illegible; there is no requirement for them to be legible. This is why the standard requires a name in addition to that squiggle.
S AS9102 Interpretation on Form 2 field 6 - Specification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B New AS9102 Rev B--CA vs UAI--purist vs. pragmatic AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 Form #3 modification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C Customer Documentation Errors when completing an AS9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9102 Requirements - What information from the PO should be included in the FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9102 Handwritten Revisions on Ballooned Drawing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Two AS9102 Applicability and Interpretation Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9102 FAIR - Customer Drawing Revision Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Is IAQG planning an update of AS9102? Revision B of AS9102? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S AS9102 Parts with Machining Allowances for the Customer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
