AS9102 First Article Inspection and NC Parts - New FAI?
Hello All,
I have searched the forums but unfortunately I cannot find the answer to my question, so I will ask here. It seems like no one has encountered the same issue as me ;)
We are an aerospace company and receive parts from a AS9100 company with AS9102 FAIRs.
We have received a FAIR, which on papers looks perfectly fine, but when we inspected the physical part an NC was found. The rivets were installed upside down on an anchor nut.
The riveting process is mentioned on the router card and as well as final inspection and is stamped for.
Does this NC mean that the supplier has to redo the FAI? If so, should he perform a full FAI or a partial FAI?
Your feedback would be highly appreciated.
Big Jim
More than that!
The part needs to be returned and corrected (install rivets correctly or if needed, remake the part) AND a full new FAI completed for the correct part.
The FAI needs to be performed on a representative sample of the first production run. If the part is made incorrectly, it needs to be corrected and so does the paperwork.
They should be totally embarrassed.
dsanabria
Hello All,
First - you need to issue an NC on the affected product.
Second they need to perform a partial F.A.I.R on the corrections and affected areas.
Then they need to correct all affected products.
per AS9102
"5.4 Nonconformance Handling
The FAI is not complete until the Organization closes all non-conformances affecting the part and implements corrective actions. The Organization shall re-do an FAI for those affected characteristics and shall record the results."
Thanks guys for your responses.
The manufacturer indeed did a partial FAI, implemented corrective actions. up-issued the FAI report. updated the job router with the corrective actions included. Reworked the part and redelivered.
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O AS9102 (rev.a) First Article Inspection Requirement Quality Manager and Management Related Issues 1
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A When to do First Article Inspection - AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 First Article Inspection - Who signs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
J AS9102 First Article Inspection Requirements Flowdown to Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
P AS9102 First Article Inspection Training Advice Training - Internal, External, Online and Distance Learning 3
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 30
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C AS9102 - How many pieces need to go on the First Article paperwork? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T AS9100 and related AS9102 Supplier First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E AS9102 First Article Training Material and AS9102 Forms 1, 2, and 3 Training - Internal, External, Online and Distance Learning 7
A Looking for AS9102 On-Line or Third Party First Article Training "Help Sidney" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T When do the requirements of AS9102 come into play? First Article AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B New AS9102 Rev B--CA vs UAI--purist vs. pragmatic AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
